Everything posted by captainbob
Thanks for sharing your learning curve on the sails. It's good to know. Your last try is looking very good. Bob
- 135 replies
- willie l bennett
- model shipways
As usual I'm late to the party. Very good on the cross planked hull and the deck framing is great. Think I'll stick around. Bob
- 97 replies
- Willie L Bennett
- SkipJack
I couldn't agree more. You're projects are a joy to watch. Bob
- 2,215 replies
Mark, The pads are old 1000 grit sand paper so I wouldn't slip as I went in. Popeye, Placed wide blue masking tape covering the deck and the first coat is drying as we speak. Bob
Wayne, she hasn’t said anything yet, so don’t say it too loud. Thanks, John, I thought the table needed something. Yes, Michael, Old jeans come in handy at times. Bob
I probably should have painted the hull first, Popeye. I’m sorry but I did it again. I got carried away building and forgot to take pictures. Anyway I built the cabin furniture so I could put it in before I put on the sub-deck. I put pads on the benches and backs and added a chart on the table. The brown shelf has a step in the middle and another on the cabin deck. That’s it for now. Bob
I hear that some modelers use a mill to help make some of the parts for their models. What parts do you use the mill on? I'm considering buying a mill but I don't know if it will help. Bob
If that emblem is sewn on with out seams in it. It would be a very wide piece of cloth. Bob
Nice looking hull. Inside and out. Bob
- 153 replies
- model shipways
- bounty launch
Well done, Mario. Another masterpiece for your shelf. Bob
- 78 replies
- victorian steam launch
- constructo
Wood filler vs. spackle
captainbob replied to rtropp's topic in Building, Framing, Planking and plating a ships hull and deck
I've never tried. I tend to paint my boats. The container says to test the stain on a scrap piece. But since it is made by Elmer's I would expect it to stain the same as Elmer's white glue and sawdust. Bob -
I wasn't sure so I went out and cut a curve. If you are cutting a convex curve you can rotate the material very close to the cutting edge of the blade and by cutting off a little at a time, make very small discs. The problem is with the concave curve where the thickness of the blade and the width of the blade causes binding as you cut the curve. The tightest I could cut with my 3/8" blade was a 1 3/8" (35mm) radius or a 2 3/4" (70mm) inside diameter. The boat I am making now is 30 feet long. At 1:48 scale the beam is 2 1/2". For this the scroll saw is what I used. Bob
Mario, Once again, beautiful work. Bob
- 78 replies
- constructo
90% of my builds is bass wood. But I did not make it clear, I use "Elmer's Wood Filler". It is a water based filler and comes as a paste. I use it straight for large fills. I also put some in a small jar and add water to the consistency of heavy cream. This I paint on to take care of the smaller scratches. Bob -
Go look at my Malabar Jr. I just posted pictures of the hull after filling with Elmer's. Bob -
I did some more sanding and added the keel. Filled the cracks and blended in the keel with filler. Now a little more sanding and I’ll be ready to paint. Bob
Mark, They say for your brains sake "You should learn something everyday". That's easy when you forget what you know. So I'm learning all sorts of things (again) My brain should be in fine shape.
