Everything posted by grsjax
Hi I have some quava drying now. What type of quava are you using. Here in Hawaii we have several varieties of quava some with very different qualities. What I have now is white quava which looks to be very good. There is also yellow, red and strawberry quava. The last is really hard to season. Seems no matter what I try it splits badly.
Shopping on eBay: A Primer for Newbie Ship Modelers (Parts 1 and 2)
grsjax replied to ccoyle's topic in Wood ship model kits
Another good site for finding books is bookfinder.com . I have found some very good deals on rare/out of print books there. -
Need help with saw blade output
grsjax replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
How fast are you running the wood through the saw? If you are moving to fast it can result in poor results. Try moving the piece forward at a slow pace, experiment until you find the speed that works best. A dull blade could also be the culprit. -
Hobby/micro drill press suggestions
Another thing you can do to make the Dremel drill stand better is to fill the column with something to stiffen it. A wood dowel of the right size or poring in epoxy thickened with sawdust will do the trick. -
I find the Dremel drill press stand adequate for 90% of the drilling I need. Bolting it down to a solid surface helps. For the more precise work a small bench top drill press is the way to go. -
I would go along with the suggestion of using poplar. It is usually available from the big box stores, is fairly cheap, harder than bass wood but still works easily and looks good. As for slicing up the wood you might want to invest in a hollow ground planer blade for your table saw. With care you can get very thin sections using a planer blade.
Oscillating Wonder Cutter
grsjax replied to Jim Rogers's topic in Modeling tools and Workshop Equipment
This is a startup that isn't on the market yet. Claims it can cut soft material like leather. This is a link to their Kickstarter page. -
Newbie with a few tool questions....
grsjax replied to CPDDET's topic in Modeling tools and Workshop Equipment
For a kit like the MSW Bluenose you wouldn't need a lot of tools. Bare bones would be an xacto knife with a No.11 blade (get extra blades), a razor saw, large and small tweezers and sandpaper do most of what you need to do. A few other tools are nice to have like a couple of needle files and maybe a miter box but arn't necessary to complete the model. Look over each step in the process and determine before hand what tools are going to required. Have fun. -
There is, or was a company called Woodkrafter that makes simple model ships for kids. Don't know if they are still in business.
Ship stand
grsjax replied to Snow's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Brass spacers used in lamps can make good ship stands. They already have a hole through them so simply running a screw up through the base board, spacer and into the keel makes a solid stand. These are links to a couple of lamp part supplier that sells them. You can usually find good ones for about $5 a pair. https://www.grandbrass.com/category/necks-cast_brass_necks/necks/ https://www.antiquelampsupply.com/lamp-parts/couplings-loops-hooks-swivels/couplings-armbacks-necks-swivels-spindles -
Recommendation
grsjax replied to Jaeon's topic in Building, Framing, Planking and plating a ships hull and deck
Thanks for the kind thoughts. Luckly we are in a spot that doesn't flood and can last for several days if the roads get cut. Biggest problem is going to be power outages. If a lot of lines go down we could be using candles for a week or more. Makes doing fine work very difficult. -
Recommendation
I would sand it to fit. Others may have different advice. -
I have been looking at the Master Korabel kits. Just wanted to try a simple small scale boat first and the Falkonet 6 oar boat looked like a good bet. Already ordered the Falkonet kit. Figured if Model-expo was selling them they must be legit. Live and learn.
Brass - Shining Small Parts
grsjax replied to Koa4225's topic in Metal Work, Soldering and Metal Fittings
If they are not to delicate they can be polished in a tumbler. A kids rock tumbler is perfect for this. Use a fine medium like ground walnut shell or corn cob with a shot of liquid polish like Brasso. The finer the medium the better the result will be. Add a shot of Brasso or other liquid polish to the medium. Don't use the grit sold with the tumber, much to harsh for brass. Put everything in the tumbler barrel and let run for 30 minutes or so. Take out one of the parts and check the state of the polish. If it needs more time do it in increments of 10 minutes or so. After it looks good rinse with acetone and let dry. -
Good advice. A make do alternative is a hot attic. Don't know what your weather is like there but if attics get hot then you can sticker the boards there and get some dry wood. Down side is you can't really control the moisture levels very well.
- 28 replies
- construction
- models
(and 3 more)
Thanks I think I will go ahead and order one. I will put up a review of the kit.
Any reasonably hard wood with a fine, straight grain can be used for most parts of a model. Best to pick out your own pieces if you can to get the best results. That said some woods are better for some purposes. For a general all around, low cost wood go with basswood. Poplar is also a low cost alternative that is a little harder than basswood. Not the best woods but pretty good. I like cherry for most purposes but it doesn't seem to be the best for steam bending. Apple and pear are good for just about anything. Black walnut is excellent if you can find good pieces with out wild grain or knots. Maple is good for the backbone of the model and decks but get wood with a fine grain, not the typical stuff you find at Home Depot. Boxwood is an excellent wood for everything especially carving but it is expensive. There are lots of woods that can be used in modeling and they don't have to be the ones found in kits or from wood suppliers. I find that aracantha, dogwood, gardenia, plum, lemon, lime and other woods I find available around here work just fine and are usually for free. You do have to season it and mill it yourself but it is easy to do with a little practice. One last thing. Don't buy wood from sources in China. What they label as cherry, walnut or boxwood has only a passing kinship with the real stuff.
- 28 replies
- construction
- models
(and 3 more)
