Everything posted by wefalck
I have simulated wire rope by twisting together strands of copper wire and then painting them in some dull silver colour. One can also get at a reasonable price silver wire down to 0.007 mm(!) diameter (which is used to bridge broken printed circuit connections in repairs, I believe). It is difficult, however, to twist more than two wire together evenly. For simulating rigging wire, it should not be twisted too tightly, as in real wire rope the angle of the strands is less than for fibre ropes. There is also some (expensive!) japanese fishing line in steel grey, which seems to be braided with four strands. I have not seen it in real life, but it may be worthwhile exploring: https://www.ebay.de/itm/284004752603?var=585466534836
- 330 replies
A bit bizarre that someone in distant Mexico/USA should build a model of an 'Emspünte' ... Unfortunately, I would have only technology solutions for your anchor-problem, I would either solder the grapnel up from brass wire or perhaps making a design for laser-cutting from paper stiffened with varnish. Actually, if you can get hold of some wire, material doesn't matter too much, you could bend four 'fish-hooks', bundle and tie them with some threads and smear the whole assembly in white glue. I think the village blacksmith would have used a similar process to make the real thing, using rebar or whatever iron rod would have been available, bending them and welding them together, adding reenforcing sleeves to the shank.
- 286 replies
If you don't dare to take on splicing, you can also just make ring with an overhand-knot, put the block in and a pin for keeping the eye open at the other end. You then start the seizing with a series of half-hitches until you reached the desired length of the seizing. Then you pull on the loose ends of the strop to shorten it to the desired length. Fix the seizing with a dab of varnish or paint and trim the loose ends of the strop and the seizing respectively. On a real ship the stropping would have been done in situ, but on a model it would be better to do the stropping off the boat with the ring slipped over the traveller and only then to install the traveller.
Seizing Blocks With Alternate Half Hitch Knots
wefalck replied to Glenn-UK's topic in Masting, rigging and sails
Thanks for showing this in a video. I have used half-hitches actually ever since I got into this kind of ship-modelling. I don't use CA glue though, but rather fast-drying varnish, so that I can slip thing up tight against the block, if needed by just a drop of solvent. However, it seems to me that you are using a series of overhand-knots rather than half-hitches !? Of course, this works well. -
You don't mention the scale, but it is possible to make simplified long-splices by pulling the ends through each other with the help of e.g. a hypodermic needle as marlin-spike. You then dab the splice in varnish and roll it between your fingers. Then you basically proceed with full-scale practice and tie the strop around the block and the ring on the traveller. The splice will disappear under the seizing.
Looking good! I gather the book on catalan lateen-rigged boat that you got, will give some more ideas on the specificities of that rig. One of these is that the parrel is a sort of rope with an eye at its end that goes around the mast and is fixed to the halliard. The purpose is to be able to loosen the parrel to allow a better adjustment of the antenna. Not sure though, whether this would be case on the more lugger-sail like sail of the canoa here. On the photo below from the Albufera near Valencia (Spain), the parrel is a pretty ugly affair, not quite ship-shape: Probably your photographs don't show such detail, but usually the rope that attaches the sail to the yard is not just wound around, but at each grommet there is a half-hitch - I don't have an image to hand that would show this. In that way, the sail has less a tendency of slipping along the yard or pulling out of shape.
- 286 replies
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Just wondered why 'Spring Chores', as we are heading now into the Christmas period - but of course, you guys down under are not only standing on your heads, but also got the calendar wrong Here it is mulled wine time, not cocktail time ...- 993 replies
- gun dispatch vessel
- victoria
The Heritage and Education Centre ship model series
wefalck replied to tkay11's topic in Nautical/Naval History
Thanks for the links, have to look into this - just revisted the Sjöhistoriska Museet in Stockholm three weeks ago - one of the last of the maritime museums that really seems to appreciate its model collection. -
Hope you don't need to repaint your models now - we were quite happy with the colour schemes of the woods etc. BTW, Gratulations to the successful surgery! I gather it is like getting new glasses: the brain has to readjust the images to the perceived realities.
How could I know, that you are working on three projects at the same time ... so I missed the beginning 🙄 Very good subject! I doesn't always have to be a VICTORY cross-section ! I know very well the space and mobility problem.
Self-centering 4-jaw-chucks are far and between, because they can and should only be used on square stock or parts. Sherline does offer one of the hobby market and that is the only one I am aware of. Independent 4-jaw-chucks are very common and are either used for precision centring of round stock/parts with the help of dial indicator or, indeed, for irregular/rectangular/square stock/parts. There are many offers on the hobby market. Sometimes and particularly in the USA independent 4-jaw-chucks are confused with faceplates with moveable jaws. Chucks, however, are meant to take up longer stock/parts, while faceplates are meant for mounting short stock/parts on their surface. On faceplates the jaws are sitting on the surface, while in chucks the jaws move in T-slotted or dove-tailed slots. Incidentally, chucks with dove-tailed slots are rather rare today. Normally, either solid jaws run in a sort of douple T-slot or the jaws are in two parts, so that the top-jaws can be reversed or exchanged for other types of jaws. 4-jaw-chucks and faceplates have to be operated with caution, as the excentric load can cause vibrations and light machines to jump around, when not fixed to the workbench. As far as I remember, PROXXON offers a metal and a plastic chuck for its light wood-lathe. The idea is that with plastic jaws there is less risk of marring the material. I am curious what lathe you are using that has a 16x1.5 spindle-thread?
Method of securing the mizzen outrigger on a Cutter
wefalck replied to Thukydides's topic in Masting, rigging and sails
To me it looks, as if the boom runs in at deck level. It then could be secured on deck with wooden cleats and a stopper block at the inner end. -
A new angle in precision sanding
wefalck replied to Arcticbeaver's topic in Modeling tools and Workshop Equipment
Edges round in which direction? -
Yep, with a bit of putty and a few tools, one can quite easily adapt commercial figures. However, 3D-printing in acrylic resins is the future. It may be worthwhile contacting sellers on the commercial platforms, such as shapeways, in order to see, whether they can/are willing to print their figures in different scales. While upscaling or downscaling over a large scale range may not be feasible for reasons of resolution, a change from 1/72 to 1/80 or from 1/87 to 1/80 should not pose a big problem.
- 392 replies
Wow, this is quite a price tag for those two tools, even though they look sturdy and well-engineered. If something melts or burns during machining, that means you are putting too much energy in a too short time-span into it. Reducing the energy helps. If you have a 220V/110V sander, you can reduce its rpms (and hence the energy put into the process) by running it off a dimmer, if doesn't have already a speed control. I also found that diamond tools work better on plastics (acrylic glass, polystyrene, etc.) than carborundum abrasives, so I am using diamond grinding discs on my micro-sander.
