Everything posted by HIPEXEC
- 1,133 replies
- model shipways
- syren
I put in the hole for the rudder. I'm holding off for now installing the stern post until I finish planking
- 1,133 replies
- model shipways
- syren
Jesse, It's gold paint to give it a gilded look
- 1,133 replies
- model shipways
- syren
More stern planks. I think I'm pretty close to hiding all my mistakes when I veneer plank the hull. If I were coppering it the same would apply.
- 1,133 replies
- model shipways
- syren
- 1,133 replies
- model shipways
- syren
Continuing to build the stern. This is rough veneer planks plus the decorative trim that will eventually be installed. You can see where I screwed up rough planking by the stern post. I'll correct all that with sanding, filler then veneer planks. First I have to finish the bottom half of the stern.
- 1,133 replies
- model shipways
- syren
Here's my supply of veneer. I'll be using some to build the transom even though I'm a long way from putting veneer on the hull.
- 1,133 replies
- model shipways
- syren
More work on the stern. This piece will greatly strengthen the whole thing. While I was fitting the several pieces that comprise of the upper part of the stern, the ship slipped off my holding rack and the tip of the bowsprit broke off! Thank goodness it glued back with a perfect fit even though the break was jagged.
- 1,133 replies
- model shipways
- syren
Working on the stern. The plans and instructions are vague on this part with one fuzzy picture showing planks before painting.
- 1,133 replies
- model shipways
- syren
America by Nirvana - Constructo
HIPEXEC replied to Nirvana's topic in - Kit build logs for subjects built from 1851 - 1900
Your "V" box is very clever an cost effective. I made a more elaborate stand so I can hold various size models over time. -
- 1,133 replies
- model shipways
- syren
Down to two pieces on this side. I'll probably finish the sides today if I'm not distracted by life.
- 1,133 replies
- model shipways
- syren
The last main piece on this side. Two very small pieces at the rudder post then I'll finish the other side.
- 1,133 replies
- model shipways
- syren
Down to two short planks on this side. I'm using the Philistine method of making stealers. I just use sharp points shaped to fit. I'll leave the correct method of making stealers to real ship builders and the purists.
- 1,133 replies
- model shipways
- syren
Yes. It will feel good to enclose the sides. Then I have to finish the stern with very poor plans and photos in their book. I'll figure it out ,though. After that there's my veneer planks, then inside the gunwales, then the deck. So...a long way to go. But I will be happy with the sides closed in.
- 1,133 replies
- model shipways
- syren
Well, it was a good lesson....to slow down and plan ahead better. I sometimes get on a roll and hate to slow down. Bad habit it ship building.
- 1,133 replies
- model shipways
- syren
- 1,133 replies
- model shipways
- syren
