Posts posted by Haze Gray
Kevin, overall how well are those square locating pins working for you? Originally when I started designing hulls for 3D printing I decided not to use them since I wanted a solution that both located and applied some clamping pressure - I use a kind of socket on either side of the hull sections to join and clamping tabs when mating them.
Kevin, for me 99% of the time I keep history on in Fusion 360 - so if I discover an error in my work I can attempt to go back and fix/change it. Sometimes that's works great, and sometimes it also drives downstream effects and completely wreck things ...but it does provide a chance. Sometimes I'll save a particular state and then remove the history and save as a separate version and carry on from there. It's all personal choice of course....
Count me in on the Rhino session as well (whether live or video). Question on Rhino - is it mostly just for modeling or does is also have a workspace similar to F360 & SW? When I'm working on a model for 3d printing there's a lot of tools that I use to align, cut, combine, offset, etc on solids. F360 isn't the best when it comes to the creating the model but it feels pretty strong in the CAD arena.
- mtaylor and Old Collingwood
- 2
Hi Egilman, Kevin probably has the best idea for attempting this in fusion 360 - using 3d sketch to draw a spline and manipulate the control points to get the right angle and curve but that could be little messy/time consuming but could be made to work. Since I really only design ships based off frame/hull lines I don't have any meaningful experience doing a hull without them.
- Egilman, Old Collingwood and mtaylor
- 3
Egilman's description of calibrating the drawing to known dimensions is a very good writeup. One challenge that may present itself is when you don't have perpendicular lines to calibrate. Since I do a lot of older ships where the plans are rough and don't show reasonable detail down the the individual frames or the only available reliable measurement is LOA (length over all) or the two extremes of the ship are at different elevation (stern high and bow low) drawing a calibration line at an angle won't get you the right size. I've also found that (for me) it's hard to draw that calibration line perfectly horizonal which can impact accuracy.
First time printing the Ram I had problems - the raft was truly fused to that laser etched build plate - worked way too good plus I hadn't really dialed down my exposure settings so it came out essentially fully cured- despite all the razor blades and other sharp metal tools I used that sent brittle pieces flying it took me 20 minutes to clean off that build plate essentially ***zero damage*** and I was not being careful at all.
Adjusted my settings and used the original build pate I got with the printer and the ram print worked out just fine even if I had gone way overboard on the support.... so much easier to get off the build plate with just a razor blade and only just a few seconds. does appear that the MonoX can print holes that are under 0.5mm diameter where as the Photon S I had to use .8mm and up
Hello Max, when you are ready please share your you version of the Charles Martel - I will be happy to see how you design it and hopefully it will be more accurate than what I have ! - I really wish there more information available on this ship.
Here's another French Ship relaxing on the table waiting for more parts.....
Okay so I'm back to printing on the Mono X using clear resin again with settings off that G-drive document - we'll see how it goes. Throwing caution to the wind - I'm going to try printing out a 1/350th scale version of the French ram Cerbère from around 1870 (which I currently have a 1/72 scale hull of already printed). fingers crossed.....
- thibaultron, Nirvana, lmagna and 2 others
- 5
51 minutes ago, Egilman said:
I wonder how long that is going to last until it gets all scraped up and you wind up having to sand it smooth again... Looks neat though and it's proof positive that they will be releasing the DLP sooner rather than later....
I doubt it will last long - most of the build surface looks sand/glass blasted - I expect the high level of aesthetics will be over after the first print gets scraped off 😃
- lmagna, mtaylor, thibaultron and 1 other
- 4
I received two things today - the replacement LCD for the Photon S (already installed now and working but it's not a fun proceedure). Also received the new (replacement) build plate for the Mono X **finally came!** - low and behold it's got the laser etching that's found on the upcoming Anycubic DLP printer. It didn't come with any mounting bracket or hardware (shoot) but I'm still pleased with it -
- mtaylor, king derelict, thibaultron and 2 others
- 5
4 hours ago, Egilman said:
Now like I said I don't know this for definite sure, but it works for me sufficiently to say that no thump equals a more efficient print and hence a better success rate...
No thump could also mean layers are not attaching to the part - which will become visible once the retraction lifts the part above the level of the resin 😃 From experience the lager the contact area of the part the more likely you will thump with a higher report....
- lmagna, thibaultron, mtaylor and 1 other
- 4
Hi Ron, pretty easy actually, you can just pour some in by the corner.
- Egilman, thibaultron and mtaylor
- 3
Jasseji , have you thought about setting up a camera up there? If you have a rasberry Pi and a webcam there's a couple of programs (like Octoprint that's used for driving 3d printers and even slicing for prints + cam or time lapse) that would give you some piece of mind - you can access the rasberry pi via wifi on your phone.
Humm - it always worries me when I don't hear a mild to medium thump - but you're probably right - really loud thump = low resin, pour in resin and you deaden the sound....
- Egilman, thibaultron, lmagna and 1 other
- 4
So, funny thing happened, after I got the Mono X printer setup I put on a screen protector before trying any prints (scheduled for the next day) and, because it was late at night, I forgot to torque down the vat screws.... next day I pour in the resin for the first print and hit go....bed comes down...a little bit of suction and up the vat goes but I grab it and pull it out and away thinking "that was an awesome save"..... then I saw shower of resin coming down off the build plate onto the LCD.....a few expletive's ran though my mind before I remembered the screen protector was on there. totally worked, totally saved my butt...
Honestly I think cling/saran wrap might do just as well - more likely it will stick to the glass than to the FEP - either way if you're clumsy like me make sure you have that LCD protected.
Hello Max, thank you for your kind words. When you start working on a model to 3D print please start a topic and show us your progress. Which ship do you intend to choose first?
Привет Макс, спасибо за добрые слова. Когда вы начнете работать над моделью для 3D-печати, начните тему и покажите нам свой прогресс. Какой корабль вы собираетесь выбрать первым?
The Bow of the Magenta seems quite unique (even among French ships). It has kind of a symmetrical break above and below the the waterline.... it's captivating for sure. I don't think I've seen ships with a similar bow like that but maybe there are others?
- Edwardkenway, Keith Black, Canute and 2 others
- 5
Hi Egilman, If you have fusion 360 there might be some ways to repair the mesh in that software:
or this:
I don't usually work with meshes but if you send me the file I can attempt to close it and make it manifold but no grantees for success.
By the way, I saw you've had some priting issues - what resin are you using? There's a spreadsheet where users have reported settings that have been successful using the mono X here: Anycubic Photon Mono X - Google Drive
maybe that has settings that will work for you.
- Neal
Oh, I almost forgot to mention - ambient air temp can be important - 70° or above is ideal, lower temps seem to preclude good bed adhesion.
- 1
- 2
I'll definitely be following this build - the French incremental design advances starting with Gloire up through the Amiral Baudin class class are fascinating to me. At 1/72 scale the Magenta will be almost a yard long and should be quite a striking (and rare?) model!
- Keith Black, thibaultron, Free and 6 others
- 9
Hi Egilman , since I have a new buildpate on the way I've sanded down the one I have on hand - it's right around 0.115mm (the note I got from the "engineer" said anything less than 0.15mm would not impact a print - which might be true so I'll give it a go and see how things turn out. Part of me thinks it would be nice to have two build plates as I'd like to build a wash tank that I can drop the build plate onto without removing the parts - so when I am removing them there's less of a chance of dripping or unwashed parts attempting to launch into orbit during the separation process.
On another note, my tiny little Photon S is down, I got a tiny leak in the FEP and and the resin cured between the LCD and the underside of the FEP... the LCD ripped out when I pulled out the vat with almost force required - so I have a new LCD on the way but I also bought what is essentially a screen protector for both machines in case that happens again - the film covers the entire LCD screen and a bit beyond it....so those should at least mitigate some risk there.
An attempt to model a ship hull in software.....
in CAD and 3D Modelling/Drafting Plans with Software
I already use somewhere between 4-7mm (sometimes more) for the mating surface. Rather than a flange along the entire length of the edge I use a reinforced flange but only in specific areas.
