Everything posted by wefalck
Watchmakers and jewellers indeed use aprons. Watchmakers generally use cloth, while those of jewellers are made from leather. The latter clip to the underside of their workbenches, so that they can recover precious metal filings. It also protects them when silver-soldering. I have been wearing aprons in the workshop for decades. However, I found that small pieces mostly either bounce off, or just drop besides ...
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Pat, are you making your own rope? If so, you could try some 18/0 fly-tying yarn (I found the Danish Veevus a good brand), which should you get down to 0.1 mm or even below, if you split the two-ply yarn and make two lengths of three-strand from three lengths of the two-ply yarns.- 993 replies
- gun dispatch vessel
- victoria
Ah RR-apprentice at work - love this filing-button work, that shows the toolmaking approach. I could think of two uses for these strops at the end of the boom: either they are some sort of footropes (well HSE rules apply, when you have a professional crew, but it may depend on the country of registration) or they are sort of bridles to grab and help the boom shift, when going through the wind.
Looking good, Pat! Just wondered, whether you couldn't have used some solid round brass, turned down the OD and drilled/bored out the ID to fit? When parting off with a saw, I would do this on the lathe, running at low RPM. I usually make a first cut with an cut-off tool to provide a guide for the saw and then finish it off with the latter.- 993 replies
- victoria
Well, now you have the link to maritime subjects In fact, quite a few colours i.e. pigments were available, sometimes since antiquity, but cost variied considerable. Lamp-black was among the cheapest, easy to produce and intensive (meaning the amount of pigment needed to achieve a good coverage) pigments. Earth colours (e.g. the various types of ochres, ranging from pale yellow to a blueish red) were also cheap. White lead is/was also cheap and had a good intensity. Other lead oxides (menninge) were used extensively as rust protection. Chalk or lime is even cheaper, but chemical reasons cannto be worked into oil-paints. However, it was intensively used as white-wash, as lime solutions also have anti-microbial properties (not know as such at the time, but white-washed environments where 'healthier', hence its intensive use on shipboard, hospitals, private houses etc.). I have been researching paints for (German) later 19th century warships quite bit, and it seems that well to the end of that century, paints were delivered as their components to the ships, that is the pigments, the binder (oil), and thinners separately. Paints were mixed up by weight and volume of the ingredients on the spot and would not have had a long shelf-life. Certain paints, however, such as anti-fouling paints, became commercially available from the later 1860s onwards. This means that the actual shades of 'battleship'-grey or yellow for masts and funnels could vary from ship to ship and even across a ship. Grey for warships became gradually the rule from the mid 1890s on, but the greys of the different navies differed a lot. Machine tools were almost always painted black until the end of the 19th century, particularly the bigger ones. Then, indeed, grey became more common to light up dark workshop and to see better what happens. Precision machinery then often became painted dark green or other shades of green. In Germany, for instance, the standard colour became 'Reseda-green' in around the 1930s, almost until today. Some (precision machine tool) manufacturers, e.g. Schaublin, Bergeon etc., choose specific standardised colours, such as blue or pale yellow.
That’s an ingenious way of making boat-shells. I would not have thought of using galvanoplastics for that. However, as you have the set-up already for e.g. the ventilators it’s logic.
The machine begins to look like one 👍 The fishbelly-shape serves to stiffen the link against buckling, when longitudinal stress is applied, and to reduce the moving mass at the same time, compared to using the same width all along. Reducing these masses is important, as they have to be accelerated and then decelerated at each stroke. At this time engineers had only limited means to calculate the static stresses on such parts and basically no means to calculated the dynamic stresses. As you can often on say connecting rods in steam-locomotives, the interior has been thinned, leaving basically a bar on both sides with a sheet of metal spanned out between - effectivelly like a fishbelly girder-bridge. Such parts would have been moulded and cast. A question: why did you turn the pivot-pins and did not use precision ground 1/8" rod and ream the holes to size? And another observation: I tend to start-tap holes in the milling machine with head in the same position as for drilling the hole. This ensures verticality. I utilise the backlash on the vertical spindle, lowering the head to the bottom of dead move, advance the tap perhaps half a turn, then again taking out the backlash, and so forth. I usually do this only for a couple of threads, until the tap has securily grabbed, and finish off tapping away from the machine.
Here in Europe, after Putin is turnig off our gas-supplies, we are firing up again old coal-fired power-stations that were kept on stand-by. Problem is that in many European countries coal-mining has been phased out, the only major European producer is Poland. Much of our needs now come from as far as South Africa and even Australia. Those guys running museum steam engines and the likes feel that in their pocket ... Back to the topic of machining now!
A bit off-topic: it seems that at some stage RR made their own lathes - http://www.lathes.co.uk/rolls-royce/. I looked again at this page, because I thought that there might be a shot of Sir Henry' lathe, but not. You wouldn't remember what make it was?
Well, as I said earlier, there are many different alternative truths and alternative terminologies. There is no good in having strong feelings about these things. I sometimes extrapolate from my native German language and there - to my knowledge, we only have the term 'Schnaumast'. Another thing to keep in mind is that our ancestors were much less obsessed with terminology than we are today. I gather this terminology-obsession is due to the various maritime dictionaries that began to become proliferated from the middle of the 19th century on in particular. Also, the increasing presence of the Navy in various societies fostered the obsession with terminology, I believe.
In fact many railway steam-locomotives had such bearings. They need a lot of oil to keep them cool and are only suitable for relatively low speeds, as overheating could melt the metal Again, this avoided complicated set-ups for boring and honing of multiple bearings. I think they were also used on ships' propeller-shafts for the same alignment reasons. But I gather more often pock- or iron-wood bearings were used.
By the colour of the material of the crankshat/beam bearings, I would also say that thei are bronze. In full-size practice often Babbit-bearings were used: the housings of the bearings were carefully installed in place and then the shaft put into place, wedging it tight so that is does not move and does not touch the housings; in a next step the ring-space in the housing was filled with molten Babbit- white-metal. In this way, the bearing surfaces were all aligned without complicated boring and shimming operations.
Well, a snow (or Schnau in German) is a special variety: it has a sort thinner mast attached to the back of the main-mast, the snow-mast. The purpose is to allow the gaff to be lowered without interfering with the parrel of main-yard. Occasionally, multi-masted or even barques had such snow-masts fitted. The snow-mast largey disappeared in the second quarter of the 19th century, at least over here in Europe.
For rigging work I use Castrovejo eye-surgery scissors. They come in various sizes and straight (pictured in one of the earlier posts above) and curved, which is good for close cuts. I also use a holder for broken-off pieces of razor-blade, again from the surgical department.
I was also hurt by this crash (which seems to be a long, long time ago ...) and henceforth drafted my building logs in MS Word first, to be copied and pasted into the Forum. In this way I have a record of my respective contributions. However, I do not keep such records on comments I make in other threads.
Jon, I think the subject can be a treacherous field. Today, we seem to have a relatively clear terminology, even though there are differences in usage between the US, the UK, and continental Europe. However, if you go to historical records, the terminology tends to be less clear. The same ship may be referred to in different records by a different classification. In addition, there were in the past various rigs, that we today would consider sort of hybrid forms and that do not fit our modern terminology very well. The hermaphrodite brig is a good example, as already the name indicates, something 'in between'. Arguing about terminology is rather futile. I don't have strong feelings about the subject and only stumbled about it here, because for me the 'brig' is one of the relatively clear definition, because it is a vessel with two full-rigged masts, i.e. masts with top- and top-gallant masts. As soon as one of the masts only has a top-mast, things tend to become more complicated. And don't think of the Mediterranean, where the so-called Polacca-rig, i.e. where at least mast and top-gallant were one piece ... Carry on with the good work and research !
Pat, good to see more progress here and welcome to the club of close-up-photography-haters Could it be that the booms were actually stowed somewhere on deck? Lower stun'sails typically were only set on long-haul tacks, in a chase etc., so actually not very often. In harbour they may also have been used as boat-booms, i.e. the boats were tied to them - there would a safety line running above so that the crew could run along the boom and then climb down into the boats using a rope ladder. In any case, it seems to be more likely that this gear was stowed on deck, where it would be also less exposed to the action of the sea.- 993 replies
- victoria
Master class from Pavel Nikitin
wefalck replied to a topic in Painting, finishing and weathering products and techniques
It's actually a sort of intermediate between staining and applying translucent washes with an airbrush. This is an established technique among plastic modellers. There is nothing wrong with that. It's just that the model was quite poorly built (look at the gaps under the capping rails) and the colour-scheme reminds me of those 'decorative' or 'tourist' models of old ... -
It popped up on my YouTube recommendations and I watched it - not impressed, to be honest ... -
Ah, I like those small mid-19th century merchant vessels! Will be following further progress. Just wondering, why you call her a brig. According to the terminology I learned, she would be a schooner-brig, because she has one full-rigged mast and a schooner-mast with a top-mast only, no square sails and no topgallant-mast. A brig would have two full-rigged masts.
Again, another very nice 'Baron' ! I love those small sailing craft from the southern shore of the Baltic. Some years ago I organised the annual meeting of our German Association for Shipbuilding History in the Nautineum, a museum of Baltic maritime history on Dänholm Island, just off the old Hanseactic city of Stralsund: https://www.nautineum.de/sammlungen/fischerei. The have a nice collection of regional boats and the centre-piece is a (replica) Zeesboot. In fact, quite a few of these have survived (through the GDR days) by having been converted to pleasure boats.
