Posts posted by niwotwill
After waiting a few days looking at the planking above the wales I am not happy with the way it looks. I realized that I had sanded the entry into the stem rabbit as if it was a wale strake. This caused the uneven planks in the front. So I'll take it off and make another correctly. I had been concentrating of the spaces adjacent to planks and not the entry to the rabbit. Too much sanding.
Thanks for all the looks and especially the likes it really helps with all my redos.
Much better color and the size looks correct
A lot of progress since the last update. Got the bobstays finished using my little alligator clip jig to space the closed hearts. It took quite a bit of time but all went well. I just finished the martingales inner, outer, and back all that is left are the foot ropes. I'm running a little test of conditioning the foot rope lines. I thinned LePages white glue and soaked the lines before hanging them to dry with a weight. LePages glue drys translucent when thick and when thinned it become almost transparent so we'll how how the test piece looks in the morning.
- WalrusGuy and Edwardkenway
- 2
Finished the first strake above the wales. The planks were made using 3/16" wide strips shaped to fit the 1/2 distance between the wales and 1/16" moulding. The aft most plank had to be made from 7/32" wide strip as the moulding sweeps up from frame 14 and beyond. Started the first plank of the 2nd strake and will finish tomorrow.
A few pictures of the planking so far.
I think I can finish the 2nd strake tomorrow. Time will tell and how much sanding, fitting, sanding, fitting it will take.
- Ryland Craze, bruce d, glbarlow and 3 others
- 6
Well we've had a change of plans and postponed or cancelled our vacation due to the Delta variant infection rate and my poor health.
Started putting the starboard side back together with the wales. After placing the 1/16" trim moulding and starting the strakes between the wales and trim I had forgotton how hard it is to get two strakes fitting between them. I measured the distance at each frame dividing it in half to shape the plank.
The first one from the stem was easy since it is so short it was just a matter of an angle. The second plank goes to frame 8 and starts wide narrowing towards the middle and then straight to the end. The fourth plank fits as it should but the proof will be the second strake.
Just a quick update and tomorrow will be finishing the first strake and starting the second.
- Ryland Craze, GrandpaPhil, bruce d and 1 other
- 4
Made the rope necessary to get the bowsprit rigged. 24 feet of tan .008/010, 48 feet of .018 very dark brown, 24 feet .021 very dark brown and 48 feet of .012/.014 very dark brown this should be enough to give me plenty of error margin.
I borrowed an idea from _SalD_'s Syren log only I ground the teeth off rather than use smooth jaw alligator clips.. I formed a 1/16" brass rod and soldered it to the alligator clips but when a heart was held the clips made dents so I found off the teeth. I ordered some from Amazon if my modified one don't work as hoped.
Before I ground off the teeth
After the teeth ground off
Tomorrow rigging starts. A very exciting day as it represents the end is in sight ie a light in the tunnel that's not a train.
- allanyed and Edwardkenway
- 2
Paul the mast coat looks really nice and a good setup for the dremel. Glad you found the post I referenced. I can not figure out how to post another referenced log. Hope it helped with the belaying pins.
Well back in shop I go. We were planning on taking to month of August to tour Maine to Massachusetts coasts for lobster and museums but with the Delta variant and my health we cancelled.
After breaking all the open heart while cleaning the laser burn I made new out of boxwood. Served up 9cm of line making a loop with a faux splice per David Antscherl's tffm vol 4. Made loops at the ends and attached to the open hearts. Served up 4.3cm making loops at the ends leaving the severing thread to be use for seizing the loop. Seized the line around the heart. Lashed the hearts to the bowsprit with tan thread per monograph.
Finished up the bowsprit parts and glued them to the ship. Made the splash guard for painting and mounting. When all items dried overnight I lashed the gammon 9 turns and finished per tffm vol 4.
Today I'm making rope for the rigging. Not very exciting.
- PRS, Edwardkenway and Ryland Craze
- 3
You're on the right track. Its looking like the way to go with sculpy.
I agree with others that I use both scalpel and xacto for different cuts. I find xacto #11 good for cutting and carving the #11 scalpel is used for slicing and paring to flexible for cutting. I also use the Micro-Mark mini chisel set but they don't hold and edge and I've upgraded to the Vertas mini chisels.
You're on the right track for the belaying pins. I did mine for the Syren a while back and now that they're on the model Im very glad I took the time and effort.
I used Thomas Gahms method and he was most helpful to getting me started. His method is explained in his Syren log page 8 post #218 and up. His suggestion I used most was to keep a drawing of the shape you want right in front of your work area for instance reference.
its looking really nice Paul. Great work on the boarding steps. Did you cut a relief in the top step for the 1/16" moulding or cut the moulding for the step?
The treenailing looks great I am very impressed with the pattern and your prior explanation of how you treenailed. I'm not sure if I want to treenail or leave mine plain so looking at your impressive job will help me make a decision.
Patrick I love your out of the box ideas. You're on a good path here. Love to hear your ideas for the next step.
Interesting result after your basswood pattern. Looks good. I like the comments of two different approaches to the garboard strake.
Patrick
Its not necessary for me to add more about how bad the quarter badges are!!!!! There are several posts where scratch quarter badges were made in lieu of kit slop. One in point is Thomas Gahms you might try looking at what he and others did .
Give it a go and the light work might keep you busy while you recover. My wife has had both shoulders repaired and the recovery time was long and painful.
Best of luck on the surgery
regards
Will
good idea to using basswood. I also have trouble with card stock patterns with things beyond planking.
Bowsprit, jib boom, and flying jib boom constructed and painted. Tried to make the dolphin striker with individual pieces as described in the monograph but not satisfied with my results. So I made it out of Boxwood I had laying around. Made a copy of the drawing and glued it to the material using sticky glue. Drilled the holes and then cut it out with the scroll saw. Filed and sanded to final shape adding the blocks.
image glued to wood with holes drilled
part cut from piece
Finished dolphin striker ready for final sanding and painting
Completed and ready for the hearts to be added
Next the hearts and splash guard
Completed making all the parts of the bowsprit, jib boom, and flying jib boom. The jack staff was straight forward using the Proxxon lathe to shape a dowel to size leaving the cap.
The travelers were made from 20 AWG copper wire bent around a larger dowel and soldered to a circle. Using jewelers sizing pliers to hold the circle at 2mm line pinched the circle which caused the traveler shape. Putting the traveler on the sizing pliers at the needed diameter and pinching the traveler causing the middle to squeeze to shape. Wrapped the center with 30 AWG copper wire simulating the rope wraps. Secured the wraps with solder. Used the same process to make the flying jib boom traveler only smaller.
The securing bands are two circles with a wire between. Used the 20 AWG copper wire that was flattened by hammering on an anvil creating a 3/64" wide strip. Hammering hardened the strip. I annealed the strip before wrapping around a dowel to make circular bands. The 2 bands were placed with a piece of 20 AWG wire between and soldered. Cut excess wire from the joint and filed to clean flash.
Now on to painting and seizing blocks for the bowsprit cap and flying jib boom tip.
Travelers ready for paint
Jib boom and flying jib boom link (with travelers)
All Bowsprit, jib boom, and flying jib boom parts ready for paint
Well my fears have come to pass and I'm starting the starboard side planking over. When running a #11 blade between the planks in between the bulkheads I pushed the blade too deep causing a gap when a new straight plank was placed. I did this at multiple locations and it was such that gaps were very noticeable. Tried to use a wider plank and shape it to fit the gaps but getting the gaps starting, depth, stopping correct was not working.
So the decision was made to start over and do a better job the second time. Had quite a mess of glue to cleanup. Got out the 80 grit and faired the entire gunport area stem to stern. Next down to 150 grit to smooth the bulkheads, sill, and port sides and finally 320 grit to finish. Painted the ports and when dry start over.
Bare boat before sanding.
Sanded and painted boat
Inventoried the wood pile and not sure if I have enough so I ordered wood from Modelers Sawmill and I'll start when the wood arrives. Its going to be the end of August before I can get back cheerfully working on Cheerful. We are going on vacation for 3 weeks and won't be back until 8/24/21.
See You Then
- GrandpaPhil, Tigersteve, bruce d and 4 others
- 7
All the offending planks removed and ready to cleanup for new. It was very difficult digging out the planks without damaging the surrounding planks. Start to add new planks this afternoon. Anxious to see how it looks but decided if i'm not satisfied with the results I'll remove all the strakes and start over.
First plank cleaned ready for new
All offending planks removed and ready for cleanup
Hoping I can make it work really don't want to start over but will.
- bruce d and GrandpaPhil
- 2
Got up this morning and couldn't bring myself #11 blade and then used a 3mm paring chisel to start digging. Unlike some port side planks this did not just lift and peel off. Piece by piece it came out without causing additional damage. Now just the careful cleanup getting ready for the new plank.
I'm going to post the process as it continues rather than wait to the end, so here goes. Here's a photo of the removed plank
Closeup of area to clean
More to come throughout the cleanup
- bruce d, GrandpaPhil and Tigersteve
- 3
Major problem today. I was close to finish planking the starboard side when I opened a tool cupboard above the Cheerful work area and when I reached in to get something and the waterline marker fell on the Cheerful. At first it looked undamaged but then I saw a gouge and a long scratch down the side.Most of the repair will be fairly easy as it is above the 1/16" plank but the gouge is on two planks above the wales. I don't feel as if I need to replace the wales and 1/16" moulding as there will be a second layer. The two planks will have to be dug out and replaced. (good thing I've had so much practice)
I think I'll go ahead and finish the planking especially since I trimmed and bent the after two pieces. And while at it I make the repairs to the damaged planks between ports 5 and 6.
Keep telling my self it could be worse and landed on the boat and knocked it to the floor breaking things.
On to repairs tomorrow
- Ryland Craze and bruce d
- 1
- 1
Bowsprit completed. As stated I made all the pieces from AYC. Everything was straight forward with the exception of the fairlead which made me think of how to drill holes on a radius. Supriseingly the method was fairly simple. I cut a square piece of material and found the center. Mounted on a rotating table mounted to the mill bed. Using a laser alignment tool mounted in the mill to locate the marked center. Moved the table to the radius and drilled the 6 holes at 21 degree angle spacing. Amazing that when aligned with the drawing it was almost perfect. Now just a matter of sanding the outside radius and filing the inside radius.
The chocks were a matter of taking a piece of 1/32" x 1/16" and filing the angle and slicing off pieces using the razor saw and mitre with the stop set to 1/32".
The saddle for the spirt sail yard sling was made be sanding using a thickness sander to thickness of 1/64" stained and soaked to be bent around the bowsprit. Same process was used for the top piece.
The iron bands are simulated by using heat shrink tubing cut to the proper width and once shrunk they don't move.
All the parts made and stained were assembled to the bowsprit previously made.
Couple photos of the completed bowsprit assembly on the Syren
I've really got to clean the Syren as the photos really show everything including dust.
- Edwardkenway, HIPEXEC, WalrusGuy and 1 other
- 4
Emma C Berry by Maury S - 1:48 scale - POF - rigged as schooner
Oh! so bad. I know how it hurts and am hoping your fix will be perfect and you can proceed. Best of luck.
