oakheart
Posts posted by oakheart
  1. 8 hours ago, mtaylor said:
    zu Mondeld's Historic Ship Models.
    Thanks Mark @mtaylor, I happen to have purchased a copy from the famous Booths bookshop in Hay-on-Wye last summer. I often go there as it's only 40 mins down the road. I paid £5 which was a bargain looking at the prices online.
    Now I have some non fiction bedtime reading.
    Tim
  2. 3 minutes ago, iMustBeCrazy said:
    This gives a fairly clear example:
    Thanks Craig @iMustBeCrazy that as you say gives a clear example, what a fantastic resource RMG is.
    so now I have a couple of names, channel is the block of wood, chainplate is the metal strip. Is that correct?
    Now I am thinking I will make mine like this, with a planted strip on the outside.
    Tim
  3. 11 hours ago, druxey said:
    (see bottom pic, post #114).
    Talking about a lot to learn.
    The drawings  in post #105 and #114 show the deadeye straps passing though the board attached to the hull, other drawings show it on the outside?
    OK now I think I need to do some more research on the names for the parts of what I believe are called the "channel" or "Chains"
    I found this webpage useful even though it seems aimed at a more general audience
    http://www.ageofsail.net/aostermi.asp
    Is there a good reference I can refer too?
    here comes yet another rabbit hole......................if I don't get too sidetracked I might get some ship building done.
    Tim
  4. Thanks for the advice @druxey, @Thunder and @iMustBeCrazy.
     have done a new profile view and think I will be able to make it work.
    This model will not represent any particular cutter but should work visually.
    I am not sure now if the straps ( don't know what their real name is ) should bolt into the wale?
    Tim
  5. 24 minutes ago, Twokidsnosleep said:
    Likely just delaying the process
    I know the feeling. I am struggling with a scratch build of a cutter in wood, can't decide whether to rig or not.
    You have inspired me with your excellent build, I will have to get and build this kit.
    I need to watch the movies again to get in the mood.
    Tim
  6. 2 hours ago, Thunder said:
    get away with just moving the belaying racks and then making sure you space the shrouds / deadeyes so they do not end up in front of the gun port
    Thanks Thunder, I can see how that could work.
    I have just been working up some drawings in photoshop.
    The rigging would take me well outside my comfort zone at this time. Lets see how I feel when I have completed the hull.
    Tim
  7. 10 hours ago, iMustBeCrazy said:
    very light stains to provide some contrast
    Hi Craig
    That is a nice idea.
    I did do some tests earlier using a water based stain which worked well on the cedar.
    But I am terrified that it will all go horribly wrong and I will end up with patchy tide marks all over the beautifully smooth hull.
    Someone suggested spraying the stain using a hand spray bottle, not sure if this would work
    I think more testing is required.
    Tim
  8. 1 hour ago, Thunder said:
    Are you going to make the deck layout match the gunports?
    Thunder, welcome onboard, glad you like the build so far, it was your original build that inspired me to start this model.
    Thanks for taking a look and for some very welcome advice.
    You are right I will have to move everything to match the revised gun ports.
    I had been considering doing a sort of "admiralty" style with a stub mast and bowsprit, so no rigging, it's above my current pay grade anyway.
    Could I get away with just moving the things you mention.
    The anchor will also need moving, that was a costly ( in effort ) mistake I made ..............
    Tim
  9. 1 hour ago, iMustBeCrazy said:
    I think she's going to look very nice.
    Thanks for the encouragement.
    remember you are working off different drawings:
    I seem to have difficulty even following the ones I do have 🙂
    Next jobs, glue down the deck, line the bulwarks, fit the spirketting and waterway, then frame the gunports.
    I intend to leave it all natural wood so there will be no hiding any ( more ) mistakes..................
    Tim
  10. 3 hours ago, kgstakes said:
    I see what you mean by the blemish
     thanks for the compliment @kgstakes.
    Here it is with blemish removed, a bit more work than with photoshop, but worth doing.
    a quick coat of WOP ( water based Tamiya matt, thinned). looks much crisper now.
    width of planks is 5mm which at 1:48 equates to about 9.5 inches.
    the gap at the stern top right, will be covered by the pantry or the W.C. can't remember which goes on which side.
    Tim
  11. Got quite a bit done yesterday, deck planked with 5mm white maple from Mantua Models.
    I think it looks good, there are a couple of planks I may replace. I was not taking notice, the brown blemish shows now I have sanded it down.
    here is a close up
    used the soft pencil for the caulking, it was glued to 1mm thick grey card, I have left it loose for the time so I can try other decking.
    what does everyone think of the colour and width?
    Tim
  12. Happy New Year to all onboard.
    I managed to get the wales cut and glued in place, I was really happy with the result.
    Then I went back to figuring out the deck.
    I cut out the deck plan from the original design as drawn by Bill and laid it in place.
    As I looked, the old saying of "measure twice and cut once" sprang to my mind.
    How did I managed to do that?
    I had measured from the transom taking measurements from the side view drawing, it looks like I had got the stern all wrong, it's too long, so that threw out the gun ports.
    Not a lot I can do about it now, so I will crack on and finish this model knowing that it's wrong, I think it should make a nice looking model all the same.
    I don't remember who said it, but apparently "we learn nothing from success."
    Tim
