GrandpaPhil
NRG Member-
Everything posted by GrandpaPhil
Do you have a copy of Zu Mondfeld’s Historic Ship Models? If so, there is a great jig detailed in there for making ladders. I have used it in the past with great success. I have also duplicated the Amati method of making ladders in my current build. It has worked quite well for me. Both have some setup, but both are conducive towards making ladders that are evenly spaced and properly squared up.
Here are the end pieces of the decks, some painting and detailing still pending, and all door/window frames, in cardstock, glued to 1/16 basswood, as well as the majority of the quarter badges and Elizabeth I’s monogram: From the scroll work left over from when I did the learn to carve tutorial on this site, you may assume that I have had this piece of basswood for several years. By the way, if you would like to learn to carve, the learn to carve tutorial group on this forum is a most excellent resource and way to learn to carve. It is how I learned to carve. For the doors, I am cutting out the slots on the cardstock and gluing to thin card from a box, cutting it out and gluing another slotted piece to the back of it. The handles will be shaped annealed steel wire and the hinges will be cardstock that has already been copied directly from the plans. The frames and badges will be antique gold by Delta Ceramcoat and the doors will be painted forest green like the ones below deck.
Many things are slow to change, especially if it works well.
- 508 replies
For small lines like that, I have used sewing thread treated with beeswax, or with thinned down PVA glue added after installation. For small lines that don’t have attachment points and you don’t want tension on, I have prestretched sewing thread on a building board and treated it with thinned down PVA glue, before cutting to length and installing. Both methods have worked well for me in the past.
HMS SUSSEX by KarenM - FINISHED - 1:48
GrandpaPhil replied to KarenM's topic in - Build logs for subjects built 1501 - 1750
Congratulations! Very well done! -
How to measure masts for Sovereign of the Seas
GrandpaPhil replied to Andy Whincup's topic in Masting, rigging and sails
Which plans of the Sovereign of the Seas? -
Congratulations! Very nicely done! Excellent work!
- 589 replies
- le gros ventre
- cargo
Thank you all for the likes and for stopping by! This round of deck fittings is complete and it is time to start making the bulkheads for the ends of the decks. I have all the pieces for them printed out and glued to card, so I just need to print them out and paint them. The plan set came with the decorative friezes already printed out that would have come with the kit. I do not have the painting ability that some of you do, so I believe that I will use them because I believe that it will look better.
French Pre-Dreadnought Battleship Carnot
GrandpaPhil replied to dgbot's topic in Nautical/Naval History
I have been on a late 19th century binge lately. The binge started with the Solferino (1860), one of two modernish battleships that were designed for a full broadside, and has expanded from there. The Solferino’s hull was pierced for 96 gunports. Only 55 were used as gunports, the rest were windows. It is possible that the things that look like gunports on the Carnot were intended to look like gunports, but were actually windows, like the Solferino. I have no idea why the French Admiralty would want a ship to look like it could deliver a full broadside after turret ships had obsoleted them, but it is a possibility that that may have been the intent.
