GrandpaPhil
Everything posted by GrandpaPhil
  1. The Endeavour has a bluff bow. Make sure you use plenty of filler blocks around the bow. I built the Mamoli Endeavour as my second actual ship build and that first layer of planking was challenging for me.
  2. All cannons are painted: I used wargaming miniature painting techniques to generate the faux metallic look with acrylic craft paints. I have never painted faux metallic bronze before, but it looks mostly like bronze stuff that I have seen before. So, I’m happy with them. Next up will be the carriages. I am going to mount the demi-cannons, canon periers and the sakers on conventional carriages. The culverin type guns will go on the two wheel carriages. The breech loaders will get the block mount shown in Zu Mondfeld’s Historic Ship Models. The two-wheel carriages will come from the same plate. I will trace the four wheel carriages out of the instruction booklet that came with the plans. Everything will be sized and scaled accordingly. After I get all those done, I’ll install the ones I need to preinstall and then get back to covering the hull.
  3. The breech loaders are finished: All cannons are finished and just need painting. All of them but the canon periers will be painted with a faux metallic bronze. The canon periers will be painted faux metallic iron. However, they all will start out painted black. The bronze ones will have successively lighter browns layered up and dry-brushed on. The iron ones will have grays layered up and dry-brushed on.
  4. For myself, I prefer wood or card for wooden ships. For steel vessels, I personally generally prefer plastic or card. Although, I have some interesting books that discuss scratch building steel ships from wood.
  5. This is the Orel kit of the Battleship Orel of 1904. Orel is alternately spelled Oryol and literally translates to Eagle. Having built an Orel kit before, I can attest that their kits are excellent. I bought mine off Amazon. This kit has optional laser cut and photo-etch sets available. Like the Solferino, the instructions come in Russian (I think), Polish, German and English. There are construction diagrams at the beginning of the book this time. Construction is a modified Plank On Bulkhead. The quality of the parts sheets are excellent and printed on A3 paper or card. Most parts are printed on paper for laminating onto card. Some are printed on card and ready to use. If you are interested in card models, Orel, a Ukrainian company, makes excellent ship models, in addition to a full range of other card models. They have a pretty decent selection of ironclads and pre-Dreadnoughts from around the world in 1/200 scale. Most have optional laser cut and photo-etch sets available. I liked the first model that I got from them well enough that I ordered three more. When I get the other two I’ll review them too. The price for this particular model was $46.99 with free shipping.
  6. All cannons that are getting seals have them: The last step prior to painting will be installing banding on the breech loaders.
  7. Everything that is getting seals, has them, except for the sakers. I’ll get the seals on the sakers the next time I work on my model. I am thoroughly enjoying this build. Chris did a fantastic job of drawing the plans and making the assembly booklet. Taking the plans from the Victory Models kit and expanding upon it is working out great. Plus, they are adapting to card quite nicely. I know that I didn’t really need to make the guns yet, I only needed a few carriages, but the guns are a major part of any warship. At least now I have them and I now know beyond a shadow of a doubt that I could do a full set of guns for a much larger warship (like maybe a 2 or 3 decker in the future?). Carving them is not overly difficult. It only takes about 40 minutes each starting out. Once you get the hang of it, carving the cannons goes pretty smoothly and swiftly.
  8. I am going to try normal paper, cut from scrap, sealed on both sides, wrapped a few times for the breech loaders.
  9. Prototype seals: They look good so far. The detail is partially cut and partially indented into the seals. After I make these, I need to figure out the mechanics of banding the breech loaders. They are so small the card is separating when I try to wrap them.
  10. All 40 cannon barrels are carved: The port guns and fowlers (the breech loaders on the lower right) still need banding. The rest of the guns, except the falcons, need the royal seal on them. That will be a task for the near future. My thanks again to @allanyed for providing the seal. I will copy the seal into Word, replicate it 32 times, sized for each of the various calibers/types of cannon, and print everything out on cardstock which will be sealed and possibly CA’d to allow for minor carving. Then, I will glue the seals to the cannon.
  11. 1 saker and a few breech loaders left, however both falcons are made: The last saker split out on me while carving so I CA’d it. I decided to get prepped for the falcons and discovered that there was very little carving to them. So, I decided to carve them really quickly while waiting for the last saker to dry. They took about 15 minutes apiece. The breech loaders should be quick, too. Now, for that last saker.
  12. In other news, I just ordered the Orel kits of the pre-Dreadnought battleships Mikasa and Orel, and the Ironclad Battleship La Redoutable! All 3 will most likely be rescaled to 1/100 scale
  13. 13 cannon remaining: 5 more sakers, 2 falcons, 2 port pieces and 4 fowlers are all that’s left. The sakers are going well. The falcons are small organ pipe style cannons. The port pieces and the fowlers are the Henry VIII style block mounted breech loaders.
  14. First two prototype sakers are done: I am going to have to figure out gun placement and carriage construction once I finish all of the guns. The rest of the sakers will have a wood breach reinforcing band. These sakers did not because I ran out of the heavier dowel rods and have not dropped in on a hardware store yet.
  15. Demi-Culverins are done: Next up: 10 sakers Speaking of which, some shaping and assembly required:
  16. I am currently reading The Adventures of Captain Hatteras by Jules Verne right now. It is interesting reading about the Franklin Expedition in 1845 from the perspective of a contemporary. The premise of the novel is an Englishman, Captain Hatteras, who wanted to reach the North Pole in 1860 aboard the steam brig Forward. Verne relates back to the previous Polar expeditions quite a lot, and the Terror and Erebus of the Franklin Expedition in particular. I haven’t finished the book yet. I’m about two thirds done with it and it is very good so far.
  17. 6 demi-culverins, some shaping and assembly required: I am using the same drawing for the culverins, but further reduced.
