Everything posted by ERS Rich
Installing the Wales Installing Wales is difficult because they need to be precisely positioned so both sides mirror each other. Here is a way to do it simply. Start with a full length plank, cut it to fit along the Stem Lost. A tool like this can be used to form the curve, it’s quicker and saves time compared to soaking. Make up a set of blocks, here I use 4 x 4 mm Plastrut. Next position the Wale in the exact location and secure with cloths pins, and take a break. Come back and make sure everything us right. Then install the blocks along the Wale edge with a dab of CA. Now the Wale can be removed, glue applied, reinstalled to the exact position, and clamped. After the glue dries, use a pair of pliers, and snap off the blocks.
Shaping the Area Aft of Bearding Line Here the task is to taper, or thin, the First Planking from the Bearding Line aft to the Stern Post, so the top if the Second Planking is close to flush with the Stern Post and Keel. First made a template of the Bearding Line off the plan with Velum and transferred the Bearding Line to the model. The tools for doing the work: large and small gouges, triangular and round files, and a pattern file - with cutting edges and perpendicular safe edges. Making large gouge cuts. Finer cuts were made with the smaller gouge. Using a piece of Hardwood Second Planking as a Scraper to remove the chips, along with the pattern file. And working along the Keep and Stern Post.
Hello Y.T., Great question. A light pass with 220 sandpaper will remove any tool or saw blade marks. The thickness sander is used to make dimensional changes. For example reduce the thickness of a sheet from 3/64” to 1/32”, then cut individual planks from that sheet on the table saw. Or say you have 1/4” x 1/4” square stock, the thickness sander could be used to take off 1/16” on one face to make the stock 1/4” x 3/16” - the table saw could also do this job. I do not have a thickness sander in my shop.
HMS Badger: Cutting Bearding Area in First Planking
First made a template from the plan with Velum.
Tools for the Work
Large and Small Gouges, Round and Square Files, Pattern File - it has cutting edges and perpendicular safe edges.
Large gouge used to make chips.
And smaller chips back towards the bearding line.
Hardwood plank makes a great scraping tool.
Pattern file to work along the keel and stern post.
The plank edge should fit flush along the keel and stern post.
HMS Badger: Counter Forming and Installation
Usually I’d soak and form with my fingers.
This time realized I needed some help with some sort of jig. Looked around the shop and found a PE rolling bar, and a jig used to hold dowels when drilling holes.
Piece in the Jig and Clamping
Done
Installed on the Ship
Let’s get underway! Awesome model. Thank you for posting….
- 37 replies
- Pillsbury
- Clemson-class
How serious do you get about dust protection
ERS Rich replied to bigcreekdad's topic in Modeling tools and Workshop Equipment
Thanks, I am doing well now, on the road to recovery and back to doing what I like to do with some limitations. Apologize for being preachy, you know how it is, you go through a tough experience, and hope others will not. Happy modeling! -Rich -
Hi, Get serious about dust. I want to help others. I was diagnosed with Interstitial Lung Disease/Pulmonary Fibrosis last March, with minor symptoms - age 63. Six months later, after a rapid decline, had a Double Lung Transplant. Fortunately I had no major complications and am recovering quickly. Foredom makes a line of desktop hoods with integrated vacs - they are expensive. They have a desktop hood that attaches to your vac for $70. That being said, use tools to remove wood, and sandpaper just for finishing. Woodworkers do not use sandpaper to remove wood they use tools, in our hobby: miniature planes, small chisels and files, drill bits. These tools produce, for the most part shavings, not dust. If you find yourself making a lot of dust with sandpaper, ask are you using the right tool. Sand outside. Using sandpaper? Wear an N95 mask, that makes a tight seal. The mask below can be found on the web, box of 10, for about $20. Rectangular “COVID” masks with gaps around the face are useless. Need motivation? Search for Interstitial Lung Disease, or Pulmonary Fibrosis on the web. Please protect yourself, you want to get old and be healthy. All the best. -Rich -
Always a good time watching your work. Thanks
- 165 replies
- Red Jacket
- Marine Model Company
Hardly a newbie! Welcome and good luck with your project. -Rich
Good job, looking forward to what’s ahead…..
- 66 replies
- First build
- Cutter
“Clinker” happening means the width of the plank needs to be reduced, or tapered, towards the stem. The taper starts about the third bulkhead aft of the stem, the plank width will end half the width or less at the stem. At first you can get away with not doing it, it will catch up to you. Find one of the many postings on this site to see how to do it. My Constitution build log talks about it. Nice work, so far, good luck.
- 66 replies
- First build
- Cutter
Keep going! Sand that wood filler until it is smooth and feathered in. When filling seams feel free to mask off each side so extra filler is on the tape. Makes the sanding job easy. Consider the lower hull needs to be completely smooth, no humps or bumps, or “stair steps” between planks. Look into how to use a card file. Good luck.
