mikegr
Posts posted by mikegr
- yvesvidal, mtaylor, thibaultron and 1 other
- 4
One evening one piece.
I decided to work on the main mast. While assembling the PE part it came obvious that while it was detailed, the tripod was too thin, more of a 2d shape. And since Ticos have a reinforced mast like Spruance class I decided to work on the original part.
Work begun on SPS Radar. While holding the arm with tweezers and trying to attach the radar, it twisted and bended. I took another set from my spares, but proved very delicate and broke after a slight bend. Perhaps If i could use 10 sets I could have damaged all. An attempt to glue them failled, still looked wrecked.
So basically I took the arm of the plastic piece and add the main radar plate on it. It was the best solution I could think after all other options have failed
- thibaultron, king derelict, Baker and 4 others
- 7
- Old Collingwood, mtaylor, Canute and 4 others
- 7
The PE are good but they don't have instructions.
The fit the heli deck properly I had to remove the hangar. I removed the side deck pieces and worked on them. Added doors, handrails and removed moulded life raft barrels. I will replace them with my own one. Sided pieces were joined together. Need to add boat facilities and other minor details. Main deck was painted with faded dark grey and hull sides with primer
16 hours ago, king derelict said:
Great haul Mike,
Looking forward to more excellent builds
Alan
thank you ,
hope you get a satisfactory result with your challenging project
Thank you OC. The last and most difficult bit coming up - the bursting wave. I think I am going to retreat a bit and get the two Flowers moved along a bit first. I think one of them will need to be fixed in place for the final bits. So far its turning out better than I hoped and I am continuing to learn
Alan
You may consider using snow paste. Ready mix or home made. I use ready one since I bought it but hand made is superior because you can adjust the texture from coarse (usually on waves top) to smooth(wave base and around)by adjusting the portion of baking soda. When dry, you can add silicone bits with a toothpaste to increase the water splash effect.
On the right wave I used hair blower on hot so the wave get more foamy because of the baking soda
Regardless the chosen method you should lightly airbrush white around areas where foam will sit, to make smoother the transition from white to dark ocean color
- king derelict, Veszett Roka, Baker and 5 others
- 1
- 7
If you consider using cotton and gell for waves make sure the latter is of those that will not get yellowish over time.
Personally i consider cotton as an emergency solution as its white color is not white enough, just compare it to white acrylic and see the difference
- Canute, mtaylor and Old Collingwood
- 3
- KeithAug, GrandpaPhil, Canute and 2 others
- 5
- Canute, Bill Morrison, uncarina and 1 other
- 4
2 hours ago, patrickmil said:
Thank you!
Apparently there are quite a few upgrades coming out for this kit now. When it's all said and done, I'm willing to bet the cost of all of the upgrades will far exceed the cost of the kit. That said, the upgrades appear to be very detailed.
Some modelers report 300$ on upgrade parts for a 50$ kit.
Though I do not count my spendings, I cannot cope with that
- king derelict and Canute
- 2
- Old Collingwood, Canute, FreekS and 4 others
- 7
11 hours ago, king derelict said:
Thank you OC. And now i realise that moving to 1/350 doesn't really make it easier. Its a bigger scale but now you can detail tinier elements. The braces for the venturis are absolutely tiny and there are ready use ammo holders for the 4 inch gun that are ridiculously small. I'm undecided whether to even try them If they escape the tweezers they will be lost forever.
Alan.
There is no cure. Whatever the scale there always will be tiny things that have to be worked with absolute precision. Its just the amount of work that differs like painting hulls in 1/200 instead on 1/700
- mtaylor, GrandpaPhil, Canute and 4 others
- 7
- GrandpaPhil, KeithAug, yvesvidal and 3 others
- 6
Next was the hangar. I printed the right half and made some adjustment to fit the PE externally. I made them in separate pieces so I can scratch built the interior more easily them glue them together. Like in Horizon class because of the side compartments for inflatable storage, the heli hangar is somewhat narrow.
- yvesvidal, KeithAug, GrandpaPhil and 3 others
- 6
Next was to print the central area between the hangar and the bridge where funnels and towers will placed upon.
However because of warping problems that I couldn't solve after many attempts, I removed it and replaced it with plywood wrapped with plastic fillets for a smoother finish. This handwork took me 2 hours instead of 2 wasted evenings, what a bitter lesson.
Fortunately the other piece, the main canon printed just fine and a barrel made of needle pieces was added along with hand rails.
- GrandpaPhil, mtaylor, ccoyle and 4 others
- 7
LPH-11 USS New Orleans by Spaceman Spiff - Iron Shipwrights - 1/350 - RESIN
sad that there in not a worthy kit of this class in 1/350 or even in 1/700
