SIDEWAYS SAM
Posts posted by SIDEWAYS SAM
- Schubbe, Edwardkenway, marktiedens and 4 others
- 7
Haven't posted for a while - been fixing the first planking. There is a lot of it.
For light relief have been working on the stern piece.
Attached photo's show cabin rear walls. Extra coat of yellow ocre needed
Next is the balustrading and lower stern piece.
Also the hull planking. Starting to question the wisdom of double planking.
There is so much of it.
Impressive work Tim.
The furled sails are superb.
Overall a very high quality build.
Sam.
Hi Tim,
Looking forward to seeing Bounty finished.
Will be watching for the start of your next build.
Keep safe,
Sam.
Hi Catopower,
Thanks for the info and interest shown.
Before starting this kit the earliest build I attempted was HMAT Bounty, 1783.
Before this I kept to the 1790 - 1815 era.
So I assumed the odd difference was due to advancements in building technique
between 1733 and 1750 when she sank and later building practice and design.
I have already deviated from the plans provided and intend to treat the poop deck
very differently also. This build will end up as a generic model and will be un-named.
Also, should you be on the poop deck puzzling over the weird arrangement and,
someone shouts "dinners ready" don't rush down the ladders to the upper deck
because someone left a cannon at the bottom of the stairs. Looking at the height of this cannon port
above the deck it could only be used against low flying aircraft and would probably be stored elsewhere.
I used the ply piece supplied in the kit to locate this port and now wish I hadn't.
After all that, I am enjoying this build and it will end up an impressive piece.
Regards,
Sam.
- marktiedens, BobG, ccoyle and 1 other
- 4
Thanks for the likes and, your comments Catopower.
Post one of this thread shows how the kit arrived.
Six boxes of various sizes all assembled into a stout cardboard sleeve. This was plain, no markings.
This was placed inside a thin highly decorated cardboard sleeve.
You are right Catopower, I have found a website (D'Agostini) who sell all sorts of kits
especially the full Occre range. You can buy these in stages or, as a full kit.
I bought my kit from Cornwall model Boats (as a complete kit) during the pandemic.
Now I realise that this can be bought in stages the instruction book makes more sense in it's layout.
First thing I did on receipt was unpack to make sure it was all there and then stored it all
in one box, AL's HMAT Bounty kit box (which luckily I didn't throw away).
Thanks for the imput.
Sam.
Steering gear assembled and rigged. Dry fitted for photo's.
Permanent fix before poop deck fixed due to limited access.
Instructions seem to be written to suit supply of parts in stages.
Probably explains why the kit arrived in six boxes.
Spending a fair amount of time moving back and forth through the instructions.
Getting it correct most of the time.
Sam.
- catopower, marktiedens, kirill4 and 2 others
- 5
- Edwardkenway, marktiedens, catopower and 1 other
- 4
- coxswain, Edwardkenway, puckotred and 1 other
- 4
- marktiedens, puckotred, coxswain and 2 others
- 5
- puckotred, goetzi73, Edwardkenway and 1 other
- 4
- marktiedens, Edwardkenway and BobG
- 3
- Edwardkenway, BobG and marktiedens
- 3
Thanks for one of the best build tutorials on the forum.
Best wishes for the holidays,
Sam.
Gangway blanks fitted and edges trimmed. These will be reduced in height to suit the deck planking
after planks are fixed. So lots of work over Christmas.
Second photo shows replacement columns.
Supplied by Cornwall Model Boats. Ordered on line early afternoon and delivered the following morning
slightly more than 20 hours later. It helps that they are just up the road from me but still impressive.
The next build stages should go more quickly, will be using kit parts and stock items.
Sam.
- Edwardkenway, marktiedens, goetzi73 and 2 others
- 5
Thanks RMC for an outstanding build.
Been a pleasure watching this.
Sam
Thanks for the comments Mark and, everyone for the likes.
This kit is turning into a sturdy well designed build but treat the instructions as a guide only.
Compared with some previous kits the main framing needed very little work
but Oh, that plywood is still a problem with me.
Your build and Sferoida's show the end result is worth the hassle and extra work.
Sam
Upper gun deck finished for now and waist gangway beams fixed.
Read Mark Tiedens post ref the gangway supports and, the instruction book supplied.
Agree 100% on the columns. (Replacements on order).
Will not be following the supplied instructions but will also go for one continuous beam
which will also cover the edge of the false gangway and the edge plank.
Occre's approach is to provide plywood where ever possible and, where seen - paint it red.
I'm trying for a more natural look. Mark's paint job is superb but I can't re-create this quality
hence my reliance on stain and varnish.
Cannon barrels will be removed, blackened and stored for later.
- sferoida, goetzi73, marktiedens and 3 others
- 6
Nuestra Senora Del Pilar by Sideways Sam - OcCre - 1:45
Thanks everyone for visiting and comments.
Upper deck shot garlands fitted.
Replaced instructions with something neater.
Highlights will fade when the varnish dries.
Sam.
