Bill97
Everything posted by Bill97
  1. I am glad the new instructions show the rigging for the yards. The Heller Victory instructions (older version) does not clearly show it as you can tell since you have both. That is what I am spending time now researching with the old instructions and my Longridge book. I know each yard has a number of blocks strategically placed along each yard for future running rigging. I want to tie all of the blocks on before attaching the yards to the masts. Just have to sketch it out so I know what goes where. If I can help you in any way please just ask. I have no doubt you will do a fantastic job. Except that it will take a good while to finish. In fact don’t even think about finishing it. You will in due time. Just enjoy the journey. I am a few days from 11 months since I started mine.
  2. Twahl I have the new instructions for my future Soleli Royal build. I see in these instructions that Heller clearly shows where blocks and other rigging go on each yard. Does the new Victory instructions provide the same information.
  3. Oh so you had the backstays tied at the mast but did not have them attached at all before doing the ratlines. I guess that would cut out doing double work.
  4. Your right about that Kevin. The rigging does seem to take ages but I enjoy it once I understand a particular line. Especially the shrouds and ratlines. That is something I would for sure do different on a new CS and Constitution. Both of my models in their case have the Revell plastic molded shrouds.
  5. Kevin watching you build your CS combined with the knowledge I have gained building my Victory, makes me want to rebuild the Revell CS and USS Constitution. I have them completed and in cases but back then I just followed the instructions. Made very few changes, if any, as my build blogs of those two ships here on MSW will attest too. With still quite a ways to go on my Victory and my Heller Soleli Royal waiting patiently, I doubt I will build those ships again, but who knows? I am not throwing in the tools yet.
  6. By the way Twahl, you are doing a beautiful job!
  7. That is what I did Twahl. I have 6 different sizes of black thread. I use the spread sheet of thread sizes I got and round up or down to select the closest. I have .35, .45, .55, .65, .80, and 1.0 mm. I also have a standard spool of black sewing thread for any need smaller than .35mm. The 1.0 mm is a little smaller than the the largest black thread called for but I can live with it.
  8. That’s a great idea Ian. Just undo the lanyards for the backstays, tie the ratlines, and then redo the backstays.
  9. Thanks Ian. I thought I was doing it correct according to Longridge. Glad you mentioned the black bead mouse. That was my first time high I did paint. After that I decided to leave them pearl. Need to go back and remove the acrylic paint from these first two. What is your opinion about the backstays and the shroud ratlines? Should I go ahead and do the ratlines before backstays are in place or reach through the backstays that will be positioned in front of the shrouds to do the ratlines later?
  10. Interesting question for you guys. I am currently working on adding the backstays to the masts. I have looked at Longridge and a number of builds here on MSW for the placement of the loop for the stay and preventer stay. On mine I have the loop made by the fore and main stay and preventer stay going around the shrouds and back stays at the mast head. Others I have seen (see attached photo as example) show the backstays placed on top of the loops of the stay an preventer stay. Which way is correct? When I read Longridge, he says to place the back stays on top the shrouds. I did it that way and have the loops of the stays going around the top of the shrouds and back stays. (See 2nd photo which is my ship). Does it matter?
  11. Ok gentlemen I have finished the jeer blocks on the fore and main mast. I am now ready to move on to the different backstays. I immediately see the the breast backstay and two of the three standing backstays are in front of the shrouds. Should I go ahead and do the ratlines first or work around the backstays later to tie the ratlines?
  12. No Ian. Those are just threads I put through the blocks to hang weight from for the photos. No actual bunt lines rigged yet. Appreciate your compliment. I learned that is for sure a step I will do sooner in the standing rigging on future builds. Little tedious working around the shrouds. I have to admit Ian this rigging is really starting to make since thanks to you. And as it does it becomes easier to understand what and how to do a particular line. Thanks again for the spread sheet of line sizes. I use it constantly!
  13. Ok my friends this was a full Sunday’s work. Got these rigging lines (whatever the proper name is) completed on the main mast. I do not have any triple blocks for the upper block so I just used the largest doubles I have. Also used a large double block instead of a thimble for the middle one.
  14. Great Ian that makes perfect since. Another thing I have been looking for with not much luck and wonder if any of you know a reference I can use is the layout of the blocks and other rigging that goes on each yard? It will still be a bit before I start working on them but would love me to find what I need in advance. I plan to tie all the foot ropes and necessary blocks to each yard before I attach it to the mast. Don’t know if there is a simple diagram that might show what is needed on each yard and where positioned?
  15. Ok gentlemen another rigging sequence question. Trying to determine how Longridge suggests doing it. Do you recommend putting on all the stays up through top gallant stays and royal stays before any of the back stays, or do you recommend some other sequence?
  16. Yeah the serving machine I have has been a life saver.
  17. That’s fascinating Kevin. I knew we had more than ship building in common.
  18. Crazy back story. Many years ago, in the 70’s when cameras still used film, I got my college degree in photography. Had a darkroom where I developed and printed my own film. The whole set up. Tried to make a living with photography but income was not enough to raise a family and a home so I eventually threw in the towel and got a job that would. Photography was just a hobby then. From time to time I was asked to be the photographer for a wedding. When ever I did I was always highly stressed until I was able to get to the dark room and see my finished product! My thoughts were always “what if something screwed up and I have no pictures, or dark pictures, etc. You only get one chance at a wedding, no do overs! Was glad when digital photography cameras became affordable for the common man! Now I can see immediately if I need to take that shot again.
  19. I am still sporting my Canon AE with a few additional lenses. Gets the job done for me. However I lazily find my self just grabbing my iPhone for quick shots of my ship. Makes for easier post to MSW.
  20. Top mast stays for all three top mast installed following Longridge’s instructions. In keeping up with my plan to add a bit of bling to my build I used a pearl bead for the mouse on each of my stays. I think I will use the same pearl beads for the parrals when I am ready to hang the yards.
  21. Thank you Ian. That is very good and helpful. Going to print your photo for quick reference. I think when I finish my Victory and put it in the display case, the name plate I put in the case will have: “Assisted by Ian Grant” under my name as the builder. 😊
  22. Now Ian that is what I am looking for. What you actually did.
  23. Thanks Ian. Plan 8 is pretty good and I have an idea what it is supposed to look like when completed but just could not get a complete grip on the process.
  24. Ian HELP! Now that I have completed the shrouds I ant to go ahead and do the jeer blocks and jeer blog strap before moving on to the stays. I have read Longridge’s paragraph The Jeers on page 241 and studied Plan 8. I get the general idea what it is supposed to look like when finished but I am a little confused about the long and short legs of the double strap, as well as a couple other confusing things in that paragraph. Would you mind translating that paragraph as if you were writing a “Model Ship Rigging for Dummies” book? 😊 I would certainly appreciate it.
  25. Finally all the shrouds, futtock shrouds, futtock staves, and catherpins finished. All the lanyards will get final tighten and a drop of white glue in the future. Now to the stays! IMG_1110.MOV
