Meriadoc Brandybuck
Everything posted by Meriadoc Brandybuck
  1. Thank you for the likes and enthusiasm! I’m glad we can share these little projects. I have the frame together in some sort of order, dry fit for now. It took a bit longer than expected and the card stock I ended up with is not the best- too papery and hard to achieve minute precision. But it’s the basic shape which will hopefully at length come together to look nice. I’m looking forward to getting it glued, skinned, planked, painted, fitted out, and rigged. One bit at a time. -Meriadoc
  2. Hello, I was peeking through this thread as it is such a treasure trove of information for scratch-building, and I asked my wife, who works in the apparel industry, about the fabrics you mentioned. Voile cotton is a soft cloth used in blouses and pajamas, and Navara fine lawn is used in men’s dress shirts, or at least ones that have soft fabric. Perhaps the future supply chain for scratchmaking becalmed sales goes through a used clothing shop, or one’s own closet. Meriadoc
  3. Very sad to hear the news, Mark. I don’t know up from down but I think it’s safe to say you will be missed around here. Do take care. Meriadoc
  4. Second planking not going bad. Planked from the lower gunwales down to the main wale line. I found the best method around the bow curves is to CA a plank in position at the flat of the bow (only about 2cm worth) and once it’s secure, work around the curve with water and a hot iron. CA sections bit by bit as you can, and keep encouraging the plank with heat and moisture until it takes its shape. Starting midships and working forwards doesn’t seem feasible. Anyone know the correct cut of the garboard on galleons? Criticism welcome! -Meriadoc
  5. Hello, Inspired by the card creations of Ab Hoving in particular, and informed by his wonderful guide linked to below, I chose a small subject from Chapman’s Architectura Navalis Mercatoria to work on the skills and knowledge necessary to tackle larger future projects in card. The medium offers much greater time and cost efficiency than wood, while still allowing for excellent results, at least once you know what you’re doing. I chose the sloop-pink on plate XIV, No. 20 as it is relatively simple but includes some interesting visual features. With the original vessel measuring 51.3’ between perpendiculars, at 1:100 it will total a whopping 16cm or so plus bowsprit and whatnot, so nice and small, all the better to make my Heller Victory look big someday. I do not know much about this vessel or type, where or how it was used, or why it has the features it does. If anyone knows anything, I’d be more than happy to hear about it. There is a similar looking brigantine-pink next to it on the plate. Dutch? Mediterranean? English? The rudder-tuck stern is sort of reminiscent of Dutch flutes, but that could be a coincidence. After negotiating with my printer, I have the essentials for the frame. I may have ended up with a suboptimal kind of card though. Oh well, press on. And a big thank you to Ab Hoving for sharing not only his wonderful creations on this site and others, but also the knowledge of how to do it. I hope I can make use of this generously shared knowledge to make some worthwhile models to look at. Must start somewhere. Hoping to get the hull together soon and see how it looks. -Meriadoc
  6. An update- spring and summer were spent building 1/72 airplanes and playing Dragon Quest, in addition to attending to a certain baby. Now that it’s nice and autumn, it’s time for nautical hype and tall ships. The Revenge: I decided the wale wasn’t satisfactory, and removed it with some difficulty. Sanding to follow, and I think I’ll plank the sapelli next. Note that I stained the bulkheads to match the gunwales.. some side effects but it will work out better. I also sealed the dollar store putty with clear coat, and mean to stock some real putty soon. Below is a good overview of what my 2021 hobby efforts have amounted to thus far. -Meriadoc
  7. Hello, I believe earlier we had talked about silicon casting as a means of reproducing parts accurately. There is a better method, using blue stuff and epoxy resin; far cheaper and easier. I’ll link a video that shows how to do it. Hope you and others around here can benefit from it.
  8. Backer- thanks for the kind comments! Google translate seems to be working well for you. Don’t trust it for translating Japanese though! Heres my pinhole-putty issue: See how the white putty has seeped up through the holes in the wale. About wale positioning- I’ll check some sources. This kit includes no actual plans, so I made some measurements and guessed. Meriadoc
  9. Thanks for all the likes! A quick update. Slow progress, as a few other interests have had to be dealt with; see below. Finished sanding and filling, and added the first wale. The “instructions” are now taken far less seriously. Then some other pursuits came up.. And got some attention.. A few more days left of finishing work on the Hornets, and I think I’ll put Dragon Quest and 1/700 waterline ships away for a long while and get back to my Elizabethan shipyard. QUESTION: I am having filler seep up through pinholes in the wales when I try to get the holes to close with drops of water. Anyone know of a workaround for this? Meriadoc
  10. Hello, I've been quietly following along. Learning quite a bit from your chronicling here. I knew I couldn't be the only one with this problem.
  11. Looks much more the part after a day of sanding and negotiating with the gunports. Putty next.
  12. Lots of planking has happened. I finished everything but the upper gunwales on the first layer. Learned a few things as I went. I’m not sure if I should be happy with it or not, but I think it’s workable. In particular, does anyone have any good information on how/where the garboard plank should terminate at the bow on the Revenge? Photos below; I’d love to hear any ideas on what to do better next time. Trying to establish planking bands; a process I think was counterproductive in this case. The first strakes at the bow. Should have tapered to minimum width ASAP. Did I let the garboard curve up too much? First and only stealers needed here. Getting closer. Almost. Criticism welcome: Thoughts? I attached several more photos to show the process but the above photos are the most relevant. Hoping to wrap up loose ends and get it ready for the sapelli soon. Meriadoc
  13. Silicon casting is kind of costly and troublesome but would allow you to duplicate small parts accurately.
  14. Can you silicon cast your sculpey work? Maybe not worth it in this case though.
  15. Planking adventures! I did investigate a variety of opinions about this process, and amassed a collection of inexpensive equipment. The Occre “instructions” tell one to start immediately below the plywood guides, and gives little other guidance. Their example seems to be planked wrong anyways, but I started at this point as I will need to fit some sort of backing for the dummy barrels I intend to add to the lower deck. First I plank the area, then when I still have acces from below I will glue in the backing. I ended up planking myself into a bit of a pickle as the two sides were ever so slightly asymmetrical after two planks each, and I had to try to fit my planks evenly under the beakhead deck- one side wanting 3 planks (5mm each) and the other wanting four tapered planks. I’ll let the photos do some of the explaining. I started with this plank on each side, and added one above at full width. I used a crimper to bend, which was easy enough. At this point I thought it should all fit evenly under the deck that must go in at the bow. Then I remeasured and decided that four tapered planks would be needed. I tried soaking and bending over an iron for these, as the taper was awkward, narrower at bulkhead #1 than the very bow. In retrospect a crimper would have been easier but I did get to practice a different technique. Not happy with how they came out but I learned something and it should be good enough for the bottom layer with some sanding and filling. The curve around bulkhead #1 is quite severe, I broke one pre-tapered plank at this narrowest point trying to bend it over my iron. It was also difficult to get consistent curves. Better filler blocks would have been helpful, as well as tapering on the top instead of the bottom of the planks. On the starboard side, the gap was smaller and i deemed three planks would work far better than four and save all the fuss of tapering and breaking narrowed planks over an extreme curve. These were bent with a crimper with very little sweat and toil. I was using CA though in an effort to get more than one or two planks installed in a day, and it froze some of my mistakes in place as you can see behind the first bulkhead on this third plank. Ought to sand out though. Back to PVA. You can see how many planks I was able to get done despite my best efforts to achieve economy of time with CA. Really the elephant in the room here is the baby in our house that I must help take care of, so a best case scenario is a few planks per day plus maybe some peripheral progress on other loose ends. Here there was a major gap between the plywood and the lay of the lower planks. Perhaps I missed something in my fairing process. I fixed the problem by inserting this little filler block to get the next plank to play ball with the plank below, above, and the front of the forecastle. Got the plank in, so it’s even with the port side except for the bow. You can see how much learning I have to do before I take on single planked kits. I needed to do something about the asymmetry of the top of the planks here under the forecastle on the port side as the planks were tapered unlike the starboard. I marked out a spot for a stealer. And installed it with CA. Ought to be roughly symmetrical now. There is a gap under the deck on the starboard side that should be addressed but I don’t think it would have been worth tapering four planks and hoping they don’t break around that bend at their narrowest point. If I had to do it over I think I’d properly filler block the whole bow and then one could work tapered planks with an iron easily enough. Just now, I installed the garboard planks but couldnt decide the cut at the bow. I think this is determined by the run of the next strake, for which I must calculate tapering first, so I left them hanging for now. Now I have to remember to install my dummy gun backings before I plank the rest in. Slowly but surely (or reasonably confidently)! Meriadoc
  16. I'm sure they reinforced it around the area where the powder charge goes. Maybe they were for ships that didn't plan on using their guns much.
  17. As I was putting these together I did have a thought in the back of my mind, that all the hooped "wrought" guns I could recall seeing were in fact iron ones.. Well they're rather planked in now; I'll contemplate the prospects of repainting them. Going to have to mix up some iron color anyhow.
  18. I was under the impression that ships of this period carried quite a variety of guns with very little in the way of standardization. Do you suggest that her guns were likely iron, or are wrought and cast bronze exclusive terms? Seems you know a lot more than me about this period! Meriadoc
  19. What’s everyone’s favorite Silmarillion character? I guess I’m a Felagund fan.
  20. An update on progress~ Got the last piece in. Planking all the gunwales in sapelli. Easy enough. Faired bulkheads, and added a few filler blocks. These photos show the work in progress. Can’t tell if I did a good job or not but the little spruce plank I used as a guinea pig seemed to fit well enough. And fitted the first plank, bending with a mantua crimper Started dissecting the head “grating” for modification. Thought of a good use for those oversized swivel guns: Too much glue, but that part won’t be visible and I didn’t want it ever coming loose. Just used scraps. Walnut stain on interior to keep it dark. Gonna have to plank around it but should be fudgable. Now she has stern chasers! Next up: planking fun. Meriadoc
  21. Cirdan, thank you for this information. Very interesting to see what contemporary sources we do have for this ship. I've got some thinking to do about the decorations, but I'll have some time before I have to make any decisions as I learn how to plank. You have a most appropriate username, I must say. I like to put on Tolkien audiobooks while I work. That or Bob Ross.
  22. Ab, very fascinating. I'll have to look into the artwork a little more. Thanks again for sharing! I don't think I'll start anything too soon, but I'll be sure to make a build log when I do to record the adventure. Meriadoc
  23. Wait, I think it says the one on the right is a statenjacht. Meriadoc
  24. Ab, thank you for the images of your construction and the artwork. In the last picture by Nooms, are both vessels wad-konvooiers, or just the one on the left? Meriadoc
