GrandpaPhil
Everything posted by GrandpaPhil
  1. Proof of concept/prototype for the first grating: It still needs cleaned up and painted, but that will do just fine. This set of plans is very nice. The trick for the plan sheets for the brass photo-etch is to just photocopy onto thin card and then cut them out. I made the mistake with the gundeck and orlop deck gratings of cutting out the pieces on the plan and trying to glue them to card. It didn’t work too well. But, this is working just fine. It is fundamentally the same thing I did with the windows I made earlier. It’s a little tedious, but isn’t everything in this hobby, lol? That’s part of why this hobby is so relaxing.
  2. All decks are planked and the forecastle deck is sealed. I’m actually a little farther along with the model, but I haven’t paused to take pictures. I’m currently working on cutting out the rest of the pieces that I traced out and prepping the grating pieces and trim pieces that I copied on the thin card. Those are going to either get layered onto other card after I carve the details into them, or get glued down to wood and then carved. Thank you again to this wonderful forum for that carving group project. It was immensely valuable to me. Sometime in between, I need to make 2 ladders and get the hatch pieces finalized, to include the aforementioned gratings.
  3. Making progress: I already made a lot of the deck fittings, so I’ve been adding the hardier ones as I go. The forecastle deck is glued in place because I need to cut the bulkhead tabs off flush with the deck and plank over them like the quarterdeck.
  4. Thank you very much! Working on the next round of fittings: Looks like a mess, but it is more organized chaos, at the moment, lol. I am painting the underside of the forecastle deck. The knighthead will be installed prior to installing the forecastle deck.
  5. They look like timber heads or bitts to me, or something that fulfills the same function. They could possibly be tie off points for oars or sweeps as well. Possibly dual purpose?
  6. The quarterdeck is planked and all remaining deck beams are in place: I traced out the next sets of parts. So, those will be copied in the near future and glued down to cardstock. I got my Orel Vasa in the mail today. That will be fun to modify and build up in 1/64 scale. I have 4 Orel kits now. I have a Seahorse De Zeven Provincien coming too. That will be my first Seahorse model, and it will also be used more as templates than an actual kit. They will all be a lot of fun to build up.
  7. Thank you very much, Patrick! The stern piece is done and in place: The planking of the quarterdeck is about a third complete: The Revenge is proceeding nicely. This is by far the most complex project that I have ever undertaken. I am learning a lot and having a lot of fun.
  8. The quarterdeck bulkhead pieces have been trimmed off: Working on the stern windows: It is a two step process. I copied the window pieces twice. Once onto regular paper and once onto cardstock. I am using the regular paper to make the lattice by cutting out all the holes with a scalpel. I am making the window frames from the cardstock and then gluing them together. The finished window looks a lot better in person than in the pictures. There are three across the stern. I have two to go.
  9. Here is the main deck with the beams for the next decks in place, with the lanterns: Here’s the quarterdeck glued in place: I’ll finish the transom piece with the stern windows and add that shortly.
  10. I photocopied the plan sheet for the brass photo etched sheets onto thin cardstock. I sealed both sides of the cardstock sheets at the parts I am going to use. The pieces that would have been thin brass, I will most likely just cut out and adjust as needed, like the lanterns above. The pieces that go to door frame mouldings, the quarter badges and other trim pieces, will be fully glued to wood and be carved as appropriate. The cardstock should reinforce the wood pieces so they don’t split out as they are being carved.
  11. Check out Grainger. They have good stuff and their prices are usually decent.
  12. The main deck is made and in place now: The gundeck is now completely sealed in.
  13. The majority of the gundeck is sealed in now: I realized tonight, that you would have to boroscope the model to see all the detail work on the gundeck now, to say nothing of the orlop deck, lol. This is the first time that I have ever made a fully enclosed deck before.
  14. The gundeck is nearly ready to be sealed and then closed in: I will add the final gunport sills after second planking the upper part of the model.
