Posts posted by Haze Gray
Hi Yves, I tried a lot of different things, some were combinations (my 12 y.o. daughter helped me by applying each to test hull sections and charging me for it too!) but what seemed to work best for a single type of coating was Gesso (it’s also non toxic which is nice). Be careful though, thick layers of gesso take a long time to cure and can be a nightmare to sand down if not fully cured. A thick layer or glob of gesso can remain uncured for months and has to be peeled or cut off. Gesso applied in temperatures below 70f can take much longer to cure I typically sand down the hull by hand or with a small orbital but that’s not necessary if you apply multiple light coats and sand in between. I’ve started experimenting with some spray on options as well. I’d recommend you print out a hull section and test how the gesso works for you. Another option is to use uv curing resin - I’ve not tried that but should be viable in some circumstances depending on the resin properties.
- PeteB, mtaylor, GrandpaPhil and 7 others
- 10
Small update here as I'm getting the hull ready for painting - mostly just some sanding and filling in the layer lines to get as smooth as a surface as possible - maybe a little filler in a few areas will be needed. another week or two and I should have the hull painted - one hiccup is the hull colour below the waterline - which was likely Schweinfurt green (also known as "Paris green") which was basically paint with a combination of copper and arsenic - it also have variations in the actual color but what's easily available to me at the moment is a green with a brown tinge to it, might still work for my purposes but we'll see- above the waterline I'm going to attempt to create the "lamp black" for the hull (which is a 'softer' black and not as harsh as the oxide black..so I think mixing in some brown will get the color in the right direction with some experimentation). Above the deck will be a light buff (much lighter than the typical US Navy buff... maybe more like the white star lines buff) humm colors are hard!
here's a few pics of the getting the hull ready for painting - getting rid of layer lines with a combination of sanding and some readily and commercially available coating that will get sanded down makes work fairly quick. The flexible sanding pad (first image) works better then a "sanding sponge" as I can use my fingers to press into areas in a way that matches the exact shape of the proper contour. If you look at "image 2" and compare it to "image 3" that show how the how the layer lines actually are filled in (coating is translucent so in 'image 2' you can see layer lines under the surface of the coating).
On 8/2/2021 at 2:34 PM, sms_koenig_wilhelm said:
This is one of the best CAD models of a french ship I have ever seen, I‘m planing to make a model of Charles Martel too, but couldn‘t find any draeings.
Could you please tell me where you got the drawings that you modeled the ship after?
You would do me a huge favour, I‘m on the verge of goving up my ambitions for this ship since there aren‘t any blueprints availabie that I could find.
Hello sms_koenig_wilhelm sorry I didn't see your message until now - there's two books that would help:
ISBN 978-5-98830-060-8 (it's in russian) but if you seach the internet you can probably find an on-line copy of it
ISBN-10 : 2374680231 / ISBN-13 : 978-2374680231 - this one is in French and is also helpful
The drawings that I have found on the internet are pretty scant on details and there's a lot that are preliminary designs so you have to be careful and check the drawings across as many actual photographs as you can get on the Charles Martel. I Found that None of the designs actually match what was eventually built but there was enough there to get the envelop of the ship and selectively taking specific features from one drawing that were accurate and combining it with features from another drawing that has additional parts that are accurate (all along the way verifying against photographs). Also There were changes to the design as the ship was built so I doubt there were any final "as built" plans....
if you compare these two drawings to the photo you can see there's notable differences across the board
Welcome Bruce! I'm certain you'll find that MSW is great place to discuss work on projects and it's a trove of useful information. There are many great members here that are very supportive and have suggestions and advice on a wide range of topics. You're going to have a lot of fun!!
- mtaylor, Keith Black and Dave_E
- 3
5 hours ago, yvesvidal said:
For the portholes, I am going to try building the glass using that special chemical (name escapes me for now) from Microsol.
Ah yes - MICRO KRISTAL KLEAR - I haven't tried that yet but now have some on order, it's water proof when dry so should be suitable for models that go on the water.
The work you're doing on that ship really looks good yvesvidal. What are you planning to do in terms of the portholes? I think the corvette in this scale has a lot of freeboard but they could let in water in rough conditions.
One thing that I haven't done enough testing on is heat susceptibility for painted 3d printed ships - the glass transition temperature (when it starts getting soft) for regular PLA is ~between 55 to 60 °C (essentially above 131f) and for PLA+ 60 °C ~140f.... I've had two bare hull sections (white PLA+) outside for 12 months and they are fine, but I'm up in the pacific northwest and the sun is not that intense - what I worry about small thin/fragile gun barrels painted black and drooping when exposed to high ambient air temp and direct sunlight. I don't think it's an issue in the northern latitudes - but I have to try out a few things and see how they do. I would suspect that hull painted black, in the back seat of a parked car on a hot day with the sun hitting it for 6 hours will exhibit some effects from the heat.
- lmagna, Old Collingwood, Canute and 4 others
- 7
Quite a nice build and looks like a fun one at that! On joining hull sections together I've had limited success with using a solvent based plastic welding agent. I dropped one of my 3d printed ships (sections had been joined with a plastic welding agent) from a height of about 3ft on to a concrete floor and there was some separation but the weight of that ship was over 5kg empty (I use epoxy now by the way) but I doubt MEK joined hull sections of the 1/48 flower corvette will have issues (still best not to drop it!).
There's a lot of things you can do with designing a boat for 3d printing, if you can imagine it, you can probably do it.
- mtaylor, Canute, Old Collingwood and 3 others
- 6
13 hours ago, PietFriet said:
Are you sure about that? I have no problems exporting and .stl is still shown as a format you can export in the free version.
Well that's great news - Autodesk must have caved to the community pressure, I remember it was late last year that they announced that the free versions would no longer support export to STEP or STL so good to hear they did the smart thing!!!
- Canute, thibaultron and mtaylor
- 3
It’s still possible to get fusion 360 for free but the free version no longer allows export to the STL file format (which is what you would need for 3D printing). An EAA membership is $75 I think and you get solid works for 12 months… that might be a good option.
- Canute, mtaylor and thibaultron
- 3
Picking up where I left off, I've created a construction plane at the station which is nearest to the middle of the ship using the "plane at an angle" and specifying 90° for the angle so I can look from bow to stern and sketch and size the canvas for the station lines. I've trimmed the image already and inserted it as a canvas on that plane & I've also dropped vertical lines down on either side (using project to pick up the edges of the rectangle that I created in the beginning which represent the max beam of the ship:
Looking straight down the the center now - there's a couple of things I noticed - The scanned image of the hull shape shows some very slight skewing which really isn't unusual or a problem but the horizontal lines that I drew to see if I could intersect the position of the three rails is off by about a millimeter or so. Not a bid deal - and usually you have to decide what is going to be the authority when there's some discrepancies, especially when you might be using drawings from different sources. In this case I'll be using the drawing of the side profile as the authority since the differences are really small and it's typically easier to compensate the hull shape lines to meet the requirements of the side profile. but if the difference is large the drawings of the hull shape should control.
I've got red circles where the horizontal lines should be intersection of the bearth deck, gun deck, and underside of rail to the outside hull line - I'll actually be using multiple horizontal lines to create points at every station to make rails that follow the shape of the hull from the bow all the way to the stern which will help maintain a smooth surface and more accurate hull shape.
- Stroudwater, Tony Hunt, Nirvana and 4 others
- 7
I'm going to be starting the USS Baltimore (C-3) so I thought I'd create a thread where I can share some techniques on using Fusion 360 for creating a model of a ship and the design considerations for 3D printing that I've developed over a couple years as I progress through the design.... The Baltimore is a nice mix of areas that are easy and some harder spots so it's a good example to use.
It's also a pretty historic ship - built domestically in the US using plans bought from Armstrong-Witworth. Baltimore was an improvement on it's predecessor (USS Charleston). It was laid down in 1887 and was one of the first US Navy ships with the more powerful and efficient, and at the same time it did away completely with sails which were still often provisioned on other ships of it's time. The Baltimore was one of the ships involved in a diplomatic crisis between the US and Chile during the Chilean civil war. During the Spanish American war Baltimore was second in line behind USS Olympia during the Battle of Manila Bay. As a side note it seems the plans for the Baltimore were originally drafted by Armstrong for bid on work for the Spanish Navy who eventually turned down Armstrong's design in favor of one from JG Thompson - who produced a ship for Spain which was christened the "Reina Regente" which tragically sunk with all 420 hands after 7 years in service.....Here's a few details of the USS Baltimore:
Length: ~336ft
Beam: ~48.5ft
Screws: 2
Speed: 19knts
Main Armament: Four 8" guns
Secondary Armament: Six 6" guns
Type: Protected CruiserFirst thing I do gather as much information on the ship – photos are of great importance since a lot of the detail areas of the ship you won’t find in drawings that are available. I was lucky enough to find a series of drawings that included the hull lines on the Baltimore in either the library of Congress of the National Archives (I can’t remember which – since I grabbed them about 2 years ago). I also downloaded every photo I could find from the Navy History and Heritage archives which is a good supplement to the library of Congress and the National Archives. The plans that were available were old blueprints – actually blue! And the lines for the hull were hard to discern so I converted the images to black and white and tweaked the hue and contrast so it was a little easier to see things:
Before I go any further, I want to mention that for creating ships in Fusion360 I use the metric system since the 3D printer that I use is basically a metric system machine with movements in fractions of millimeters and a nozzle size of 0.4mm so that particular dimension (0.4mm) is somewhat of a constraint in the design process (i.e. I cannot print something that's only 0.2mm wide)
The next step is converting the ship measurements into millimeters (length and width) and creating a box in fusion that I'll use to start designing the hull, but before I actually do that I'm usually checking multiple sources and, not surprisingly, I got different from different sources and usually no clear definition of what the measurement actually is (i.e waterline length, parallel to parallel, or length overall). Since two sources (one of which was the "Dictionary of American Naval Fighting Ships" published by the Department of the Navy) concurred that the length was 335' and beam of 48'8" that is what I'm going with. After conversion to millimeters at 1/72 scale it comes out to 1418.2mm long and 206.0mm wide....so now I draw that box in fusion 360 on the X plane in Design/sketch mode using a "center rectangle" on the origin and put a line down the middle lengthwise
Next I switch to the Z plane and use the "p" key to project a point on both ends. I use these points to draw vertical datum lines that will be used to define the aft and foremost ends of the hull:
These lines help a lot when sizing and centering images that you want to trace. This is where things will get a little tricky - so were going to start with a side view of the ship and insert it into the design and scale it up and down it until the ends of the bow and stern are just touching the vertical datum lines and the highest point of the bow is touching that middle line that runs down the center of the rectangle. (To insert, position, rotate, and size an image on a plane in fusion 360 you would used the "insert canvas" while in the "Design Mode"). So I've done that and have it zoomed in to show the bow position:
From here, we're going to do a couple of different things. Firstly, you'll want to look and the hull profile lines and write down the station numbers because you'll be needing those later! On the Baltimore there's 23 unique station numbers (going from 1.5 to 21.5) as below:Next is where it starts to get fun (maybe...) - were going to trace the side profile of the hull using the design/sketch mode in Fusion 360. An in the case of the Baltimore we'll draft a line along the all the rails and decks (which you can see named in the picture above) even if they are incomplete. We also need to draw the vertical lines for the stations of the hull profiles. One mistake I use to struggle with was using a straight spline when tracing curved features of the hull, especially the bow. Splines by themselves can work but once you complete a spline it becomes harder to correct. These days I use "sketch points" and draw splines from sketchpoint to sketchpoint, and its a bit easier to make adjustments if I didn't quite get things right. Here's close of up some sketchpoints (in white) I'm using to define the bow: defining
And here's where I am basically ready to move on to the next step and add the lines that define the shape of the hull (which I'll be using the vertical lines to do):
Welcome Tim! I agree with others - the toothpick, scrap wood, and thread model in your photos is really good - because it was fashioned by hand from just basic materials available it has distinct presence and real magnetism! And a very warm welcome to you, you are in good company here!
- Edwardkenway, Keith Black, mtaylor and 1 other
- 4
Very nicely done indeed - congratulations!
- mtaylor and GeorgeKapas
- 2
Hi Jean Pierre, welcome! I do quite a bit of CAD myself but I use Autodesk Fusion 360 - it's available for free for hobbyist but I don't think you can export to other formats like STL or IGES with the free version - to export to other formats you need to pay a subscription.
- Ryland Craze, Keith Black and mtaylor
- 3
Hi Ron, Yes indeed the figurehead and the stern plaque were likely added in 1901 during a minor refit - Marine engineering from April 1902 reported on the changes of some of that refit included photos of the bow ornament, stern ornament, and a flat plate with a relief that commemorated the battle of manila bay.
1 hour ago, lmagna said:
Hi Lou, I do have that one and a few others for the Olympia - I know of about 5 bow ornaments/figureheads that have known public locations but whereabouts of all the rest (including the Olympia's) are unknown to me. A 3D scan would make quick work of the modeling - I am kind of assuming that many have been preserved somewhere (hopefully not in private hands). Since I'm very new to 3d sculpting it might take a really long time to develop the skill to do these but eventually I'll get there if that's what it comes to!
The bow ornament from the USS New York (ACR-2) was actually at the Puget Sound Naval Shipyard Museum, Bremerton, back in the 50's, that's one I'm chasing down too.
- lmagna, thibaultron, mtaylor and 1 other
- 4
1 hour ago, thibaultron said:
The Olympia is berthed in Philadelphia, though admittedly, it would be a long walk, for you!
Unfortunately the Olympia as preserved does not have the figurehead otherwise I’d be there in a heartbeat!
- 3
So, I'm currently modeling the USS Olympia and for awhile I've been thinking about how to model the figure heads on some of these old ships - I have a resin printer that would use for the actual printing - but as far as creating a model I don't think what I usually use (Fusion 360) is really the best tool - maybe blender is the best option? (have never tried it). The figure head of the Olympia was some sort of forging - it's possible that's it's still around and ideally I'd like to 3d scan the entire thing but it might take a long time to track down!
Anyone have any suggestions?
- thibaultron, Canute, mtaylor and 2 others
- 5
So lately i've been looking at large format resin printers - the Peopoly Phenom has a build volume of 276mm x 155mm x 400mm which is really big.... One could conceivably do a complete hull with a lot of detail and do it much faster compared to printer that uses filament. I've been thinking about doing ships that I design in 1/350 scale and that Phenom looks like it is basically what I had in mind... tempting....
- lmagna, mtaylor and thibaultron
- 3
4 hours ago, yvesvidal said:
That display of hulls is amazing. Are you selling them?
Yves
I don't think I'm at the right point to sell them but my typical process is to get the design done, then print out the first draft of the parts and see how things fit together and if I need to make adjustments or changes (sometimes I forget to add something, etc). So through that draft process I finalize the design as much as I can and re-print anything that changed. These things take up space so if you're interested in getting one of the finalized drafts I can probably make that happen provided you cover the shipping cost - bear in mind that these ships in 1/72 scale typically range between 1300mm to 1900mm from nose to tail.
The one thing I would add is that most 3d printed parts will need some sanding and surfacing - it maybe plastic but it's not injection molded.
2 hours ago, Hubac's Historian said:
Oh my! What are your plans for this battlefleet?
Well my only plan really to to grow the fleet! - I have about 700 ships of the period that I would like to model - however, based on my calculations I am unlikely to live long enough to complete more than 350. Granted I am much faster now than I was in the beginning and have about 25 designs that are pretty far along, but it would be hard to do more than 1 per month on average. 1/72 scale is kind of ideal for the typical ship of this period since it allows for a reasonable level of detail for the typical 3d printer that uses filament but the size of the printer needed typically is larger larger than what the more economical printers out there can support (both in build plate area and Z axis depth).
Flower-Class Corvette by Yves Vidal - FINISHED - 1/48 - Bensworx Virtual Kit - 3D printed
There is an option to 3d print stanchions - but it would require something like a printer that uses ultra-violet curing resin - and you'd need to select resin that is more durable than what's typically used (most UV curable resin tends to be on the brittle side). I've not tried this but my gut tells me it's not a good option but then again I haven't tested anything.
