Adrieke
Everything posted by Adrieke
  1. there is nothing better then experience. if you know all the formulas and can rattle them off by heart but dont know what they mean in the real world you have learned nothing.
  2. i used rubber bands to hold the deck to the bulkheads and keel . i use them alot as they can boldly hold things where no clamps have clamped before
  3. hello Brian i have started on the San Salvador. the buildlog is in my signature.
  4. slow progress. finished another door and attached most of the shutters that leaves 1 door 2 windows and 8 shutters i also had a look at the second stairs and they are not as bad. with a bit of adjustement i think io can make that one fit. then i can compare them and see where i went wrong with the other there is still hope
  5. almost at least i have the web to translate the words so i only need to make sense off it
  6. iam just patiently waiting for when one of the bedrooms will be available to convert into a workspace i have translated 26 out of 261 picture instructions so far
  7. a good time to check some other stuff out David maybe look at some of the deck furniture as Augie said if you cnat get the bend out that way you can do the same as i did on my Endeavour. i have been lucky so far with no bend keels but th eblocks make me sleep better knowing i wont accidently push soem bulkhead out of alingment
  8. tsk tsk guys its like you want Sjors to get in trouble
  9. thanks David , John, Jim and Wim naah i cant ignore them too long they are too much bothering me. but i need to be in the right mood to tackle them and after a days work tackling problems my mind wants a rest so i work on the easy things i got the parts from the hardware store . the board itself is from pressed cardboard (i think ) and the pedestals are actualy drawer knobs. i know its not the best looking board but it was cheap
  10. cool that the kit comes with all the parts for the inside too.
  11. i didnt even look at them tonight . will deal with them tomorrow i finished 2 more doors . now only the front and back ones left also started on the 7 doors for the 3rd deck stateroom also made some progress on the display board.
  12. David . best way to check is to lie the keel flat on a surface. if its bended it shoud show up. not sure what the standard practice is to right a keel but i would wet the outsides (soakign could loosen the plywood) and then clamp it between two haeavy straight planks
  13. thanks for reminding me John. yes that is part of the problem but i also have that i have a 3 mm height gap between deck and top of stairs. i think i pulled the bottom stright stairs a bit make them not horizontal. i need to try and fit the second stairs to see if it got the same problem but they came apart a bit when trying to fit it in. drilling the holes and making the centre pole longer does not work as the stairs in eachothers way for the fitting. so i ll need to cut them down again. i am trying to put i t out of my mind and concentrate on my work but i know its going to be hard. i dont want to give up but if it comes down to havign to scratchbuild the stairs i dont think i am up for that
  14. hello David. that sounds good. the back 2 bulkheads on my endeavour where longer too but thats where the keel curves upwards and the frames need a lot of fairing so i assume that is the same with your bulkhead. Augie its because thats where i am at with my endeavour adn its all fresh in my memory ( give a few more months and i ll proabbaly have forgotten it lol) so please join in as i am still a newbie like David .
  15. thanks John and Wim alas when trying to dryfit the first stair i could not fit it properly not sure where i went wrong but i dont see away to fix it without taking it all apart and that woudl most likely brake the sideparts i set them aside for now and worked on finishing the 2nd deck stateroom but soon i wil need to put the stairs on or i cant go further
  16. thanks Jim so happy i got the first curved railing on the stairs. as you cna tell it did split a bit but i will fix that up . hope the second one will go as smoothly also finished cutting all the holes in the second deck really happy with the progress this weekend. next wil be to install the 2 doors on the second side. the 2 at the front and back are going to be a challenge as i didnt realise i dont have enough access from the inside to make it easy
  17. hi David just a few things : did you also check the bottom of the bulkheads. they should sit almost to the bottom of the fals keel with just the thickness of the planks you are using left i the picture it looks like the first 3 bulkheads are lower on the left while the other bulkheads are more straigth not sure if that is because of the angle you took the picture finally as you filed down the top of the bulkheads where the rounded on top ? ( i cant tell from the pics). if so you l make sure you keep the same curve
  18. Robbyn that doesnt look to bad for your first try. bit of filing and shaping then repaint and they l look good . its a lot of work scratchbuilding parts but so rewarding when you see how much you improved the look of your model
  19. haha Sjors . maube i wil maybe i wont. anyway she is too long to fit on the build board for the endeavour so i wil need a bigger one plus the is longer then my workbench is deep so if i stored her like that (would have to wiht al th eother build there) she d be sticking out a fair bit which i think is not a good idea
  20. John i only saw that yesterday on the box . since she is scale 1:95 i had expected her to be lile the constitution . In real she is about 90 meters long
