Mike Y
Everything posted by Mike Y
  1. All parts of the case are finished, so starting the glue-up, side panes first. First thing to do is to find a flat surface to glue on, since the sides are too flexible (both wood and plexiglas) to be rigid. My workbench is not flat enough (beech wood it is made of swells a lot with humidity, leading to warpage), but luckily the case base is dead flat and stable, since it is a torsion box. Checked with the straight edge: Then I need to mask every part with blue tape, to reduce the mess after epoxy. For that I did a number of trials with different types of masking tape available locally, to find the one that leaks the less (epoxy can leak under some tapes). Scalpel is used to cut it just enough to let epoxy get out and avoid trapping it in the joint: The rest is a time race: 1) Apply a bit of epoxy to all future joints (8 surfaces). They are all endgrain-to-endgrain (well, diagonal grain), so needs to pre-absorb some epoxy, otherwise the glue joint would be weak when real epoxy would be sucked into the grain. 2) Plexiglas is attached to the wood with a silicone glue, so every groove need to get a continuous line of it. (4 grooves) 3) Carefully insert the glass without moving it too much to avoid messy silicone glue squeeze-out. 4) Connect joints together, applying thick epoxy to it as you go. 5) Align everything, check squareness 6) Clamp and re-check again. It was not so easy to keep track of all that, especially with a 10-15min working time for both glues. Epoxy gets out to the masking tape, but all the mess stays on it: So the first side ended up so-so, with some joints having gaps. But this side would be less visible than the other, so should be ok. Full view: After a full assembly, I will scrape and sand all jonts to make sure they are nice and flush. Second side window was much smoother, all joints look tight with no gaps. I have big hopes for that second side The moment of truth is coming - joining these sides together with a top glass and front frame. Really hope that I will not need to scrap the entire thing and start over...
  2. Thanks, she is happy to read it! Today we took part in another build (or a maintenance of an already built "model"). It is Helga Holm, the Viking ship replica, built in 1983, 22m long, weighs 4 tons. It is in a decent shape, but definitely requires some repair. For now the goal was to raise a tarp cover to protect it from elements in the winter. Daria participated a lot, and she looks forward to sail it in the summer! Ready to be covered:
  3. The build was finally resumed, we had a number of modelling sessions during the last few weeks. Horray! This time the job is simple - glue pre-cut veneer pieces to their places, fine fit and making sure they are properly clamped. Daria likes it a lot! And whines that with this tempo it will take too long to finish the model - we need to glue more than one part per day! Learning how to work with a scalpel with various angles. I know the holding is not correct here, but that will be corrected later: Using masking tape to "clamp" the veneer where regular clamps could not be used. Works like a charm on this scale: Transom all clamped: Result is ok, including the ebony parts: Then onto the bulwarks. They are double-layered for whatever reason, but alignment is easy and done by a small pins that fit into tiny holes cut in all layers. Such a simple and elegant idea! Found out the hard way that these clamps are not good enough - they clamp only in the middle, while veneer warps due to moisture. So we experimented with other ways of clamping: And ended up with this monster, but it seems to work: She really enjoys it now - the difficulty level is just perfect, and learning some new techniques every time. I am touching the model less and less, she is doing more fine fitting herself (and said fitting is always required, a millimeter here and there).
  4. 230v version, of course. The only reason is to save a bit by buying it used, and to avoid various import/customs fees.
  5. When preparing parts for the next modelling session, I noticed a slight difference between our model and how it looks in the manual... Apparently some parts are not permanent, but a temporary alignment jigs. They are not supposed to be permanently glued. D-oh! I was such an idiot Followed the manual blindly, like a Lego. Without thinking "what the heck is this part" and "wonder how it is used down the line". So I did some brute demolition with pliers, cutters and dremel disk cutter. Daria was not involved, since it is a very delicate process - one incorrect move with pliers - and bulwarks will crack. Bulwarks end up with no support when you are supposed to glue finish planking to them. Cleaned up hull, ready to move forward: Phew! Will read manual more careful next time. Daria also confirmed that I am an idiot, and now reads the manual after me, to make sure I haven't missed anything. Guess it is a good thing in a long run
  6. Fantastic model! It has a pretty unique wood / coloring scheme, which makes it look very soft and cozy. Looking on it gives some warm feeling... You can use it instead of a fireplace to add an atmosphere to your living room! Wonder how your display case will look like to compliment the colour style of the model.
  7. You definitely have a pretty clear style! It is a pleasure to look on that photos
  8. Whoops, fair enough! We haven't yet resumed the build, (full schedule every weekend, affecting my build as well), but will definitely come back to it!
  9. Fantastic! Very clever usage of the minimal tools. Thanks for sharing your methods!
  10. After few more dry fits and verifications, I made recesses and rabbets to hide the ends of "floor planking" and potential backing sheet on the back side of the case. So far I am planning to just have a bare wallpaper there, but if not - the recesses will allow to properly feet a sheet of some material (white acrylic or similar). So now the best part - finish sanding / scraping. Mostly scraping - with rectangular objects it is a walk in the park, and yields a better surface without rounding: Finish scraping with xacto blade, it is perfect for that: Applying danish oil. Irregular grain pattern leads to slight "curls" when oiled, looks sweet. Picked danish oil instead of tung this time, tung oil sips too deep into the wood, is too dark for that case and takes forever to dry.
  11. Too early to say that it is good, not done yet! The design is basic, but will see how the door design will work out. Chris, hope to see the pictures of your base and a display case soon
  12. The case is dry assembled, and after some fine tunings and adjustments everything fits perfectly! It has a bit more flex than I thought, 3mm plexiglas is not so strong. Who knew! I used some test pieces to pick up the glass thickness, but when you have a larger plane - it flexes differently. The photo is a bit distorted, it actually have just 1mm of sag in the front and no sag in the back (there is a 20mm square pear stock there). To prevent sagging, will add a reinforcement to the top part of it, which will lock the front glass frame with the front frame of the case. Now I can finally sand, finish and assemble it. Will use silicone to mount the glass and epoxy for the joints. When the top part is done, will rebuild the base out of thinner plywood - the base is probably 5x heavier than the case itself Also not sure how to plank the "floor" of the case (flat surface where the model will be). Planking it with pear would be boring, but I am on the edge between a lighter colour (that willow I cut down might come in handy) or a darker one (walnut). Aaargh, hate do to the colour choices!
  13. Would appreciate some first impressions, rookie mistakes and setup experience!
  14. Still learning the best ways of working with epoxy. First gap filling had too much spillovers (tried to use a masking tape to contain the epoxy), so the second attempt relied on gravity to keep epoxy in place: Epoxy is a fantastic thing, but I need more practice to use it without making a mess. It sips under a masking tape as well. A bit about the lumber I cut, made a photo of a stump. Colleagues say it might be Willow. Looks similar!
  15. Congrats! Please post some review after a few months of usage! That would be very beneficial for the modelling community on this side of the pond
  16. Also a good video on the bandsaw setup:
  17. Well, all bandsaws of that class look the same - Proxxon just made a smoother shape the difference is is quality (materials, bearings, alignment), which impacts the noise, vibrations and accuracy. the bearing guide is very important in my opinion, it greatly impacts the cut accuracy (so the blade will not drift to the sides). I never used a saw with the old style of guides though... But the axminster saw has the ball bearing guides, it is clearly stated in the description and photos (both upper and higher guide, while proxxon only has an upper guide). So seems to be good to go? http://www.axminster.co.uk/axminster-hobby-series-hbs250n-bandsaw-508204 Edit: sorry, right, the cheaper saw (HBS200N) does not have a bearing guides and the fence is optional, while the next model (HBS250N) has them. You might need to dig through various reviews to see how it works without the bearing guides...
  18. Andi, no worries part of the problem is that most of the US brands are not available in Europe (if you do bot want to pay for internetional shipping and customs). for example, this saw is really nice (saw it in person, saw some reviews, but no firsthand experience): http://www.leevalley.com/us/wood/page.aspx?p=75264&cat=1,41036,75262 but I was not able to find it on this side of the pond. Maybe your googling skills are better? But the main question that is left unanswered - what size are you looking for? 8 inch? 10 inch? Larger? And what are your main priorities when looking for the bandsaw, how are you going to use it? I really want to help, but it is hard without a proper starting info
  19. Andi, the decision is simple - go with the biggest bandsaw that fits your space and budget limitations I do not recall any reviews of Axminster on this forum (MSW), but from the reviews on youtube it seems quite good. See https://www.youtube.com/results?search_query=axminster+bandsaw
  20. Horray, modelling weekend! I had a classic modelling block - "oops, lots of potential mistakes ahead, and the wood is expensive - I better do smth else for a while". But forced myself to start cutting that wood! Lovely morning. Lots of toys to play with! This update looks like a Veritas ad, for some reason I used most of the tools I had this time. Maybe I just missed them First I cut the glass grooves on the table saw, that was easy. And a groove for the LED strip: Making bevels on the edges. Surprisingly, mini plane was better than a block plane with bevel guide (which was too aggressive and left some tearout). Really happy with the new plane - it is more ergonomical than the smaller version of it. Using both depending on the task. Time to cut the miters, the most scary part of the project. Proper markup is the key: Miter sled was very handy, gives a good control with no slippage. But not all the angles are 90 degrees in this build Miters were undercut and finished on the disk sander. Sander is way more precise than the saw: Next I milled the slots for the reinforcements, otherwise the endgrain-to-endgrain joint would be too weak. Finished stock, no mistakes! Oh well, I was too optimistic Apparently my mill vice was installed with a bit of an angle, so the offset of the slots was different on different sides of the vice. Some slots turned out to be misaligned: Fixing them with a tiny chisels: That will effectively make some slots wider, but I will fill in the gaps with epoxy. It would be hidden anyway, and I hope that epoxy will provide enough support.
  21. Hm, I probably have a newer version of the saw. I saw the previous version of it, it looks slightly different, maybe that is what you have? The blade guides are proper bearings, not a round brass rods. And I never had a single issue with that bearing guides - they work properly, easy to adjust and they keep the adjustment. No extra noise from them either. Zero complains to that part of the saw Also no issues with the alignment of the blade guide arm. So the only issues I have with my saw are: 1) Lack of fence (and not so easy to clamp smth since the underside of the table is not flat, but full of shapes to increase its rigidity). 2) Screaming upper bearing (cheap and easy to fix, just buy proper bearings from, say, SKF instead of the crap that is provided out of the box) 3) Super rare blade size, which means you can't buy any aftermarket blades. The Proxxon blades (3 or 4 types of them) are quite ok, not that I don't like them, but they do not offer any resaw blade, and you can't find it anywhere else due to a small size of it But for the shipmodelling use it is more than enough. We do not need a resaw capability or a fence, it is mostly used as a sort of a powerful no-vibration scroll saw. And it is really good for that - even with regular blades you can make pretty fine curves, while the narrow blade will allow even more. Pros: 1) Speed alignment 2) Overall construction is quite good and precise 3) Blade guide 4) Size. It is the smallest bandsaw in the market (excluding some chinese plastic crap). 5) Quality is good (except bearings). The table is flat and level. 6) Pretty powerful for it size - never made it stall or bog down when cutting smth big. Few years ago there was no alternatives to this saw (at least in Europe). Nowadays I see more and more 10 inch saws of decent quality, according to the reviews. And cheaper than proxxon.
