Everything posted by wefalck
I don't have one of those CNC-embossing machines, but thought it might be useful for exactly that purpose. Many years ago, I built an early iron tug-boat and simulated the plating in the traditional way, using a taylor's copying wheel. Then I wanted sharp positive rivet heads and did the embossing on a piece of linoleum. This surface is quite tough, but flexible. The embossing tool pulled up cone-shaped depressions, but I put the copper sheet on a harder surface and then rubbed it lightly on the back with a piece of round wooden dowel, which pushed the cones back in, leaving clean rivet heads on the other side. Want I wanted to say with that is, that it may be worthwhile experimenting with materials of different hardness/toughness under the copper being embossed in order to control or modulate the shape of the embossed marks.
I suppose it depends on how trusting you are in your rope and how quickly you want to strike the rigging. In ships' boats this usually has to be done fast and in perhaps rough conditions, so minimal rigging would be of advantage. On the other hand it looks, as if the set up of the forestay would not be so easy to loosen, there is a lot of friction in the deadeye and the holes in the stem. But then, it may be only necessary to lift up the mast by a couple of inches in order to get it clear of the mast-spur. Then it could be laid down.
Yes, but going down to the keel. Not sure how it would be made fast there at that time. Perhaps a single block and then a belaying point at the shelves?
Cleaning and Priming metal
wefalck replied to Cleat's topic in Metal Work, Soldering and Metal Fittings
If the flux is just citric acid, chances are that you have it already in your kitchen as de-scaler for coffee-machines and the likes. Over here in Europe we buy it in 500 g boxes in powder form in supermarkets. Just dissolve the crystals in distilled water (preferably), as the carbonate-hardness of the tap-water would consume some of the acid. -
I don't know about 18th century practices, but in my late 19th/early 20th century boat reference books such stay were taken to floor. However, the yards then were much steeper and would clear the stay and the foresail had no boom. One option is to set it flying, so that it can be cast loose, when tacking etc.
It indeed evokes the feeling that the crews on these little ships crossing the oceans were all on their own ...
How were they launched in the US those days? I know of several European paintings of the same period, where the ships were launched fully rigged with sails on etc., I mean new ships, not ships hauled out for repair. May look unusual to the modern eye, but would allow one to show the rig too.
Oh yes, I forgot about her wheel. That makes perfect sense to show it with a mirror underneath ...
The museum's model is barque-rigged. Shown below in the old setting, before the museum was closed for refurbishment.
The AAMM plans for LA GLOIRE are based on the large-scale model in the museum's collection and various contemporary plans.
Looking very impressive indeed 👍 I actually thought that she would be sitting directly on the board, evoking muddy waters around her, as someone was hinting at above.
I suppose in your area the local softwood, such as pine or cedar would have been used, as it was abundant and easy to cut into planks.
Things evolved differently on both sides of the Big Pond and in the various European countries. I was quite astonished to see, when I first started to go to England in 1972, that even young office clerks and the likes would wear three-piece suits - mind you they often were in dark green, brown, bourdeaux and with (slight) bell-bottoms at that time. Also ties were of the 'plaice' style and colourful. At the same time the suit had almost disappeared almost everywhere in my home country, Germany. It had a brief revival in the early 1990s, but generally badly cut with too long sleeves and hanging shoulders ... When I moved to the UK in the mid-1980s, many (if not most) 'white collar' workers above 30 or so wore ties in the office, however shabby they might have been dressed otherwise. My father to the very end normally wore white shirts and a tie. Allowance was made during vacations, when travelling, when the shirt could have been grey or blue, but jacket and tie were always there. Sic transit gloria mundi ... or as Karl Lagerfeld seems to have put it: "Them, who wear track-suits, have lost control over their lives". As to workplace-safety: when working with machinery, my father always rolled up the shirt-sleeves inside. Apparently, he was taught this by his father, who was a trained locksmith and mechanic. And: What is the difference between the UK and Germany? British men, when sitting down in a meeting room take off their jackets and loosen their ties; later, when going to the pub they straighten their ties and put on their jackets. In Germany it is the other way around.
You didn't have an 1/16" end-mill ? That would have been another option for milling the slots into the jaws. Or to make a low-profile saw-holder that uses an internal thread and a screw to clamp the saw. Putting a plate in front of the chuck-body is avoiding to have to use a T-slot cutter, but from an engineering point of view is a weaker design than a solid body.
Indeed, and I would not use it on thick stock, where lots of material is to be removed. However, I am using sometimes the 20 to 40 mm diameter versions on the saw table of my lathe for thin stuff. Make sure you get a cutting-saw, that is one where the coating is on the rim and extends some mm on the side surfaces. Disks that are covered all over in diamond are for grinding and may get stuck, as there is no clearance when you feed them in further.
I think Underhill's book has a sketch for this arrangement, but I may be mistaken, as such detail drawings are a bit dispersed around the book. Basically, the eyesplice of the block is fed through the cringle and then turned over it - a simple, straightforward operation, but difficult to describe ...
Internally stropped blocks are mechanically a better solution, because the iron strop support the axle closer to the sheave. However, I think, they only became practical, when rolled iron bars became available in larger quantities from around the second quarter of the 19th century on. Calibrated iron bar allows to mass-produce the block-shells on machines, as the slot for bar can be milled to a given dimension, rather than being fitted to each strop. Internally stropped blocks would be found in locations, where heavier strain is expected and where there is no risk that they would chafe sails. In locations where the latter may be a risk, rope-stropped blocks were preferred for a long time. Underhill's book on rigging would be an appropriate source for the 1860s details.
On the Internet you can find all sorts of sizes and grades of diamond-coated cutting saws. They are not only used in tile etc. cutting, but also for cutting gem-stones.
