GrandpaPhil
Everything posted by GrandpaPhil
  1. The gratings now have something to sit on, so next step: painting.
  2. I have the framing for the head gratings in place. The first set of seats of ease are painted and installed. I have a few more pieces to make and install so I can paint the framing. Then I will start the gratings themselves. I am going to use the exact same method I used on the Prince de Neufchatel to make the gratings.
  3. Here is where I am starting off for the day. The center piece is partially base coated. The top rail needs touched up. I also had a fortuitous event this morning. I discovered that I had a good sail plan for the Victory which is the last thing that I lacked. I found it on page 190 of Bjorn Landstrom’s The Ship. I had planned on pausing Victory to build the Edmund Fitzgerald but I believe that I am going to press on with Victory. I am two and a half years into this build and I think it is time to finish it.
  4. After reflection, I think I’m going to use the same building methods as I did for the Prince de Neufchatel because it worked very well the first time.
  5. Dan, How do you laminate card without it curling? I have had a time with it. I’m looking at starting another card build. On my last one, the bulkheads and the center keel plate warped badly after lamination and I was wondering if you have any tips.
  6. The head rails only lack paint now, otherwise they are done. I made the mouldings. The beakhead bulkhead is just test fitted in place. Next step: paint!
  7. I got a set of plans for the Edmund Fitzgerald, today. They are in 1/192 scale and originate from the Archer Company in Toledo, OH from 1978. I will be putting the Victory on hold in the near future for this project. I am going to build her POB. The keel and bulkheads will be 1/4” plywood. The covering will likely be the leftover houghtboard that I used for the Prince de Neufchatel. The Edmund Fitzgerald was steel, so I’m not worried about planking detail. Plus 1/192 scale makes it difficult to put tiny details on anyways. I’ll start making sawdust in the near future (it depends on when I get to a hardware store).
  8. Welcome!
  9. Yep. I take my stuff when traveling on business. On my last business trip, I made a bunch of test carvings off the sterns of the Triton and the Winchelsea just to see if I could.
  10. The beakhead bulkhead is carved and is test fitted. I need to adjust it to take the bowsprit, but otherwise it is okay.
  11. Quick question, when did the Royal Navy start coppering their hulls?
  12. My beakhead bulkhead is being carved. In hindsight, I should have made this in multiple pieces. Oh well. Live and learn. If it doesn’t turn out well, I’ll make another.
