Bill97
Everything posted by Bill97
  1. Ian I used this panel line accent color with a tiny tip brush. kirill4 I think I am going to meet you in the middle for changing the color of the ratlines and running rigging. I could darken my tan thread I intend to use for running rigging on the sails. That thread is obviously not on the ship yet and I could use some recommend method to do so. However I think trying to paint all the running I have already installed would be much more difficult than painting ratlines. I would be further concerned about lack of uniform color and stray tiny brush strokes and droplets accidentally getting on ship parts. As a result I would have possibly two different colors of running rigging.
  2. Kirill4 you convinced me. Staining my ratlines. I have to admit I do like them better that way. However I am going to stay with the tan color deadeye lanyards to match the running rigging.
  3. All very good points kirll4. I will consider taking a small brush and applying a thin wash to the ratlines.
  4. Just out of curiosity I did some MSW research on the interesting question Kirill4 brought up. Pretty good discussion from a number of years ago.
  5. Of course kirill4 every time I look at your galleon I come away inspired by your work. Maybe my next build I will go darker colors. I have always thought of the deadeye lanyards as running rigging instead of standing rigging since they would be tightened from time to time like other lanyards throughout the rigging. Would that not be the case?
  6. Kirill4 the photos are a little deceptive. The lines you listed are not white. All of the lines that look white are actually a light hemp/tan color. Not as dark as some sold by model ship companies but also not as light as some sold by others. Since I began making my own shrouds and ratlines years ago I have always preferred a dark shroud and lighter ratline. I like the contrast.
  7. Main mast yards rigged with parrals, lifts, and braces. I have not secured the braces because it looks as if rigging the yards on the mizzenmast might be easier if I can temporarily move the main yard braces.
  8. Henry I will be anxious to see how your’s looks. Strange that Heller had the standing end tied to the base of the flag pole. I am moving on up the main mast now rigging the topsail and topgallant. Glad I have made my last parral. Not sure why, but I do not enjoy making them.
  9. I decided to go with a sheave hole through the bulwark next to the kevel in a place that does not interfere with the backstay or the cannon port. I took the brace through the sheave and belayed it to the kevel.
  10. I do have the unused (based on belay point diagram) kevel you see in the photo. It is on the bulwark on the next stepped down deck. Anderson does mention the belay point of the brace was sometimes on the next deck down. I think I will tinker with finding a good place for a sheve hole and tying off to the kevel. There is a mizzen back stay very near there I will need to avoid, as well as a round cannon port.
  11. I still need to come up with the best idea for the running end. On the Victory after it returned from the pendant block it passed through a sheave in the bulwark near the standing eyebolt and then belayed to a cleat on the deck. Other idea Anderson shows is having another eyebolt on top the bulwark near the standing eyebolt that the he running end would pass through and then to a cleat.
  12. That is how I rigged my HMS Victory and assumed the Soleli Royal should be.
  13. Main yard rigged with parral, lifts, and tye. Also tinkering with the braces. I need to read the section on braces in Anderson’s book. Heller has the standing end tied around the base of the stern flagpole. Surly that can’t be right? Is it? Seems a good stiff wind would simply rip the flagpole right off the deck and maybe kill a crewman.
  14. Oh my goodness Baker. That is exactly how mine looked before I adjusted them. It was not just the sag in the stay that bugged me it was the slight zigzag of the stay. That was the most troubling to me. Thought it looked kind of amateurish. But I guess maybe not. To adjust a third time to get the braces a bit more taut or just move on to the main mast? I think I will check the braces one more time to see if any have real visible slack. If so tighten just a bit. Then move in to the main mast.
  15. Henry I want to mention this to you in case you have not reached this point in your rigging yet. We moved that forward knight head a little to the right. In doing that we placed it in front of the center starboard side post of whatever (nautical term) that rigging fixture is so as to not foul the main stay. However when rigging the starboard side fore topsail brace it is supposed to belay to that now obstructed post. I just tied it to the cross member.
  16. Ian based on your comment I may adjust to add just a slight bit of sag to the stays for little more realism, or just leave well enough alone. Will give it some thought. Thanks again guys.
  17. I think I do have it a bit better than it was. I think I could tune a piano after that exercise! 😀
  18. Thanks Henry. I will loosen them up to get the stays more straight. Appreciate you so much my friend.
  19. I know this is probably more of a personal preference thing. I keep looking at the rigging I have done so far, especially the main stay and the main top mast stay. Maybe even the main topgallant stay. As I mentioned before I tried to reach a happy balance between the tautness of the fore mast yard rigging lines and the stays on the main mast. I just don’t know if I am pleased with the pull the rigging lines are obviously showing on the stays. Do you guys tend to lean more toward the stays being as straight as possible at the risk of a bit of slack in the rigging lines. Or, as I have, tolerate some bow in the stays to get all the rigging lined taut?
  20. Ian I had just said I was planning to add a combination of furled, partially unfurled, and fully unfurled sails. And that I was trying to decide on unfurled on the top gallant and graduate down to fully furled on the main and fore yard. Of course in the photos the top sail is fully set. I like the photo you attached above as well. Wonder if it would be alright to have the windward clew on the fore sail pulled up as well. To finish this topic I am going to either do it as above in your photo Ian or the previous photos. Thanks everyone for all your help.
  21. So Ian are you saying that I would not be nautically inaccurate if I rigged my Soleli Royal the same way? That was my original idea/plan that started this conversation. 😊.
  22. So guys I am looking at a build by one of the more familiar builders. He has several videos from which these photos were grabbed. From our discussion above, are we saying this sail arrangement is not nautically accurate? It appears not.
  23. Ferrus I could easily turn a new topgallant yard but I would also damage the topgallant mast as well. I really liked your idea but not if I have to do so much damage. Of course I could still display the sails that way and not move the yard if that is the way I want to display the model. As I have said before on other issues I have encountered “who would know, or care?” That is except you guys, and me, now that you are educating me 😊. I look at some of my older models in their case, especially my Revel USS Constitution which was my first when I picked up the hobby again after retiring, and I think if you guys had the opportunity to examine them I have no doubt you would find countless nautical errors. From then until now building this beautiful Soleli Royal right after building the Heller HMS Victory I have learned so much and become addicted to the craft. Each time I learn something new, and why that is so, it is like a new window has just opened. I never gave any thought to what would actually happen if a ship had just the topgallant sails unfurled as you explained Ian. That makes perfect since. Knowing that now and the physics of it is enlightening. So now I have the decision. Do I want it to look “cool” but down deep in my soul know it is nautically WRONG, or do I display the sails correctly, which will also be stunning?
  24. Unfortunately even though I rigged the yards on the fore mast the way they would have been rigged in order to raise and lower them I can’t without doing major damage. To hold the yards in place while I rigged them I drilled matching holes in both the yard and mast I which I placed a metal pin with CA glue. I also used a few drops of CA glue on the parrals to help hold them in place while I rigged them. I would do severe damage to my yards and the mast if I tried to remove them. Until reading you guys newest comments I had no idea the yard was lowered when a sale was furled. Henry I understand since I have the foremast yards as they are I will have to do the same with the main yards if I want to be accurate. I could consider furling the main course, but all the remaining sails will need to be unfurled? Again if I want to be accurate. Oh well. I guess decisions have been made on sails. So are we saying in making my sails there are no reefs in 1668 when the SR was constructed? That will definitely save some time.
  25. Thanks Ferrus. So I understand all the lines stay attached and if the sail is furled the lines are just folded up into the folds of the sail? I thought that had to be the case. Could not see the crew trying to attach rigging lines to a sail after it was unfurled, or while it was being.
