Posts posted by oakheart
15 minutes ago, iMustBeCrazy said:
Keep a few cotton buds handy,
sanding stick is a fairly flexible
Good tip, Don't know about the spit, depends if I am drinking tea or beer, maybe a jar of distilled water might be better.
Sanding stick looks good, I have some sandpaper glued to a dowel for the lower curved part of the hull which seems to be working.
Tim
1 minute ago, iMustBeCrazy said:
I glue the plank edges.
Thanks Craig, I like that idea.
But as I am going to stain the hull, I would worry about glue getting on the front surface of the planks.
I need to do a test and see what happens if I do.
Tim
Could not resist, I started sanding the planking already done. Using 50 grit sandpaper on a small wood block.
But I have a problem with the 1.5mm thick planks flexing, while I am sanding the hull fair the planks are bending slightly in between bulkheads, I am not even pressing very hard.
This means that the plank on either side gets sanded a little bit more and becomes thinner.
This is sort of difficult to photograph, hope you get the an idea of what's happening.
On my next build I will use more bulkheads, meanwhile I have glued a small strip behind the planks to stop the flexing.
Has anyone else had this problem?
What have others done about it?
Tim
Thanks for the compliment Craig, and everyone for the likes.
10 hours ago, iMustBeCrazy said:a hair (literally) more off the highpoints of strake 5
I have only just noticed that gap between 4 and 5, things show more in photos than in real life.
Not sure if I will take it off and fettle it or not.Tim -
The planking continues.
I made a simple jig to aid cutting the planks into the correct taper.
here it is with the steel straight edge ready to cut the taper
A few planks make it begin to look like a cutter.
the shape begins to appear.
close up of the bow.
Doing the Bounty launch helped me with understanding planking.
I want to stain the Alaskan Yellow Cedar to look like the old models in the RMG collection, so I have been testing a water based wood dye.
Pleased with the result, also found I could not coat with brush on acrylic as the stain runs, so used a rattle can from Halfords.
Tim
3 minutes ago, iMustBeCrazy said:
Well, if I can pull this off the guns will have functioning carriages.
Now, I know you really are crazy.
Tim
So here I am back, it's been a long summer, so much to do.................
Managed to get a bit done on the Speedy. Garboard plank in place on both sides.
while I am plodding away building this 1:48 scale model some people build full size Cutters. Here is the real thing
Luke Powell built the 'Pellew'
https://www.workingsail.co.uk/pellew?itemId=fihssy98q3833wr2jbjrsb17q7mzt6
loads of videos of it on youtube.
and some action video of other Cutters , really shows what it must have been like sailing these craft.
anyway, the sun is shining and I have more garden work to do.
See you soon
Tim
- allanyed, iMustBeCrazy, GrandpaPhil and 3 others
- 6
On 7/14/2023 at 8:03 PM, allanyed said:
If they were indeed Blomefields,
Thanks Allan
For this build I have just gone with whatever Bill Shoulders has shown on his plans.
I have no idea if they are accurate or not.
I will try and find somewhere in the UK where I can get things 3D resin printed, I have tried cannons at this scale on my FDM printer and they do not look good.Tim
18 minutes ago, iMustBeCrazy said:
just screw something (or some things) to the false deck
You are right, I need to : KISS
As the plywood is a bit suspect the blocks will be better.
Just some 4x2 ( measure it first ) blocks on the false deck would do the job.
thanks Craig
Tim
Managed to get some done to the hull over the last few days.
Masked up the keel ready for fairing the bulkheads.
Noticed a fault ( hole ) in the plywood
made a quick and dirty repair
I had to add some temporary beams to strengthen the bulkhead tops while I was sanding.
they will be removed after I have done the planking.
the planks now sit nicely on the bulkheads
I now need to make a jig to hold the hull upside down while I do the planking.
Off to do some research
Tim
- bruce d, iMustBeCrazy and Thukydides
- 3
On 7/4/2023 at 1:00 PM, chris watton said:
released in around 2 weeks
Now I know what my new build will be.
Tim
- mtaylor, Canute, chris watton and 2 others
- 5
While the glue on the bulkheads was drying, I turned to the cannons.
I had ordered a set of Amati barrels and wheels from my favourite model shop
https://www.cornwallmodelboats.co.uk/acatalog/amati-cannon-barrels.html
I drew out the carriage to scale, printed it out then assembled a stack of 2mm thick wood cut to those dimensions, a small strip was glued along each end to hold the block together. The template was pasted on one side of the block.
Then using a jewellers saw cut out the shape of the carriage.
There are a few errors with the cuts, but not too bad overall, a quick touch up with a small fine file.
I ended up with enough to make the required number of carriagesThese were assembled and with the barrel in placed look pretty good,
the barrels are a bit to garish so gave them a coat of matte black that I dabbed on with an old scrubby brush.
Looking good.
But I have just realised looking the photo that the wheels are on the wrong way round, should be the larger at the front, lucky I had not glued them in placeTim
- mtaylor, iMustBeCrazy and bruce d
- 3
7 hours ago, iMustBeCrazy said:
Yours also seems to sit a bit high, have you joined it the same as Thunder did?
Hi Craig
Well spotted, you have a very keen eye, it is high and I did not join it the same as either you, thunder the booklet.
I went off on my own and it worked out wrong, I have no idea where those angles came from?So back the the drawing board, printed out new templates and cut some new parts.
I now need to sand them to the correct angles and glue them up.
Back tomorrow
Tim.
- bruce d, iMustBeCrazy and mtaylor
- 3
Just a couple of small jobs to keep the build moving along.
Glued on a strip of limewood to cover the raw plywood edge.
then added a layer of limewood to the stern. In my next build I really want to make a solid wood stem, keel and stern post.
but for this simple cutter model that I am using to get some practice at planking, this will do.Tomorrow I will cut a rabbet.
Tim
4 hours ago, Igmar said:
Hello.
I build models for customers. Recently I got the idea to open my own channel on YouTube.Hi Igmar welcome to MSW
I am glad to be retired, I used to build models for customers ( not ships )
Will go and have a look at your YouTube channel
Tim
- Ryland Craze, Keith Black and mtaylor
- 3
Yesterday in the workshop I managed to get quite a lot done.
Pasted the paper templates onto the plywood.
then made some sawdust
here are the bulkheads and the 'deck' which holds the whole thing together.
I then glued the rabbet strip on the keel using some 1mm limewood.
I will leave that to dry overnight , then cover the plywood edge grain as well.
A good days work
Tim
- mtaylor, CiscoH, iMustBeCrazy and 1 other
- 4
On 6/8/2023 at 11:00 AM, iMustBeCrazy said:
Update time.
That has turned out fantastically, congratulations.
Gives us all something to strive to achieve.
Tim
- iMustBeCrazy, Montaigne and mtaylor
- 3
9 hours ago, iMustBeCrazy said:
so I designed and built my small Cutter and learned a lot.
I was quite happy with that so I designed and am building my Bounty Launch
And your Bounty Launch is fantastic, I have just been over there to have another look.
So patience and hard work pays off.
For me, I definitely see this small cutter build a step in the right direction.
I am already having new ideas on how the Rattlesnake might be constructed for a PoB model.
Taking ideas from Bill Shoulders original model and mixing it up with modern ideas.
Tim
- mtaylor and iMustBeCrazy
- 2
12 hours ago, bruce d said:
Fun ! I think I may need that Aspirin now..........
Just spent a good ten mins looking for a way to search for a specific name?
Any clues?
I was looking for more detail on the cutter Rattlesnake ( I already have the profile and lines that Craig sent me the link too )
Tim
Le Renard 1812 by iMustBeCrazy - Artesania Latina - 1:50 - early kit version 20305
Did you turn the barrel ?
How is your planking going?
Tim
