Everything posted by SkiBee
I've just been using the rigging lines that come with my kits. It appears that most of the lines are Nylon. What are the different types of line? I've heard of Cotton, Nylon and Polyester/Cotton blend. What is the best type of line and why?
Sanded the edges off the blocks but did not shorten them. Broke a few wires as I was twisting to make the wire tight around the blocks, but had enough wire. I left the hook loop unfinished until I threaded the wire in the brass eye. Making the sails was very similar to the Norwegian Pram. I used water thinned Mod-Podge which is very similar to white glue if not the same material. Ended up with some pencil lines which don’t look so good. Also, might have used to much Mod-Podge, the sail is very stiff, will have to wait and see. I also don’t think I should have tied the brass mast hoops so close to the sail as well as the sail to the gaff. Completed the running rigging on the mast and starting to make the standing rigging. I wish I would have waited to after I put the standing rigging on the mast before I put the upper gaff block so I could have made the standing rigging eye off the mast.
- 61 replies
- muscongus bay lobster smack
- Finished
First, I’m a beginner too and you’re doing great on this build. What’s the old saying, “we learn from our mistakes.” Instead of the Muscongus Bay Lobster Smack by Model Shipways look at the Model Shipways 18th Century Long Boat. I built the Dory and Pram like you did, and then I built the Long Boat since the Lobster Smack wasn’t available. I learned a lot from the Long Boat and the instructions were SO much better than the Lobster Smack or the Pram. The Long Boat has a great schematic that showed great details. The planking on the Long Boat was better for a beginner than the Lobster Smack. The Lobster Smack planking has a tricky aft end due to the complex curves and bends. So far my two favorite builds are the Long Boat and Dory. I’m finishing up the Lobster Smack now and it’s my least favorite of the four. I’ve learned a lot and some past learning was reinforced by the Lobster Smack. Take a look at the Model Shipways Muscongus Bay Lobster Smack build logs that exist on this Web site before you choose your next build.
- 160 replies
- Model Shipways
- norwegian sailing pram
Well after a break of over 2 months, I’ve started back on the build. Installed the rudder and tiller without too much problem. I did make the tiller out of thicker material than the kit, it was just too thin and flimsy to do anything with and I did not want to go through the trouble of doubling it. I had better luck at this mast, boom, gaff and bowsprit; at getting them round than the Norwegian Sailing Pram. The dimensions of my mast were not the same length as the drawing but it should work without a problem. Small goof, I stained the mast, boom and gaff prior to installing the stops. Had to make two small stop cleats for the gaff since I could not find any on any of the sheets in the kit. I used cyano to glue the bowsprit on, had to glue the aft end first then bend the bowsprit a little to align with the beakhead. Drilling the holes in the two brass chainplates was a challenge, even after annealing the brass strip. Need to find some stronger drill bit tips that will cut through brass better and quicker. I painted the cleats and turnbuckles brass with some enamel model paint, had to let them dry for over 24 hours before gluing them on. On to the mast hardware, making the blocks and sails.
- 61 replies
- Finished
Great job, have one on me before you start another ship.
- 52 replies
- Model Shipways
@Retiredpm Great job. I regard to the oars, they look good and the only way to get them round a this point is sanding. Just be careful not to put to much pressure while sanding, they break very easily.
- 12 replies
- Model Shipways
- Lowell Grand Banks Dory
My coaming look just like yours, but I glued it in and used a little filler to smooth it out an it looks good now.
- 52 replies
- Model Shipways
Also, note that the brass rod to raise and lower the centerboard is missing now. It came out while I was painting the model and I couldn't get it back so I just left it off and filled in the slot on the deck for it. I also used Mod-podge to adhere the 'trail board appliques' to the trail boards, I had used this water down white glue to adhere appliques on my 18th Century Long Boat. In both cases it worked grate and dried clear. I did break one of the trail boards in half while I was sanding it.
- 61 replies
- Finished
I didn’t like the small gap between the coaming and the end of the cabin sides so I filled it in with putty. Also, I filled in the area in the aft part of the coaming were it had a tendency to crease. Put the cabin roof on and the access hatches on and then sprayed with a matte clear coat. Now I will move on to shape the mast and spars. Waiting on the replacement sheet that has the rudder and tiller as well as the right size of line.
- 61 replies
- Finished
Paint will cover all fills. Looks really great
- 52 replies
- Model Shipways
It took me 3 bending sessions for the Coaming and Cabin Sides so as not to break the wood. I started with a wide bend, then a smaller one, then actually using the model as a bending mold. The Cabin Sides worked out really nice. However, the Coaming kept wanting to bend at a 90 deg angle rather than a curve but I finally was able to get the curve. It took me a minute to figure out that the top of the fwd end of the coaming sat level with the deck since there weren’t good pictures in the instruction of this area and since a schematic drawing was not included in the kit. The real problem was the coaming would not fit level to the deck and the fwd starboard tab kept wanting to go below the deck level. The problem was the Coaming stopped when it hit the ‘seat back’, since the seat back stuck out fwd of the deck opening. I had to reduce the height of the seat back to the Coaming could sit lower. Also, I had to cut down the two starboard frames in the seating area to get the coaming to sit level. I also had to widen the space between the deck and the frames in the cabin area. I cut the frame to widen the gap for the cabin side to sit down in rather than the deck to ensure a smooth curve of the cabin side.
- 61 replies
- Finished
I glued the planks on the same way, just be careful not to push down anywhere but directly over a bulkhead, I pushed on some unsupported sections and that’s how I ended up with some depressions that I had to fill
- 52 replies
- Model Shipways
I’ve finished the hull painting; I painted the upper half a slight off white, mixing white paint with a little cream color paint. (My wife does a lot of crafts and has a lot of acrylic paints) I did paint the bottom of the hull Model Expo Hull Red, MS4968. I thought that the hull was a little bland so I painted the rub rail a Tamiya Flat Black that I had. For the first time I used Tamiya plastic masking tape and it was fantastic. I really like the way you can stretch the tape to make curves, the water line, or fit a curved piece, the toe rail.
- 61 replies
- Finished
After a couple of coats of gray spay primer and an off-white spray paint, I thought might look ok but did not like the color. Needs a little more work on the bow. Wet sanded to get some dust off and will start painting the hull later this week.
- 61 replies
- Finished
Finished filling and sanding the hull, there are still wavy and depression spots, but they are not as prominent. Hopefully, they won’t be very noticeable when painted with flat paint. Trying to decide what color of stain to use on the deck and toe rails. Will paint the hull off white and hull red.
- 61 replies
- Finished
@bobandlucy the key is to take as much time as needed to bend your blanks to match up so you don’t have to put a lot of pressure on them when gluing. Also, don’t put very much pressure on the plank where there is not a bulkhead behind to support, thus avoiding all the depressions that I ended up with, especially fwd and around the aft stem.
Current Projects:
Muscongus Bay Lobster Smack - Model Shipways - 1:24
Phantom New York Pilot Boat - Model Shipways - 1:96 {on hold until Lobster Smack is complete}Completed Projects:
18th Century Long Boat - Model Shipways - 1:48Norwegian Sailing Pram - Model Shipways - 1:12
Lowell Grand Banks Dory - Model Shipways - 1:24
The starboard side I sanded a little more then put the first coat of putty on to fill in the gaps and depressions. You can see that the depression at the aft end next to the stern post will need much more fill and smoothing. I think I should have sanded more to even the planks more, so that is what I did on the port side, I think it looks better and will result in a better job.
- 61 replies
- Finished
@cbeckenb You have done a fantastic job on planking!!!! Mine looks like crap compared to yours, well done. If you haven't solved your sheer stake problem yet, I would look at taking the total distance from the #9 plank to the top of the deck and divide by 2 to make two planks (a new plank 10 and a new sheer plank) to replace the sheer plank. Good luck
Finishing the Planking Finally, was able to get back to planking this past week and I have finally finished it. Planking this boat has been a challenge and my key recommendation to everyone is to take your time to bend the planks to help reduce gaps. The Sheer Plank, I had to wet the sheer planks a few times to get the right vertical bend as well as to form it at the aft end. When I was forming them one of the challenges was the top of the plank kept wanting to bend over the edge of the deck which made it difficult to get the plank to butt up tight to the other plank and not gap at the deck interface. My recommendation is to take your time and use some left over wood to keep the elastic band from bending the sheer plank over the deck, see pic’s below. Also, you can see the gap at the aft end that I finally had to hold around the aft end while the glue dried. Also make sure you have enough glue coverage on the deck edge to bond the sheer take to the deck. I then used my knife to trim the sheer plank down to the deck. As I was trimming the plank wanted to split along the grain, you can see some areas where the sheer plank dips below the deck a little which was caused by this split. Even being aware of the grain, I still had a few areas that dipped below the deck. Started to sand the hull as you can see the results of my initial rough sanding below. I would like to sand the hull smoother before resorting to using putty, but concerned of making the planks to thin. I will have to use putty to fill in at the bow and stern, see below. I’m going to rough sand some more and will upload pic’s before I start to putty the gaps and depressions.
- 61 replies
- Finished
