marktiedens
NRG Member-
Everything posted by marktiedens
Yes,very impressive,although the kit supplied casting is very good also. Mark
- 652 replies
- royal william
- euromodel
Wow Pete,that`s one nice figurehead! Thanks Mike - your kind words are much appreciated. Thanks also to everyone hitting the like button. Mark
- 652 replies
- royal william
- euromodel
Thanks Pete - yes,a bit tricky. There is some deflection as it is nearly impossible to rig the backstay without a little deflection. Mark
- 652 replies
- royal william
- euromodel
- 652 replies
- royal william
- euromodel
Hi Ken - here are a few pictures for you. There are a few more in my log on page 16 - the log entries are not numbered,but if you scroll about half way down you will see them. Mark
- 424 replies
I decided to fix an error - the cleats on the fore & main masts for the preventer stays should have been just one on the forward surface of the mast instead of two on the sides,so I removed the ones on the sides & added the ones on the forward sides of the masts. Mark
- 652 replies
- royal william
- euromodel
Thank you very much,Edwin - your thoughts are appreciated. Mark
- 652 replies
- royal william
- euromodel
Thanks,Michael - yes,I am using Chuck`s rope for all but the smallest lines. I am using sewing thread for those. Nothing really wrong with the kit rope - just too fuzzy like all kit rope. All the kit rope is light tan & I was having trouble darkening it consistently & once I did,it got too stiff to work with. I already had most of what I needed anyway. Mark
- 652 replies
- royal william
- euromodel
Hi mates - another update. The main stay & preventer stay are now done,as well as the snaking. The fore & main top crowsfeet are done also. 2mm rope was used for the main stay & 1.6mm rope for the preventer stay. As always,thanks for looking in. Mark
- 652 replies
- royal william
- euromodel
Thanks Frank - getting better every day. Mark
- 652 replies
- royal william
- euromodel
Another little update - I have got the fore stay & preventer stay done & snaked.I should be further along,but I am fighting a nasty cold,so not getting a whole lot done right now. Mark
- 652 replies
- royal william
- euromodel
Another little update - after re-doing the bowsprit mast ratlines,the bowsprit was set in place. The gammoning was then done & the rack blocks were made from some walnut strips & set in place. Finally,the bobstays were rigged to the stem & bowsprit. Mark
- 652 replies
- royal william
- euromodel
Another little update - I thought I would take a little break from rigging & add some nails to the wales as Ken did on his RW. The nails I used are from the railroad area of my local hobby shop. They are called track pins & the nice thing about them is they are already blackened . Mark
- 652 replies
- royal william
- euromodel
Thanks Pete - yes, it is starting to come "alive" now. I`m trying not to rush through it & mess it up. Mark
- 652 replies
- royal william
- euromodel
Hi mates & thanks for looking in. A little more progress made - I have finished installing the main & mizzen mast back stays & the mizzen stays. The crowsfeet at the mizzen top are also done. The shroud cleats provided are really nice,but looked a little large on the mizzen stay,so I had one a little smaller that I used. I will use the kit ones on the other areas where they are needed. Just about time to install that fragile bowsprit & hope I don`t snap it off while turning the ship back & forth. Mark
- 652 replies
- royal william
- euromodel
95% coverage where I`m at,but it was cloudy & raining so I didn`t really get a good look. Mark
Thanks,ragove - happy to have them done. By the way,I think I forgot to mention the ratlines are standard Coats & Clark sewing thread & the spacing was done by eye. Mark
- 652 replies
- royal william
- euromodel
- 652 replies
- royal william
- euromodel
Update - All the ratlines are now done. A real test of eyesight & patience. Next up will be the stays. Mark
- 652 replies
- royal william
- euromodel
