Tony Hunt
NRG Member-
Everything posted by Tony Hunt
Here are a couple more pictures to add to this story. The example of coppering is the bow of the clipper Snow Squall, now on display at the exclellent Maine Maritime Museum. Nearby was a fascinating exhibit, seen in the second photo, showing a machine used by the shipyard to pre-punch the nail holes in the copper sheets. The sheet is put in, the lever is pressed down, and presto, out comes the sheet with all the holes pre-punched. I'd never seen one of these before!
I bought one of their drill presses a little while ago. I haven't used it much so far, so no in depth experiences to share yet! First impressions - it's true, it's a bit of a toy, but it is well-made and works quite precisely. For small work I think these machines probably work quite well, for the money. But don't expect to be milling steel with it! Wood and plastic, sure, small cuts. Aluminium maybe.
I love the gratings at the stern! This is going to be an exquisite model of a very beautiful ship.
I remember reading the articles Harold Hahn wrote for Model Shipwright magazine, MANY years ago (!), about building his model of the Oliver Cromwell, and being awed by his superb craftsmanship and his skilful use of differently coloured woods to build a beautiful model without using any paint. You're doing an amazing job of matching his standard!
- 969 replies
- hahn
- oliver cromwell
The steamed Swiss pear that lots of specialty modelmaking wood suppliers have is very reddish and very fine-grained. Harold Hahn used it for the inner faces of the bulwarks on his model of the Oliver Cromwell for that reason. I think it would be a good mahogany substitute, you should be able to get it in veneer sheets or scale lumber dimensions.
Like Clipperfan, I recently visited the Mystic Seaport and got to admire Ed's wonderful model of Young America. It's even more impressive in real life (which is really saying something!) because of the fine scale - the detail and sense of grace that he has achieved at 1:72 scale is amazing.
- 3,618 replies
- young america
- clipper
I think Howard Chappelle redrew this plan and published it in one of his books - probably The American Sailing Navy?
Topsail schooner sail plans and rigging
Tony Hunt replied to Dr PR's topic in Masting, rigging and sails
Dr PR, I agree with all you've said too! There were so many variations on the theme, it's impossible to name them all, and yes, many nautical terms are used interchangeably. Especially in different regions that have different traditions. I think my main point is these schooner courses were running sails, set when the wind was coming from astern.- 104 replies
- schooner rigging
- Topsail schooner
Hi Ian Nice to see another Australian researcher here! My main interest is pearling luggers, but I've spent a fair bit of time on the Australian merchant schooner fleet too. And various other things - easily sidetracked, I am. 😀 On the subject of courses on schooners, and the rig of schooners vs brigantines, I've always been of the understanding that schooners don't carry courses, in the true sense of the word. I understand a course to be a permanently-bent part of the suite of sails on a square-rigged mast. They are typically wider than they are deep, which means that they have relatively short leaches. This allows them to remain set even when the ship is sailing into the wind, with the weather tack hauled forward by the bowline to keep the weather leach taut. The foremast of a brigantine is primarily a square-rigged mast, with the lower mast rarely more than ~30% of the total height of the mast. By comparison, the foremast of a schooner is primarily a fore-and-aft rigged mast, with some square sails added, and the lower mast is relatively tall, usually at least 50% of the total height of the foremast. For this reason, the lower squaresails sometimes set by topsail schooners are almost always much deeper than they are wide. This means it would not be possible to have the sail set acceptably if the ship was beating into the wind, as the long leach would inevitably twist and flutter. Spinnakers have the same problem on modern yachts. Consequently, these square lower foresails (for want of a better name!) were only ever used with the wind coming from abaft the beam - i.e. as running sails. On schooners, the primary sail on the foremast is the fore-and-aft sail, either a gaff foresail or a staysail if it's a staysail schooner. On references, my favourite schooner book is Basil Greenhill's two-volume work, The Merchant Schooners.- 104 replies
- schooner rigging
- Topsail schooner
I love a puzzle, and those are really intriguing images - both paintings and photographs. In some of the photos the forward end of the line appears to be attached to the outside of the hull approximately at the line of the deck edge? I've no idea what they could be for. Fascinating! PS - I like Jim Lad's suggestion. Better than anything I could come up with!
I suspect the top-down view (plan view) may be drawn at the level of the deck (i.e. the top of the wale), not the level of the sheer strake. Hence the discrepancy.
- 139 replies
- ancre
- Bateau de Lanveoc
Gotta love a single! Interesting wheel configuration, alloy front and wire spoked rear. Don't see that often. I think the headlight might need a new globe, too! 😃
