Posts posted by NenadM
- usedtosail, BLACK VIKING, mtaylor and 3 others
- 6
Next attempt, with holes for little hooks, drilled before soldering, and with front cover.
Dia of rings: 4mm upper, 5mm lower. For me, it is impossible to solder hooks on rings in this scale, so I decided to drill holes, and to mount hooks after final mounting when time comes to mount whole spar on it's place. In next post you will see what I mean.
In this point rise question about material for hooks, which max dia is 1mm. For now, I am considering posibility to make them from staples 😲
- GrandpaPhil, cog, popeye the sailor and 1 other
- 4
Go on!
CS needs patience and skill
Nenad
Hello and good luck.
Answer to your questions, particulary colors, depends how you imagine your model to look like - in which period of Her life. I have done some research, and decided to show her in present stage, mainly there are many useful photos if Her on internet
"Coopering" ... 4000 pieces to put them in scale as on C plans ... a lot of them...
If you are not a kind of "hot head" self testing monkey as me, main filter what to do or not is simple question - will it be visible at all?
Pls let ne know when you start your log
All the best
- Vladimir_Wairoa and mtaylor
- 2
On 5/23/2020 at 9:40 AM, Vladimir_Wairoa said:
Hello Nenad, been eyeing your build here and there, hat off in that scale lovely work, go on continue. i am about to fiddle around bowsprit as wel. Vladimir
Hello Vladimir, and wellcome!
9 hours ago, Kevin said:
just read your log from the start, lovely work, and an enjoyable couple of hours, thank you
Wellcome Kevin!
- mtaylor, cog and popeye the sailor
- 3
Preparing for Jib Boom in Adobe Acrobat
18 hours ago, samson said:
Only playing, learning engrave. Nothing more than artistic piece of wood, maybe a gift for someone
Keep on good work!
Very nice work !!!!!
- popeye the sailor and samson
- 2
CORONA impacted everything.
Courts are closed, my job stops, and I am docked in house, going out only for neccessary shoping
So, days are long, but filled with domestic and garden works.
And naturaly, all of my another hobbies are activated (guitar, painting, writeing short novels, wood carving, cooking, gardening, book reading, music research, history research, furniture making, home decorating, and some kind of internet social life ... ) so, days are short again ...
So, Her Majesty is on a hold for a while ..
I hope that you all are well and healthy
See you soon
- cog, mtaylor, popeye the sailor and 2 others
- 5
On 2/18/2020 at 2:09 AM, keelhauled said:
Great progress, Nenad!
she is looking wonderful! So much to be proud of.
Take your time with the rigging. Always check the placement of your hands and your lines. No long sleeves. You'll be fine!
Are you going to rig her with sails?
best
Marc
Ou, yeah! With all sails and with stunsails too !!!!
Ambitious madman
On 1/25/2020 at 2:56 PM, samson said:
then we are two who build without a professional background, but if you stick to the drawings and many photos of the details then we can probably com thrug this vith stile .
Jens.
So, here we go ... some kind modelbuilding for dummies
I hope you will, and I kindly ask all of you, as much experienced modellers, to check attached photo, and to correct me with adequate names of masts and yards
Little explanation. My country is continental, and throught the history, sailing with clippers particulary was not possible, so, in Serbian language, there are not adequate terms for this
I made some kind of draft drawing, just as reminder of order for further research of any particulary part, as beggining and entrance to deep and dark forest named masting and rigging
- keelhauled, michael mott, mtaylor and 5 others
- 8
Hello to all
I am forcing myself to learn about masts, yards, spars, rope lines, sails, and all little parts, about which I know - absolutely nothing!
A lot to learn about, particullary because for a most of them, there are not Serbian words
Enough for solid headache
I thing that, without understanding what really happens there, it can not be done on adequate way. Also, informations I collect can help me to decide what to make accurate, and what not to make, or to make in artistic or apromaximate way
Time demanding stage of build, in my case. All is, on some way, connected with all another !
Wish me luck and patience
- mtaylor, popeye the sailor, jud and 2 others
- 5
Cutty Sark by NenadM
Thank you, Vlad. As I said somewhere in this, I think, the slowest build on MSW log, couple of years ago, I made terrible mistakes with lines of main deck, so, I decided to overdetail Her Majesty, to try to "pull up" whole thing. That approach lead me to this ... ant work ... (which is, really - nothing, comparing what, for instance, MSW member Igor Sky do!!!!)
However, it is fun to test your own limits, and to learn.
Thank you for watching and following
