Everything posted by shipman
Don't want to teach what you may already know..... eg. assuming that's from Hackney: 5'' full scale rope at 1:168 would be 104 tight turns around a stick over the length of an inch. That would be fine thread indeed.
- 481 replies
- Cutty Sark
- Revell
Reminder....cordage used to be measured around the circumference. Don't compare Cutty with Victory.....that would be folly. As for scaling up from 1:168 to 1:96, unless you're going to get too technical, simply doubling the dimensions you're talking about (to the eye on a completed model) would look just fine.
- 444 replies
- Cutty Sark
- Revell
Stacked boats on the Bounty for sure. I'd be surprised if boats on the Cutty were stacked though. Interesting techniques for stacking boats. The height of the top boat (in that image) suggests it's resting on the thwarts, which was done. To keep the center of gravity low, the thwarts of the lower boat would be removed so the top one 'nested' snugly; 'nesting' I believe is the correct term.
- 481 replies
- Cutty Sark
- Revell
Your #154 looks to be the same book but an edition I'm not familiar with. https://www.ebay.co.uk/itm/353978898254?hash=item526ac9574e:g:DewAAOSw45FiQJ-needs c This book turns up regularly on ebay, often much cheaper. I got one recently for under a tenner. As with all kits, there's something needing a bit of fettling. That deck issue isn't the end of the world and not hard to put right.
- 481 replies
- Cutty Sark
- Revell
Indeed, the Beagle is a re-hash of the Revell Bounty. The 1:87 Airfix Bounty is a much better kit, the scale providing scope to get all the details correct. The AOS book shows how accurate that kit is (at least compared to the drawings in the book).
- 481 replies
- Cutty Sark
- Revell
Chain 40lpi https://www.ebay.co.uk/itm/362852779497
- 444 replies
- Cutty Sark
- Revell
Don't forget the Cutty used steel standing rigging. Running rigging, foot ropes etc were hemp. A considerable amount of chain was used on bowsprit, masts and yards.
- 444 replies
- Cutty Sark
- Revell
Refer back to your post #38....small boat on deckhouse, Sydney 1891. I have seen drawings/plans/models where there were 2 large boats, with a smaller one between on the aft deckhouse. A similar small boat on the fore deckhouse. It doesn't seem unreasonable to adopt such a scheme. Never come across mention of a 5th boat. As far as deck clutter; unless she was loading/unloading cargo, the decks would need to be free to allow working of the ship. It's worth looking up Alan Villiers photographs on wiki...obviously a later period, but not dissimilar ships.
- 481 replies
- Cutty Sark
- Revell
I recon this is as busy as a sailing ship deck would be while at sea...... https://upload.wikimedia.org/wikipedia/commons/b/b5/Parma_-_under_sail_in_heavy_weather.jpg
- 481 replies
- Cutty Sark
- Revell
This stern decoration is turning into the adventure/farce I was suspecting. I don't understand Radimir's instructions either. The transfer sheet malarky has me scratching my head big time. It could be worse; it could be me.
- 481 replies
- Cutty Sark
- Revell
I have this 'ornament', but don't recall there being 'transfer foil' enclosed. Hope you can make sense of their instructions.
- 481 replies
- Cutty Sark
- Revell
May I suggest you email hismodel? and seek their advice. Good luck.
- 481 replies
- Cutty Sark
- Revell
They obviously consumed the ships stock of rust inhibitor! Hope they paid the admission fee.
You two chaps are making a great team. Neither are as daft as I look.
- 481 replies
- Cutty Sark
- Revell
Can I be the first in the cue and be cheeky and request a set of your lozenge decals? I have no means of printing and haven't a clue how to do the origination on my laptop. Kevin, see my comment #122 here. I share your pain.
- 481 replies
- Cutty Sark
- Revell
The best paint available in the UK, I've found, are the acrylic Citadel range from Games Workshop, which are the bees. They have very fine ground dense pigments and flow beautifully off a brush (as they are designed to). Coverage is excellent, yet they are thin enough to not obscure detail. One stroke and you're done....including a wide range of metallics. They aren't the cheapest My experience of sharpies and other felt tips is they aren't as permanent as they'd like you to think.
- 444 replies
- Cutty Sark
- Revell
Mmmm. My main concern is that the etch is pierced, ie there are gaps between the lettering etc. So whatever adhesive you use, it's bound to spread and squidge out and around the detail. CA often turns white, epoxy....well, it behaves like chewing gum that sets. Again, messy. The clear when dry properties of PVA types would seem to avoid those issues. I agree, pre-forming the etch to the surface it's going onto is a vital key to success. The stern decoration etch is a delicate filigree and needs some thought as to how it's applied, without destroying the whole point of using it.
- 481 replies
- Cutty Sark
- Revell
The 'Pledge' used to be called 'Future'; aircraft modellers dip canopies in it, which makes them perfectly clear. Not sure how good it is as a 'glue'. This Microscale product is brilliant for clear windows. It's a sort of PVA. There again, I've used ordinary PVA and got the same results. Glad you brought this up, as it seems ideal for attaching the bow and stern etch, though I have no idea how to hold the etch in place while the stuff sets. https://www.google.com/search?client=firefox-b-d&q=microscale+crystal+clear Again, I feel Longridge is as good a source as you'll find. It's worth remembering he did his own research in the 1920's when she was still afloat and had the opportunity to crawl all over the ship.
- 481 replies
- Cutty Sark
- Revell
NAIAD 1797 by Bitao - 1:60
shipman replied to Bitao's topic in - Build logs for subjects built 1751 - 1800
My first visit to your build. Oh my! This is WAY beyond me. Can't believe what I'm seeing. -
I've had umpteen small value items from China, usually free postage and never incurred any additional charges. Incredible really, when you consider they are at the other side of the planet. Makes me wonder how they make any money at all.
I concur with your opinion of most of the wooden kit renditions, though I have no wish to denigrate the folk who build them. Most (as an example) have planked bulwarks; they are sheet iron/steel on the ship. In addition, the wood provided is appalling quality, the grain being open and out of scale. By contrast the basic hull of the revel kit is pretty accurate, not withstanding obvious small detail issues which are easily remedied. As for the masts and spars, the fragility of the parts justifying scratch replacements in brass and wood. On the ship the belay pins are iron, painted black. The deadeyes are made of that very hard wood, Lignum Vitae, which is a dark brown. The often regarded as the bible 'plans' by Campbell, as someone here recently observed, aren't entirely accurate either. As I understand it he was commissioned to do them to compliment the ships first public appearance at the Festival of Britain in the early 50's. He was employed by the London County Council engineering department. I have no idea what his connection was to maritime affairs before or after. It would be enlightening to hear more of his background, what his sources were (other than 'conversations' with surviving sailors of the period). The original ships spec listed (naturally) accurate builders plans and a model. No trace of which survives. We do know the decorative elements at bow and stern were originally far different to those on the ship now. Like so much of history, there will be so much we'll never know.
- 481 replies
- Cutty Sark
- Revell
Another issue with the kit boards that the deadeyes and belay pins are mounted are at least double the width they are on the ship. Another cunning feature is that the pins locate between the deadeyes, so they can be set back. I would suggest drilling holes for new pins at the same locations where the kit ones are is pure fiction. I think you mentioned earlier about your marginal confidence tackling the rigging. If this build has already had you pulling your hair out with frustration, you must realise what lies ahead is when the party truly begins. That is when you find out your real character. Rigging explores your personality. It helps if you are already predisposed to being highly strung.
- 481 replies
- Cutty Sark
- Revell
