Everything posted by Mirabell61
Thank you very much for your words John. its going to be a lot of work with the super structure..... Nils
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
thank you very much Denis, Nils
- 2,625 replies
- passenger steamer
congrats, a beautiful model Pat, Nils
- 517 replies
- Endeavour
- Artesania Latina
Nice progress Bob, also mast, loadboom and lanterns well done..... do you have rudder and props already ? Nils
- 348 replies
- pequot
- cable ship
Good morning John, I was this morning surprized by the number of visits to my log over night, and with pleasure noticed that you have had a good look into it. Thanks for your interest, much appreciated, you`re always welcome, and I`m pleased you enjoyed the tour. I`m trying to resemble a bit of the heritage touch of the turn of the century 1900 this ship brings with it, being a trend setting benchmark in mechanical shipbuilding in the year of launch 1897 Best regards Nils
- 2,625 replies
- passenger steamer
Thank you for your nice words Michael, thanks for looking in..... Nils
- 2,625 replies
- passenger steamer
Thank you very much Piet, for your nice compliment, much appreciated.... Nils
- 2,625 replies
- passenger steamer
Hi Alex, guess the technique you are using for the hull made in CNC milled sections and then fitted together is like the professionals do for "builders models", or for the watertank drag test hulls...... The models look fantastic !! Nils
thank you very much Pete, its nice that memories are brought to mind now and then. I grew up in capetown in the late 50 ties, and also remember taking the bus about 12 miles into the city just for looking into a large model shop there and what they had on display Nils
- 2,625 replies
- passenger steamer
Beautiful work Ed, your clipper build is a through and through sample of masterly model shipbuilding of the 19th century.... Nils
- 3,618 replies
- young america
- clipper
Patrick, thank you for your nice compliment.... Nils
- 2,625 replies
- passenger steamer
Bob, thanks so much for your nice compliment. I`m glad you like it.... I have now the cabin walls 18,5 mm high ( 18,5 x 144 = 2664 mm actual) , and just hope that later on it will not look as if too low, because the boatsdeck with it`s slight downward curvature to the ships sides will leave quite a lot of the promenade deck "in the shade" Nils
- 2,625 replies
- passenger steamer
Thanks Ed for your word, and also all the "likes" for clicking the button.... Update.... the first promenade deck cabin section is so far complete.... the handrails worked out fine, was easier than I thought it to be......, and this time the railholders had flattened ends before bending the holding loop for the rail was bent, (thanks to suggestion of member "Reklein", Bill in Idaho ) Nils
- 2,625 replies
- passenger steamer
Thank you very much Bob, I`m pleased you like it.... Nils
- 2,625 replies
- passenger steamer
Hi Patrick, thanks for nice compliment. I`ll be concentrating on the handrails next..... Nils
- 2,625 replies
- passenger steamer
Thank you very much Denis, yes, its quite time consuming with the metal foil. Whats a bit tricky, is to get clean round cuts through the foil where the portholes are, because the foil ca`nt be drilled. I use the sharpened edge of a tube with an integrated centerdrill where its centerpin stands out appr. 1 mm. Once the hole is centered and the foil cut through, its easy to drill the rest through the wood. Nils
- 2,625 replies
- passenger steamer
Thanks for your compliment Denis, I`ve been "riveting" the cabin walls and bringing in the holes where there come portholes. All tiny holes for the handrail stanchions have been drilled in. Also primering has been done and the painting for the four sections. The unpainted section shows what it will look like with doors and windows.... Nils doors and windows not permanently glued on yet... Handrails still missing.... the portholes shall look like those in the ships hull (metal sleeves with "glassing" from grasscutter 2 mm diam. Nylon line )
- 2,625 replies
- passenger steamer
David, good work ! , I like your attempt for the self made chain plates and deadeye stroppings Nils
Carl, thanks, yes, you`re right there is a vac, connection socket, I`ve never tried it yet because, the cleaner is quite loud, but I`ll do it next... Nils
- 2,625 replies
- passenger steamer
Hi Rob, had a look at your trials with the coppering...... if you wish, here is a tip.... my first Trials have been for the bin, but I would`t like to give up so easily. Some time ago member Dirk posted a very helpfull link out of that "mini sail Switzerland" assotiation relating to coppering. Together with B.E.`s Prior Input I started a new Trial with real adhesive copper tape. (Tiffany tape) It would in scale size 1:64 be necessary to place 88 to 125 nails per plate of size 6 x 19 mm. After some Trials I managed to place 88 nails, flattening the surface afterwards, and having the overlapping plates borderline-nails placed at half distances compared with the the main field. Unfortunetely the staggering of the nail lines in the centerfield is beyond my possibilities in this scale. The reproduceabilty is given due to the embossing Tools I made. The sample here shows the "Tiffany Tape" coppering of the HMS Pegasus with 88 nails per plate, nail surfaces flattend down after poncing. The poncing is done with two different wheels. The 3-disc wheel is used for the larger sized inner field, oin order to obtain a better regular structure. Of course I could have bought the plates, but I wanted to see if I could do it selfmade and in acceptable way. Nils
- 1,208 replies
- great republic
- clipper
