Posts posted by oakheart
On 1/22/2023 at 11:53 PM, LFNokia said:
I've finally made the plans available
Thank you for these plans, I may just have to give this a go................. when I finish my small boat of course
Tim
I have now glued up the matching plank pre-bent and faceted the frames.
It looks good, so I think I will continue with this technique until I get round the bend, then up the straighter sides go back to normal.
I saw some one on this forum ( website ) who had planked straight from the Garboard right up to the gunwale in one run, so on this build that is what I am trying out.
As a programmer I was taught "only change one thing at a time" or you won't know what is causing the problem.
Here I have just jumped in with all feet first.Tim
- mtaylor, Wintergreen, Keith Black and 2 others
5
5 hours ago, iMustBeCrazy said:
1: Facet the frames as you have but this leaves a faceted interior
2: hollow out the inside of the planks3: skinnier planks.
4: using hollowed out balsa blocks
5: Only clamp on the frames.
so my take on those options are :
1: Could I live with the faceted inside - Yes, if it's not to noticeable it could be alright
2 : looks like it would be really difficult to do.
3 : Planks are only 0.8 mm ( 1/32 ") going even thinner may work, worth testing, may break.
4 : This would help but may need a lot of clamping pressure and crush the model.
5 : with the clamps I am using that's the only way they work, will try elastic bands
Thanks for all of those ideas, I will see how my faceted frame worked when I un-clamp it later
Tim
- mtaylor and Keith Black
2
52 minutes ago, Montaigne said:
translate many nautical terms
Even native English speakers ( Me ) are having problems interpreting, understanding and remembering the nautical terms used here.
It does sink in over time.
Tim
- Montaigne, Wintergreen, mtaylor and 1 other
4
I have now got to, as Craig said - the interesting bit.
Moving down the frame, now when I lay the plank on the frame, the plank is flat but the frame is curved !
In the photo, I have used a wider plank to exaggerate what happens, the problem is made worse when you can only clamp from one side of the plank.
Sorry - I could not get the phone to focus on the end of the plank, but you can see what's going on.
To overcome this I have just tried a test laying of a plank.
Firstly between the tick marks on the frame, I sanded that area flat.
It's glue up right now, we will see later if it worked.
How do others overcome this?
Is there a trick I am missing?
Tim
- Keith Black and mtaylor
2
1 minute ago, iMustBeCrazy said:
Pushy pushy
No really 🙂 I just want to see how you do it, I am having some problems with mine, so looking for clues.
Just like you said, it gets more interesting.
Tim
- thibaultron and mtaylor
2
12 hours ago, Montaigne said:
Kudos to everyone for sharing their research, ideas and suggestions, and to oakheart: well done so far, it's looking good!
Thanks for the compliments.
Allan and Craig are the experts here, There is a load of information on the their other logs as well.I'm just here having a load of fun doing some research, trying new ideas and learning new skills.
Question : Should all of the detailed information be collected together and put it in the "launch details" log.
Who started that log ?
was it Craig or Allan? my memory is not so good
Tim
2
1 hour ago, iMustBeCrazy said:
Something went wrong
Don't you just hate it when that happens.
It's looking really good.
Are you ready to start on the planking?
Tim
- iMustBeCrazy, thibaultron and mtaylor
3
Based on what Druxey advised I borrowed a heating tool from a model aircraft mate.
and bent the plank.
It really makes it easier to fit.
Tim
- mtaylor, Montaigne, iMustBeCrazy and 2 others
5
16 minutes ago, druxey said:
bed that garboard down more.
Thanks for the tip Druxey, I think when I do the next version in Cedar, I do some pre bending as you suggest
it would mean less clamping neededTim
2
On 1/22/2023 at 12:49 PM, CiscoH said:
planking looks great!
Thanks for the compliment cisco
After sanding down I'm sure my planks will be uneven thickness.
Tim
2
29 minutes ago, iMustBeCrazy said:
then it gets a bit more interesting.
Thanks for the encouragement, even more interesting 🙂
This is actually pretty good at getting me to slow down and not rush, rush to get onto the next thing.
Tim
2
Okay here as promised the next installment.
Got three planks in place over the last couple of days, taking it slow.
Third plank clamped in place
here is a close up after the clamps have been removed, a bit of clean up needed but pleased with it.
onto the 4th plank
There is a a bit of a step of levels here, I think it's because the first plank did not glue down tight to the frame, hope I can sand the new plank level without sanding right through it.
here is a view of the whole thing, pretty pleased so far
comments please
Tim
- mtaylor, Knocklouder, Prowler901 and 4 others
7
- mtaylor, Wintergreen and Keith Black
3
3 hours ago, iMustBeCrazy said:
tabs to the moulds to support the frames while fairing.
That looks looks like it should do the job, nicely done.
Tim
8 hours ago, Jnorton1946 said:
Good work so far, looking forward to seeing your progress in future posts.
Thanks James, I will keep recording what I manage to get done, mistakes and all, as Håkan said it's a learning process.
Tim
- Wintergreen and Keith Black
2
1 hour ago, Wintergreen said:
Tim, it's a learning process and looks like you're doing good.
Keep it up!
Thanks for the encouragement, it means a lot.
Tim
ps .I think my next model after I have finished this pair may well be a kit........
- Keith Black, mtaylor and Wintergreen
3
So here we go.
First plank in place, used PVA with long open time so I had time to get it in the right place.
Let it glue up overnight.
very pleased with the no rabbet, just beveled the plank and you can hardly see the join..............
1 down 15 more to do.........
Tim
- Wintergreen, iMustBeCrazy, tkay11 and 5 others
8
2 hours ago, allanyed said:
and yields planking that looks like a real vessel.
Well we hope so !
Thanks for all of your support here Allan, and everyone else, I could not of got to this point without it.Tim
2
Finally got this thing lined out, cotton seemed to work. Not sure about the stem end?
This was really what I should have done before I tried to understand the planking, it really helps.
Now to transfer this to templates.
Most of it looks pretty straight foward, but I'm not sure how I measure and transfer the area between Station H and the stem the cotton is stretched in straight line but i need a curve
how best to proceed here?
Any advice would be welcome.
Ignore the broken temporary square section, it had a nice curve then snapped, I should have soaked , live and learn
Tim
- Knocklouder, tkay11, Gregory and 5 others
8
OK decision made at least for the first of the two builds, this will be the 'dirty' boat.
No rabbet on this one, using the ply keel as it will be covered in tar/pitch as per Blights log.
I am not happy with the way the futtocks cut out of the molds ( frames) the scroll saw seemed to have a mind of it's own today....
Still I should be able to clean up a bit when I have planked it.
It's all glued up now so in the morning when the glue is hard, the transom needs fairing.
Then I can line it out
Not sure whether to use cotton or thin tape to do the lining having never done it before, maybe try each on different sides
Then I can get on with cutting the planks ( spilling ) to fit
Tim
- ccoyle, iMustBeCrazy, CiscoH and 3 others
6
47 minutes ago, iMustBeCrazy said:
It looks a little like a boat.
That is looking really good.
Can't wait to see the planking go on.
Tim
Welcome Wizard, only a couple of weeks ago I was welcomed here as a newbie, I have found it a great place with lots of helpful knowledgeable people.
Love you first build.
Tim
- Dave_E, Edwardkenway, Keith Black and 3 others
6
HMS Bounty Launch by Oakheart - FINISHED - Scale 1:24 – 18th century - based on drawings from National Maritime Museum
Waiting for the 5th plank to dry, trawling through the incredible amount of build logs there are here on MSW.
I found this build log : https://modelshipworld.com/topic/3741-queen-annes-revenge-1710-by-shipmodel-finished-136-scale/
Thanks shipmodel ( Dan ) your work on the QAR boats gives me a goal to work towards. It has re-inspired me, my planking was beginning to get to me.
I know this is only a tiny model but it is testing me.
Reading the QAR log I'm being tempted towards a larger project, like a pirate ship or a Bounty.
But I really do need to finish my launch first. I am too easily tempted into a new project, leaving a trail of part finished models in my wake
Tim
