Everything posted by Craigie65
Just had a fight with the brass sheer rail Softened the brass but there is still a bit too much spring in the metal. Using epoxy resin glue to attach it to the hull/capping rail, but did not hold the rail where is curves round the bow. Possibly I did not leave it clamped long enough to cure fully. Will try again in the morning.
Lovely, clean and neat work. The desking has a marvelous hue - did you stain the wood? After 21 years has some of the timber dried out?
- 335 replies
- Constitution
- Mamoli
(and 3 more)
Wow what a great kit. That was really great of the supplier to give you all they parts to backdate your build. You don't get service like that very often:( Mind you it must be heavy? Looking forward to watching this all coming together What aircraft flew from the carrier back then?
- 176 replies
- new orleans
- iron shipwrights
You have the right of it. Use the model as test bed and don't worry if it goes wrong. I tried to make the rigging more accurate but realised that I should have put in belaying pin racks so just used brass eyelets - it looks okay even if it is not accurate I am building the Caldercraft Bomb vessel Granado . It is about a third bigger than the president but has a much better package. Great instructions and proper plans. If you are short of space they have a number of smaller models that look good.
Hi Jonny, As you have guessed this is not a model of a real ship. So you can do what you want! This was my first build and I used it to learn the techniques for my second build. The cannon are carronade- like which were originally made not very far from where I now live. There a lots of inaccuracies with this vessel.
Hi Cap'n Jack Glad to see you have posted your log. Your pics reminded me that you need to sand down the planking at the stern to fair it in with the stern post. If you don't when you add the second planking and try to fit the rudder you will find the iron work is not wide enough. Guess how I know? You don't get that in the instructions. See the "how to" section on creating a bearding line when planking
Airbrush vs Hand Brush
Craigie65 replied to Intasiabox's topic in Painting, finishing and weathering products and techniques
I have an airbrush as like you I also build aircraft and armour. It was one of the best investments I made. However depending on what i am painting a hairy stick can be best. For my Granado I airbrushed the hull below the waterline. Just too big an area to get wrong. I also airbrushed the wales. For the interior I used a brush and I find 2 or 3 coats of thinned acrylic paint is just fine. If I just built ships I am less convinced that an airbrush would be a sound investment but with over 60 aircraft built and a dozen or so tanks well..... -
Passing ropes through blocks.
Craigie65 replied to Romanov's topic in Modeling tools and Workshop Equipment
Got it now - I was figuring out why I needed waders to thread a line -
interesting link - what are we looking for? -
Nice little tool - did you make it? I sometimes use the needle threaders you can buy in any sewing shop. I find that dipping the end of the line in a bit of CA works just as well and can be easier in those hard to reach places
