Mirabell61
Everything posted by Mirabell61
  1. Thanks very much John, learnt something new again, much appreciated, "lifelines" such an easy word......, also the function of the grab lines makes sense, when trying to righten my sailing dinghi once, standing on the keel I nearly broke the wooden swing centerplate by sidewise hanging my weight to it`s full length standing up, wish I had grab lines there... For these small resin boats I give it a go for a trial on a scrap part with the lifelines and the seine floats attached, quite a weary process, but I trust the optic will be worth the effort afterwards. For the closed boats the canvas cover may be partialy hiding some of the lifelines Nils
  2. A beautiful built coach Danny, you managed to build it in a remarkable short time, excellent performance ! Nils
  3. Thank you much Kees, Carl and John, for your nice words... Kees, in the beginning it was a little strange to work with silicone and resin, but now have addopted this procedure in my repertoir.... Carl, I presume that the foldable boats will be single production and then stacked, might be easyier to produce John, thanks for catching up, you`re always wellcome... As I already learnt a lot of english terms from you already, please may I ask, if the halfmoon like handle ropes (for people in the water) around the boats are called "grab ropes", or if they have a special term ? Nils
  4. Very nice gun cruiser Tozbekler, so many fine details, it looks great... Congrats to the completion, a beautiful build... Nils
  5. thank you very much Gerhard and Carl, a little bit of experience could be gained with the use of silicon and resin for the fist time, so if boats should be required again, there could be some optimizing of the process. There are still tripple stacked foldable boats (last in the row on both ship sides), but I have to do a master boat set first.... Nils
  6. Update : here, the first one of the raw open boats. I think I`ll place one or two open boats later on each side of the ship...., most of the others will be closed and canvas covered boats Nils This is the same silicon mold as for the closed boats, but here additionaly a plug is inserted and fixed in position, before the resin is carefully poured in.... The result out of the silicone mold... and after pulling the plug out the two halves are glued together and the decking cover is milled out with a Dremel seatings a bit broader and thicker, capacity, when full occupied 26 persons
  7. My thanks go to Rob and Bill, and all fellow members who gave their kind input, suggestions and comments for boats making... recently Also thanks to all the "likes"... Rob, good idea with the vibrating palm sander, I must try that, and save in mind..., I was already thinking of what I possibly could use exactly for that purpose... Bill, the additional plug still requires some corrections, but I think in general it should work as intended. After glueing the halves together I will remove the center area of the halfmoon like top cover until only the rail on the sheer remains standing. Here in the white sample there is no inner bulwark support, whilst the translucent sample was made from the modified plug with 8 slots to resemble the ribs... Nils halves ready for fairing sanding the to be matching glue surfaces here 5 completed boats The upper sample with reinforcement ribs the additional plug for hanging / fixing into the silicon mold now that it works, the other side of the plug will also get outcuts
  8. Hi Bill, Thanks for looking in.. I also thought that the work time was far too fast (laying at 2 minutes only), at mix 1:1, so I declined the catalyst share step by step, and now have a work time of 1/4 hour, but the resin will take appr. 3 hours to cure out. Ventilation.... the molds all have their open side to the top and vented over the top surface. When using the additional plug, there might be some small horizontal, but slightly tapered surfaces that could trap some air. I`ll check tomorrow morning, as the resin is still curing.... Nils
  9. Yeah Rob, its amazing what a little more seperating wax can do in the critical areas.... Meantime I faired 10 halves and glued these together,......result : perfect fit on 5 boats, I`m very pleased. I do`nt know yet if the open boat will come out the mold properly, as I`m working there with an additional plug for the interior..... Nils Nils
  10. Hello Doris, I was missing your posts over the last months and hope you may find time again to share your brilliant work with your MSW fellow members. I am with Druxey and Michael with my compliments and gladly look forward to your progress with this new project. Es ist wunderbar ! Nils
  11. Thank you very much Piet, I`m pleased you liked the engine room pics (bringing back steamship operating memories). I was myself surprised that the engine room crew had no objections in letting me down into the engine room, also through a tunnel in the coal bunker, and right before the boiler furnaces.... With the "closed" boats reproduction I`m quite pleased with the result so far. I`ll give it a try for the open boats as well, perhaps it may take several trials, in order to find out the critical points of the procedure, Thanks for your input on the possible help for peventing tearout on those "canvas cover" details Nils
  12. Carl, many thanks for your appreciative words,... the first casts unfortunately show some places where air bubbles had been trapped especialy in the fender rope region, but that could be solved with applying a little more seperation wax there. In all I`m also very pleased with the detail reproduction, I thought it would be more complicated... Nils
  13. Thank you Greg, for your nice words and that compliment... there is really a mass production of boat halves going on right now, the first boat (halves) are glued together.... Nils first boat "cloned" (next to the master boat)
  14. Wow B.E. what a lovely display, and that beautiful casing. Love that little side table she is standing on. Congratulations to your wonderful rounding up of the project, an awsome looking piece of maritime art... Nils
  15. Update : further with boats production....... It is my first attempt to make parts in silicone molds and to cast them out in polyurethan resin. I`m quite satisfied with the result so far, and pleased that it worked out so easy.... Here a little documentation to share of the procedure (to whom it may concern) Nils making the boxes for the silicon molds, comprising baseplate and side walls positioning the master model (halfside by halfside) into the box frame, holding it in place with a simple but adjustable support device checking the horizontal centerline position.... two component silicone mixing relation 1:1, for the mold seperating wax for the mold the first mold half in silicon, the master inserted slightly more (0,5 mm) than half deep removal of the master half..., the lapstrake structure and even the fender-rope mold out well and precise two components othe polyurethan resin and its catyliser (mix 1:1) casting three halves at a time. The activated polyurethan resin has a working time of appr 2-3 minutes after mixing the two components together, before it starts to polmerisate and to turn to white coler as it does so the result of the first attemt to cast the boat halves, now ready for fairing, trimming. The activated resin batches (every batch at a time) is measured for 5-6 boat halves
  16. Many thanks Greg and Igor, for your kind comments.... Greg, yes, I was very pleased especialy to stand next to the men in the boiler room shoveling coal into the furnaces, and also to watch the engine crew obeying the machine telegraph, reversing the engine (mighty "Stephenson reverse device") at work Igor, am pleased you liked the Photos...... I tried in vain to add some videos, but they were much too big for posting (appr. 30 - 60 MB) Nils
  17. Part 2 most of the ships carried guests Original steam winch entering the machine room, here the tripple expansion steam engine cylinder covers (2200 Psi) machine control stand a look into the crankrod section the machine telegraph receiver gave orders every few minutes, was continuiously in action, here a young lady is driving the engine round about midnight, a shot at the bridge deckhouse and finaly arrival back to the point of departure at 01:30 past midnight Nils
  18. Short excursion to Hamburg Harbour... Some 50 Km from my home.. Yesterday evening my wife and I had an invitation to take a river trip with the live museum steamer and steamship-icebreaker, (built 1933) "Stettin" on the Elbe river. This weekend was the 828 th Hamburg harbour aniversary, and the ride went from 21:00 to midnight. It was rounded off with a beautiful firework over the harbour, and to be watched from board the ship. The selfmade pics I would like to share with MSW fellow members in two parts.... Nils Part 1 Maritime museum pier at Övelgönne for traditional ships and work boats, (Elbe river This is the stem powered icebreaker "Stettin" at the river mooring ponton The "Aida Prima" cruise ship passes by The ship hull, all structures and interior make a very good impression Bridge Machine telegraph I had the chance to be down in the engine- and firing room at the boiler furnaces during departure. The sight of the steam engine at work, the reciprocating piston rods, crossheads and cam levers in live action was just amazing and wonderful. The orders for the machine control came down per machine telegraph, the accompaning "ring, ring" was continuosly heard in the background Bridge wheelstand with rudder position indicator and compass Other side of the river was the container terminal, and during the ride many types of sailships were busy on the stream.... to be followed by part 2....
  19. Beautiful done schooner Peter, I love the boats, they look real good, in fitting out and in scale. You mentioned in one of your posts .... the raw boat and the finished boat, just a question, if I may ask, is the raw boat made as resin cast, and what source are you using for it ? Nils
