Gregory
Everything posted by Gregory
  1. Super detail at 1:192 ? That would be interesting to see on any model ...
  2. Has anyone ever used this Mantua 'lathe' ? It has the pass through feature. Looks simple and cheap..
  3. Your concerns are well founded, but at the price point, it is pretty easy to extend the table on those lathes. When all is said and done, while I was just throwing out some alternatives to the Proxxon machine, I am personally not concerned with the length limitations. I find it's better ( for me ) to break up long spars and masts into shorter pieces, then put them back together. An example from my Resolution. I use a laser for the rough shape, which I turn with the drill and sand paper method. FWIW
  4. I don't know what your buying options are in NZ, but you might do as well with something like this: Mini Wood Lathe $36.99 US At little higher cost, but still about half the Proxxon, here is another option. Mini Wood Lathe $129.99 These machines will have their detractors, and rightly so, but you will have to go past the $500 price point to move into a category that might get the approval of our tool aficionados. I think machines like these will perform as well if not better than the Proxxon.
  5. What Mamoli is looking for you to do is trace out a pattern like I have made in red, then use strip wood pieced together like I have indicated in blue, where you would then trace the pattern to give you a shape to fit over the bow and stern without any gaps. You may want to use more pieces than they have shown in the instructions in order to easier make a curve. If this is still a problem for you and I may be able to put together a little demo with some wood.
  6. Here are the drawings at WIKI Commons Centurion 1732 There are 2, so click through to see the next one.
  7. I need to get to my drawing tools later, and I can show you what I think you need to do..
  8. I’m guessing Mamoli is showing a simplified way to put strip wood together, expecting you to match the curved shape of the stern? Do you have a picture of the profile of the boat?
  9. There are a couple of drawings in the WIKI Commons.. I can get you a link later.
  10. You should put together a book with your rigging technique. I would buy it in a heartbeat. Meanwhile, your log is a frequent visit for me. While I would be hard pressed to duplicate your work, a goal would be to get a similar look..
  11. Check out HisModel and Amazon. I see they have wooden decks for Cutty Sark.
  12. I have bought their cherry and walnut sheets, which were of reasonable quality. I think you are better off going with Modelers Sawmill or Ocooch Hardwoods.
  13. If the 2D drawings do not render well, then they are not accurate. CAD can certainly help to resolve these inaccuracies, but not having the skills to use CAD, should not keep you from producing accurate drawings for use with a laser.
  14. While I agree CAD is great for visualizing the entire ship, in the end, the laser is a 2D tool. Accurately produced 2D drawings are ultimately what you need to drive a laser, and they can be produced as accurately in a 2D environment as in a 3D one.
  15. I like the version from a Bob Seeger song: " I wish I didn't know now, what I didn't know then. " 😁
  16. Another consideration will be the software driving the laser. If the laser controller will support it, see if you can get the community to use LightBurn. It is relatively inexpensive and is very powerful. It supports 2D images that it will trace for cutting, giving you the option of skipping the CAD work if you have a good 2D drawing of your frames or other parts.
  17. Not necessarily nicer, but plywood will give you more strength for your framing. Very little, if any will be visible in the end.
  18. Just wait a couple of hundred years and all your boxwood will look that good…😁
  19. I have been meaning to give Thick and Quick a try just to see how it does. CA Does take a little extra care, but a few seconds versus several minutes clamp time means a lot to me.
  20. If it crystallizes, then there is something wrong with the formula, or the way it was used. Properly cured CA is just plastic, with fibers penetrating the wood, creating a mesh that is stronger than wood in some regards. The bond can break under shear stress, but this is unlikely to happen with planking, and not any more so than PVA. The times I have seen a CA joint come apart there was always shared wood on the two pieces, which means the wood broke before the glue did.
  21. With checkers up forward, surely you must have chess in the Captains cabin. 😁
  22. I can't say that I used any verifiable reference.. I'm sort of a " if it looks good ( to me ) it is good " modeler. I think I more or less settled on the length shown in the kit plans. The kit shows a jib boom as well as a bowsprit and I feel it has a balanced look, that I decided to go with.
  23. I think we need a picture and some context. Aren't knightheads two timberheads adjacent the stem? I am not aware of any specific rigging per se.. From Mondfeld.
  24. Take a match to it ( not too close ). If it's poly it will melt, if it's natural fiber it will burn.
