Some Idea
Everything posted by Some Idea
  1. I have to say Chuck that I really like both types of block......beautifully made and if a builder gets a choice of colour then thats even better!
  2. I think that now I can see the difference in the mounts; you have made a very good decision. Your modifications move the eye away from the mount to the model. Beautiful work - your ship is amazing!
  3. Hi Guy - I have pretty much ordered all of the above for my saw and I use everything that I ordered too. Over the past few years I have found that a UK builder should order as much as possible as the shipping costs here are very expensive. So here is what I have learnt as a UK builder - I don't use carbide blades for anything other that cutting down big pieces of wood. The edge finish is rough and not suitable for modelling. Also if the piece of wood moves even slightly sideways as you are feeding it through, the blade will cut sideways and leave you with a piece of wood that varies a lot in thickness through its length. Buy at least two accessory packs as you will loose screws and its a bargain for us. All of the threads are UNC which we do not use here. We are metric here so go for the metric stop. Get as least 5 - 6 zero clearance inserts - They are as cheap as chips and you will need one for each thickness of blade. You will accidentally fit the odd bade incorrectly as it will trash the insert. Get some spares. Buy a couple of belts as they do wear out over time and you need to think of the cost of shipping one here. Buy as many blades as you can! I use three types of blade now. The 4" blade for cutting planks as it had much less deflection and the 3" blades for finer work. I go through a lot less of the 3" blades. Regardless of how often you use these parts I have not regretted buying anything and I can honestly say that Jim and Donna Byrnes properly support their product. There's nothing better that I know of in our hobby and I'm very glad that I have mine Mark
  4. I also thought the same as you - however when it came down to it I found it easier to correct the clamp. If both sides of the clamp are the correct height then you will get less roll on the beams throughout the length of the ship. Your idea can be done but you will end up doing a whole lot more measuring in the end. The clamps will look a lot more uniform too if you make them the same. We both had the same issue and same solutions to consider.
  5. Hi Alan - Great job mate. Although I only have one clamp on my ship, I later found that one side was 1mm higher than the other in places. So I marked out the correct height and used a Veritas shoulder plane to correct it. It made easy work of the job and saved many later corrections.
  6. What a fantastic kit it really shows the details of the small area of a ship that it covers. This is the sort of kit that I would happily build as the results are great. A top tip for any UK builders though - If you have a Games Workshop near you just drop the figures into them with a few quid and ask them to paint them for you. What they can do is amazing and far better than any of my feeble attempts.
  7. Hi Marc and thanks for you comments - You are right in some ways that everything is on show and it needs to be accurate but as I have discovered there are loads of ways to hide small errors - thank goodness 🤣 Sorry for the lack of updates I'm just really busy elsewhere at the moment so I fit in the ship building as best I can. So onto the binding strakes and I soon realised that there is an easy and hard way to make these pieces. As per usual I chose the hard way in my opinion to get better results. The first front pieces at the bow are simple and pretty much more of the same. Cut them to length and carefully mark out the cuts and get going on the mill. It's difficult to explain my weird markings on the pieces that I cut too, as I use them as a guide to what I know to be correct in my mind? It works for me - it's not for everyone. Next is where you can either make the job relatively easy or a bit more difficult. The binding strakes partially pass over the top of the deck hatch openings. I really wanted to maintain the integrity of "Width A" in the picture below to keep the strake uniform in thickness along is full length. So to do this I had to scribe the strakes around these obstacles. So instead of just cutting straight joining slots I ended up with the complex joints below. Have no idea if this is how they should be made its just the way that I wanted to do it. I did find that doing it this way once again made the fitting very easy as they locked into place and followed the curve of the deck so easily. I'm very happy with the results and I have also caught up at last with the required nailing. A few pictures below I'm very tempted now to leave the main deck as it is now? I understand that everything that needs to be placed on the deck will require lifting to the correct deck height but what are your thoughts on this? I have no experience of doing what I'm suggesting but I think that it would allow anyone that looks at the model to see the work carried out inside far better. Please let me know your thoughts. So my next jobs are to make the bits, bowsprit partner, windlass supports and finish planking the inside of the bulwarks. Thanks everyone - Mark
  8. Hi Chris - I had a similar issue with the belt rubbing on the guard at the motor end. After speaking to Jim he suggested that the motor tensioning spring was probably not as it was. So he suggested that I place a few small washers behind the spring and this solved the problem. It pulled the motor further up and also gave more tension on the belt. Even now I only have a small gap between the belt and guard but it certainly solved the problem - Mark
  9. Simple amazing work - I can’t thank you enough for sharing your skills as I personally have learned so much from your log 👍👍. I’m looking forward to your next build 😎
  10. Nice job Tobias - I found that planking the ceiling was a particularly time consuming and tricky job; especially at the stern where it has to rise to the top of the wing transom.
  11. Another update from me - The inner waterway which is pretty much more of the same but is easier to make. Its made up of three sections per side. The parts were then glued into place - I found that the dovetails pretty much hold these parts in their correct place. They do nee to be clamped though to bring them down to the sheer. Then I made and fitted the first plank up the bulwark so that I could finish the bevel on the waterway. This was then all sanded down and blended in and I'm pleased with the result. So thats brings another part of the build to conclusion. The next job is to make the binding strakes. @DaveBaxt this is where I work - Its not a big area but I find it more than adequate. Its always this tidy as its our spare room so I need to make sure that the mess is always cleaned up. Cheers Mark
  12. Hi Dave and thanks very much - I'll get a couple of pictures up of my work room sometime this week so that you can see where how it's all set up. Prepare to be underwhelmed though 😆 As always mate - thank you. I know I've said it many times but those parts are very difficult to make. The shape changes constantly and if you get the angle wrong there's a gap somewhere. The pay off though I think for any builder is when they eventually just click onto the mating dovetails need very little clamping. This is why I build - the feelings great. Thanks HH - I actually think its the other way around - Its your work thats clean and never ceases to amaze! I made a start on the inner waterway and I'll get some pictures up this week. Having just finished my nemesis parts I was expecting more of the same. But no................hooray its not the same at all. It's a much simpler part to make......well so far anyway! I have discovered that the dovetails on the beams are a little short and I think this is yet again down to my photocopier. Its no big deal really I just need to take my time. Cheers Mark
  13. Honestly thanks for the very nice comments and the likes here - I won't lie I have found these particular parts very difficult to make and get a good fit. You have very much helped me through this particular part of my build. If anyone else is building Le Rochefort you don't have to cut the dove tails if you don't want to. You can simply cut a slot the width of the beam and it would be so much easier. I did it this way as I just want to make it as true to the drawings as I possibly can. However once done how satisfying is that feeling 😀 So I carried on cutting out the dove tails and also roughing out the bevel After a little fettling they did fit As always I've learnt some new skills and overall I'm very happy with the way these parts have turned out. You can see that I have also rough cut the scuppers too. My patience is definitely improving too which I like. So now that they are installed I can now start on the inner waterway. Cheers Mark
  14. Hi Bob - yes I do use these but it's the deep reach that I need. I do have lots of types of clamps including G clamps but I think the type I'm looking for will be very useful.
  15. Thanks for you reply’s - I think that I will end up making them which you are right it’s not difficult to do
  16. Hi Everyone Can anyone help me - I want to get some of these small C/G? Clamps and I cannot find them anywhere. If someone could please point me in the right direction I would greatly appreciate it. Cheers Mark
  17. Congratulations Chris that really is a beautifully made ship.
  18. Just a quick update - I've now rough finished and loose fitted one of the parts. I cut the dove tails on the mill and they needed just a little adjustment to fit onto the beams I also roughed out the inner bevel partly to make the piece slightly more flexible to fit the curve of the deck. It actually fits ok and pretty much just clicks into place but it will fit a lot better once clamped and glued. It will require a little blending into the adjoining pieces. The bevel will get its final shape once the inner waterway is made and fitted and also the bulwark plank above. So far so good - and it's nice to be moving forward again. I'm starting to feel a lot more positive regarding these parts. I'll update again once the rest are completed Cheers Mark
  19. I'm actually starting to get there - One of the pieces took me four goes to get right. I discovered that if the bevel angle between the beam and frame is wrong the dove tails on the beams will not line up to the tune of about 2mm out. So after much sawdust I've now got the roughed out pieces to sit right on the beams. This actually doesn't look like much but I've found this difficult - Its like working upside down and I think it's one of those parts that you need to make to see what I mean. So a couple of pictures. I think these pictures give a better idea - here's the transition of one part from one end to the other So I've now marked out the dove tails as best that I can and that will be my next job of cutting them out. I've also cut the holes for the scuppers which was not a great success - I've drilled them at a very shallow angle and also burnt the wood in the process. All is not lost here though as they will need lining with pewter in the manger so I can hide my mistakes then. As always you get the successes and the errors with me! So the milling machine is coming out tomorrow and hopefully they will fit ok. If you think that my marking out is a bit rough I kinda have my own method that I understand once I get cutting. Cheers Mark
  20. Fantastic what a great ship to build and what an amazing start - I'm in!
  21. B-Ram luck with your build I'll follow along mate 👍
  22. Goodness me that is beautiful work - that dividing head for you mill looks the business and I must get one of those.
