DenPink
Everything posted by DenPink
  1. Hi Vince The Admiral has got the ankle chains out ready to put on me + the cat of 9 tails ( but thinking of sending her on a long weekends holiday ) what do you think . Denis,
  2. Hi Vince I have the same cutter. I have only cut 1mm and it looks OK to me. Denis.
  3. Hi Vince Just love you deck planking, the slightly different colours make it look so natural . Nice work my friend. Denis.
  4. Hi Frank Thank you so much for them words. Don't be a stranger to my log. Denis
  5. Hi Bindy Thank you for dropping in on my log. Are you talking about the RW signature, yes its first class a very special lady I know did it for me ;) ( thank you ). Denis.
  6. Hi Frank Nice work on the planking Frank. See you are using the best wood glue. Denis.
  7. Hi Mike Thank you my friend. Yes great kit, but not sure about the skilled modeller bit ha ha . Denis.
  8. Hi Bindy Thank you so kindly for them words. I also will be in the front seat when you start your Surprise :) ;) Denis.
  9. Hi Brian Thank you, and yes I will be changing one or two things. Denis.
  10. Hi all Royal William. My first impression is that the quality of the materials are excellent, the castings are also well made, not a lot of work to be done on them. I have had two extra sets of plans made, one set I have had laminated so I can use a marker pen on them and I can wipe it off as necessary. What did please me was that the plans were rolled and not folded. The cost of the plans and laminating came to $500nz, it was the laminating that cost the most as the plans are large. Time now to have a long read and study of the plans. Will have to wait till the admiral goes out before I can have a play with her ha ha. Denis.
  11. Hi Ron Nice paint work on the transom. Denis.
  12. Hi Popeye Thank you, they are a bit better than the first ones I did ;). Denis.
  13. Hi Sailor 1234567890 I will finish one side of the rat lines then will take a photo for you of the SOS. Denis.
  14. Hi all Just having another go at the ratlines :(. This time on the main mast. Denis.
  15. Hi Wackowolf If they are not on ebay it just goes to show what good tools they are. Denis.
  16. Hi Brian Do you use it a lot . The only thing is they look to good to use ;) ;). Denis.
  17. Hi All I love this time of year, yes another birthday ha ha . This is my new thickness sander. When the wife goes out I will make some saw dust. Denis.
  18. Hi Mtdoramike Thank you. I have been working on her for a bout 2 years ( don't forget this site crashed and we all had to re post the logs, that is why you see the date 2013 ) I do about 2-4 hours a night. Denis.
  19. Hi All Re Byrnes tools and the extractors fitted to them. I went to the hardware shop and got a straight coupler 40mm and a 32mm bend. To make the coupler fit over the extractor fitting on the tools, I loaded up the Dremel with a drum sander and sanded the inside on one end, it now is a tight fit. The bend fits on the other end and the vacuum cleaner plugs on the end of that. Denis.
