Posts posted by Haze Gray
8 hours ago, qwerty2008 said:
How's that lulzbot treating you?. I've used a taz6 before but wasn't too impressed. Perhaps I didn't have enough time to get to know it though. All my personal printers have been cheap ones. One I built from scraps and only cost me $30.
Well, the Taz I have should be doing better in my opinion - I'm already planning on building a core x/y for the next printer. All in all, considering the boat anchor of a head on the Taz6, it does okay.
Hello All - another photo showing 4 of 9 sections completed. I'm going to switch to a .5mm nozzle and see how that affects the print time and quality.
As I've been printing I've noticed issues that I'm going to correct for when I re-slice the hull. When I originally sliced the hull I was somewhat purposefully kind of randomly slicing (so I didn't avoid slicing through portholes for example). Here's some lessons learned thus far:
a) I went with an atypical thinner hull wall thickness (5mm) so on really tall hull sections (over 175mm tall) there's some noticeable shrinkage so the hull sections are pulled in towards the center about 1-2mm. It's not bad but I'm probably going to re-slice for sections in the 125mm to 150mm range to minimize this.
b). I'm going to put in either 3 or 4 tabs to join sections using thin nut and bolts - this will help accurate with alignment
c) I'm going to slice to reduce the need for
infillsupport - basically because some of the surfaces that need to be mated to parts (like the cut-out for the turrents) have edges that need to be properly printed to keep the post labor count low (e.g. as little sanding as possible).d) The piping around the portholes look great, but if the layering on the hull can't be smoothed out with primer and paint and sanding is needed the port holes will get in the way of that - I might have to remove them. I'll know more this weekend when I try painting one of the hull sections.
e) PETG might also be a good material to try, I never tried it for something this big but it's a much more stable material and I think it flows just as well if not better than some PLA's so will give that a go at some point and see if I should look harder for a material that gives superior results when it comes to hulls. What I use now works well, but I think there may be something better out there.
I should have an update with another section of the hull tonight. I’ve already come up with some ideas how to make things work better for printing large hulls and look forward to sharing.
- Canute, lmagna, popeye the sailor and 1 other
- 4
2 hours ago, fnkershner said:
CDW - I suggest you friend also look at Shapeways.com. Cost is a bit higher but the quality is amazing.
Interesting thing with shapeways, I uploaded a section of the hull from the USS Maine, one from the middle - lowest cost to print was over $1000, I guess size does matter above a certain threshold. The Charles Martel hull is 20% wider than the Maine and the USS Brooklyn is even longer than the Martel.
- mtaylor, popeye the sailor, Canute and 1 other
- 4
To Joe and CDW, I think what got me interested 3D printing boats was that I didn’t have a lot of time, tools, or experience building boats. So learning the software seemed like the best path forward and I could also afford to make mistakes because I could correct them in the software, or I could identify them more easily at least.
The other thing is that designing the the boats in software would allow me to do is release the designs into the public domain when I no longer have use for them, which in the end kinda good for everyone who wants to print a boat like the ones I work on.
42 minutes ago, CDW said:
I just searched for Fusion 360 software and found that I can have my college student daughter download the program for me for free. Cool.
Hi CDW - it's free also for hobby enthusiasts too - "For startups generating <$100k/year in total revenue or wholly non-commercial users:"
here's the link: how to activate startup or educational licensing
And if you have a EAA membership you can get solidworks 2006 I think. I have solidworks through that program also but really haven't delved into it yet. Fusion 360 has alot of info online and via youtube but basically no books - Solidworks is the other way around - it has lots and lots of books on how to you.
I got enough use out of fusion 360 that I'm paying the $40 a month which gets me a reliable uptime for the server.
Sharing some more on the Charles Martel Build - I worked a little on the forward outward turrets and their mounting/rotation axels - I haven't quite got it right as I have yet to find a clear photo that is 90° to the side. I decided to take a break and sketch up a cradle from the boat that I can lay it in while i work on it as it's no fun working on a hull on the ground - tends to not stay still.
- fnkershner, popeye the sailor, CDW and 3 others
- 6
- fnkershner, Canute, shipmodel and 10 others
- 13
2 hours ago, CDW said:
Do you know of any ready-to-print 3D files of ship models out there?
My buddy has found many ready-to-print files for RC aircraft, so I assume there might be some for ship models, too.
Hi CDW,
As far as ready to 3D print boats....there are not many that I have found and only one or two interested me. If you search Thingverse for "calypso" that's a pretty good one - it's not designed for RC but can be modified to be. It's pretty well done, and there's some detail parts that will put any printer to the test for sure (crane winchs, etc.
That's really what prompted me to start designing myself - the boats I really was looking for were simply not there!
- popeye the sailor, mtaylor, Canute and 1 other
- 4
29 minutes ago, tomwilberg said:
Haze Gray,
an ambitious project you are running.
Since you didn't drop a word about your sources except a Russian forum:
I wonder if you know about the Builder's yard plan sets available from the French Navy Historians (Service Historique de la a Defense). The web site is currently offline, but there are enough backup copies around.
Regards
Thomas
Hello Thomas,
I believe I was able to get a complete copy of all the files that were up on the Service Historique de la a Defense site ( I think!) yes there are a lot of copies around on the Internet including those at the "dreadnought project" website.
As far as the Charles Martel goes - there's very little out there that I'm aware of, and the Russian site I listed is probably among the best I found. I even have another book in Russian that is about as good. If anyone has another reference please let me know. The French battleship Carnot I have found very little on (almost nothing) in the way of plans, much less than any of it's sister ships.- Canute, popeye the sailor and mtaylor
- 3
38 minutes ago, CDW said:
It only seems like a lot to me because I have 0 experience with 3D printing. I really had no idea how long it might take. But if I was forced to venture a guess before you advised on the length of time required, it would have been a much lower guestimate. I am assuming your 3D printer is NOT a low-end printer like my friend bought (and is experimenting with). From the video, yours appears a higher grade and slightly larger than his.
I've been 3D printing for awhile so I'm no stranger to longer print times. The first time I did a big part I did took 24 hours and I thought that there was no chance of it completing successfully, but it works and it did. I think the key part of 3D printing is that you spend your labor hours designing, and then you turn it over to the machine to actually produce - meanwhile you put in a day at work, have dinner, play with the kids, etc...
- 4
1 minute ago, Hubac'sHistorian said:
The thought that just occurred to me is that the computer technology available to us today makes it easier than ever to master a build, and thus create a commercial kit, and furthermore (oh, yes, I raised it to that level of furthermore) to interest young people, kids, in the hobby. The primary obstacles to creating good, off the shelf and interesting scale models seem to be lifted now.
I am all for modelers creating projects from scratch, however, we can only approach that ambition through our introduction to the hobby, via kits.
Yes, lots of things are changing - there are basically no more brick and mortar camera stores around in Seattle (maybe 2 I think) and the hobby stores are seem to be getting rarer as well. I think the "ready to run" and "ready to fly" aren't good competition to the video games which has huge $ behind it as an industry. Kids can learn to design and when they print something out they conceived themselves it does have much of the same satisfaction as when you construct something - you put some of yourself in there and once it's realized in the physical form there's the payoff.
1 hour ago, CDW said:
Wow...18 days straight is a sobering thought.
What type of material are you printing with and what typer of glue is required?
I'm using eSun PLA+ which is pretty good for PLA, you just need to make sure (as with any PLA) you paint it as it can be sensitive to UV. ABS is another material I'm considering. For PLA, I've been using Jet Hot brand super glue, also the gorilla superglue is good.
18 days might seem like a lot but the machine does all the work at that point and right now I have the hull split into 9 segments so about 48 hours each. It is a 1/72 scale boat and so not exactly on the small end of the scale although I can print a 1/96 scale version of it in 10 days and use about 1/2 the material.
- mtaylor, CDW, fnkershner and 2 others
- 5
1 hour ago, fnkershner said:
I agree about the YouTube videos. Lots of good info. Not much for ship building. So your initial plane was the deck or the cross section along the keel? How big is your 3D printer? This is a large model.
Actually, you can start with either one (keel or deck). On the USS Maine I started with the deck, and on the Charles Martel I started with the keel (mostly because there's 3 deck levels on the Charles Martel and I needed some time to get my head wrapped around how best to do that.
My printer is just big enough to print the largest cross section of the Charles Martel model but it's pretty wide - the USS Brooklyn for instance is about 10% narrower but it is also about 10% longer. German ships from around the same period are definitely narrower but noticeably longer.
With my current nozzle size and print settings a full hull for the USS Maine would take 18 days of continuous printing but I am getting pretty good results - I'll probably be testing a larger nozzle this weekend and see how fast I can print at an acceptable quality level.
- mtaylor, popeye the sailor, Canute and 2 others
- 5
6 hours ago, fnkershner said:
Ok lets start with a question or 2. what is the total length of the model? How are you planning to print her? I assume in sections and you will lay them down with the cross section to the 3D printer bed to reduce the support structure required. If you print in sections are you planning something to assist the join? Such as a tab that overlaps.
How did you arrive at the hull design? For my project I have been thinking of establishing the initial plane as the deck (mirrored). The at points along the hull create construction planes and draw bulkheads on these planes. Then use loft to connect these bulkheads.
Hi fnkershner,
All really good questions - total length of the Charles Martel model in 1:72 is 1.6 meters or 5'3.6". I'm currently printing out the hull sections of the USS Maine that I am also working on (see here: https://modelshipworld.com/index.php?/topic/18130-uss-maine-by-haze-gray-172-scale-radio-plastic-3d-printed) I've printed hulls of different boats, usually I just glue them together but tabs can be good if they are done right - I do plan to add tabs to the USS Maine and the Charles Martel once I have figured out the best sections to slice the hull in.
For the hull design I construct ribs as I'm 3d printing and want to control the thickness of the shell (see attached picture) and do use offset planes for each one and then loft. There's a lot of good videos on youtube for learning fusion 360 but not that many specific to boat hulls. I have not yet played around with the Deft Ship software that's also a common tool but I'm interested to try it in the near future.
- GrantGoodale, Canute, fnkershner and 5 others
- 8
7 hours ago, hexnut said:
Very cool project! Are you printing with a Taz? The parts look very nice. What extruder nozzle dia. and step are you running?
Hi Hexnut,
I'm running a Taz6 with a .4mm nozzle and .18 layer height.
- thibaultron, Canute, paulsutcliffe and 4 others
- 7
I worked a little bit on the transom after work yesturday which reminded me that I should post a little bit about both the Charles Martel and using Fusion 360 to design and also 3d Printing boats.
Fusion 360:
First off, once you have the design reference you need and enough photographs (which can take a long time to find as I'm sure many of you know already) once you start sketching the boat in Fusion 360 the hardest parts to get right are the bow and the transom. The method I use to turn ribs into hulls involves the use of "lofting" function in Fusion 360. It works pretty well in that you select two faces of a sketch and it creates a solid body between the two sketches *unless* the two sketches are at right angles to each other. This means you have to get creative and sometimes it takes multiple attempts to get the program to loft and then you need to go back in and adjust the sketches to get the right shape.With the Charles Martel, I ran into an even tougher problem - the transom is rounded on the sides and on the top which doubles the effort and experimentation to get it right. I just got it right but I think it was more like "luck was on my side". I struggled for awhile only getting close and not being able to fully close the surfaces until I tried something a little different and it worked and I was able to take that and use if for the rest of the problem areas.
Charles Martel:
For those that want to read more about the Charles Martel follow this link - it's a translation of a Russian book that covers the the Martel and her four sister ships: Carnot, Jauréguiberry, Bouvet, and Masséna. https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=https%3A%2F%2Fmilitary.wikireading.ru%2F35527
These 5 ships were called "sample ships" the design parameters were all the same in terms of high level performance, armor, and armament direction, so built to a broadly similar design, but different enough to be considered unique vessels.....however there were 4 different designers (one designed two, the rest each had their own designer). The design experiment of these ships was primarily the non-centerline armament arrangement. Subsequent ships produced later reverted back to the centerline type arrangement for the main armament.
The Russian book above I linked to was somewhat critical of the design approach as most of the armor was concentrated along the waterline while most of the upper structure was thin metal that would leave the crew exposed. This exposure was probably not significant when the designs were initially conceived as armor piercing rounds would pass right through and only cause damage to what was directly in the path of the shell. However by the time these ships were launched the advent of powerful, effective, and reliable high explosive shells was descending on naval warfare and the absence of adequate protection above the waterline along with minimal watertight compartments meant these ships, including the Charles Martel, would not have a significant role in WW1.
2 hours ago, yvesvidal said:
You are going to start your own plastic printed company, if it goes on..... Congratulations.
Yves
Well, now that the kids are old enough to mind themselves to and from the bus stop I did mention to my wife how easy it would be to keep a few machines printing continuously during the day - maybe that could be a home business for her. Well, she immediately fired up the computer and started typing her resume! I took that as a signal she was not on board with the idea.
- Canute, fnkershner, yvesvidal and 2 others
- 5
Hello All,
As I'm in the downward section of the designing and printing the USS Maine, I couldn't help but start on the French Battleship Charles Martel. I think it's a beautiful boat and comes from an interesting time. I'm fascinated by the tumble home designs and the Charles Martel has that in spades!
You can read more about the Charles Martel on Wikipedia here: https://en.wikipedia.org/wiki/French_battleship_Charles_Martel
Will write more later but for now, here's a shot of the hull in work. there's not a lot of definition in the pronounced armor belt ...yet, but there will be!
- lmagna, Story, popeye the sailor and 4 others
- 7
Hi Folks,
One last picture - more of the hull done. I'll be switching over to the Scratch-build section from here on out, but after the Charles Martel I'll be doing the USS Kathadin (a ram boat!) and then will return here and let you all know if I'm doing the Carnot.... or not.. (I'm too funny).
I'm so glad I found a group that can appreciate the pre-dreadnaughts!
- Canute, druxey, thibaultron and 3 others
- 6
Well got a good part out, saw a few things to change (move the slice point & put in the rear firing ports & the ports for the stern lines).
There was a lot of support to remove (extra plastic material deposited to support overhangs) but I’m actually pretty pleased with how the portholes turned out.
I added the rudder I printed out previously in one of the pics - fits perfectly. When you print parts that need to interface you have to establish what tolerance your printer can hold reliably. For some interfaces I can go down to 0.05 mm but I usually stick with 0.1mm.
2 hours ago, shipmodel said:
I did a USS Maine in the same scale some time ago and found out two things that might be useful to you. First, although authorized, the torpedo boats were never carried by the Maine in the two years between her commissioning in 1896 and her end in 1898. I had to scrap the ones that I started. You can certainly add them to your model, and they look good, but not historically accurate.
Also, there were a series of photographs taken of the entire ship from various angles and others taken on deck in several places. These are in the Library of Congress and have been scanned at 1200 bpi, so they can be enlarged to an amazing degree, which can show many construction details that do not show up anywhere else. They are free to download from the Library's website, which I don't have at the moment. Let me know and I can dig it up for you. In the meanwhile, below is what can be done with an enlargement of one of the overall shots. Hope it is useful to you.
Dan
Hi Dan, I most of those pictures also, and I love it when I find a good crisp large format film photo that's been digitized (some from the library of congress are over 100mb!). I'm definitely trying to get things right but (confession time) I'm totally new to fusion 360 so limited skill set - and most of the "plans" out there on the internet for the USS Main, while good when compared to photos are also clear that they are "general arrangements" and deviate from the "as built".
I do plan to go back in the future and turn some iterations to get as accurate as possible -
As for the Torpedo Boat being on the USS Maine (or not), is actually an interesting topic to me - I have not yet found any photos with the torpedo boat mounted. I've seen websites that mention the Main was not equipped, the second boat was not completed, the first just became a training boat and "most likely ended as scrap". I've not seen any primary source of merit mention the fate of the torpedo boats.....except one. I actually posted that a few days ago up in the thread but the end got cut off so attaching the relevant portion to this post. The Scientific American journal says it was destroyed along with the Maine! (key ominous music)(please don your aluminum foil hats!) Perhaps the little torpedo boat that was built was loaded up on the Maine just prior to the departure to Cuba.... and just maybe it was launched far off from the harbor as an insurance policy - if the Maine came under attack at night the torpedo boat would make for the harbor to try and attack the aggressor (large cruisers and battleships were easy prey for such a torpedo boat - especially in a harbor at night before "torpedo nets" were adopted). Possible that a small torpedo boat which can turn off it's boilers and run slow and silent into the port under remainder steam and pressure and either a) execute a hidden agenda to to torpedo a Spanish ship but mistake the Maine for it's target, or b.) slipped into the port in darkness with plans to be hoisted back on board when a lever, thought to be the one to discharge the air that would launch the torpedo , was in the utterly necessary and lightless stealth of darkness mistakenly the lever that actually launched the torpedo.
ha! gets you thinking!
Actually the whole reason I'm building these two torp boats is because, at 1/72 scale, they are just big enough for light weight RC gear and propulsion and I hope to be able to launch and recover them!
- Canute, thibaultron, hexnut and 5 others
- 8
6 hours ago, Roger Pellett said:
(message meant for AL actaully...)
3D printing is simple technology in that it lays down a layer of plastic type material at a thickness you specify. There's tweaking that needs to be done but once that's completed you can get reliable prints again and again.
poor video but this camera is attached to the bed of my printer and shows the vertical build-up of a part (shroud the turrent spins inside).
https://www.youtube.com/embed/baGSAz0jqbQ- Marcus.K., Nunnehi (Don), lmagna and 5 others
- 8
Charles Martel by Haze Gray - 1/72 scale - RADIO - 3D printed - French Battleship
Posted · Edited by Haze Gray
added some notes
Started working on the guns - going well considering I only have photos to work from - still need to work in details on the back of the turrents (hatches) and other stuff, but not alot of great photos out there, some are good but....but I'll take what I can get - it's amazing that there are as many photos as there are considering it was about 120 years ago!
Oh by the way, some learning from time spent working on the USS Maine: Hull first, place all the guns and pivot points and gears, put in the motors, mounts, and shafts, servo pockets and battery compartments, and then work out where you can put servo and linkages for the turret tramming! (at least that's my current theory on the sequence)
