Some Idea
Everything posted by Some Idea
  1. Hi Tony thanks for your nice comments. I’m sure that you will be back on your ship in no time. I’ve changed tack now as I was going to make the forward deck. I soon realised that if I put the deck beams in it will make clamping the outer planking very difficult. So I’m currently trying to make the moulded planks which is something completely new for me. I’ve never scraped a shape into wood before or made a decent scraper so that’s what I’m experimenting with. I’ll get something up as soon as I make something that resembles a half decent mould.
  2. Just been catching up on your build - You have made such a beautiful clean build - fantastic
  3. ensor when I was driving through Europe one of my regular stops was between Ypres and Wormhout in France. It was a routier call Hoffland which was owned by a guy call Michael. I have great memories of this place and although it is not a pub - the bar was always open and usually open late too. I think it was in Steenvoorde but my memory fails me sometimes now.
  4. Wow congratulations on such a realistic build - amazing!
  5. Hi Luc and welcome to MSW - I think your workshop looks great and good luck with your build
  6. What a lovely clean build you are doing here - your ship looks fantastic 👍
  7. This is such sad news. Donna I send my families condolences to you and yours. I’m actually lost for words at the moment. Machine’s come and go but there will only be one Jim Bynes. lost for words xx
  8. Glad you’re back building again - the work looks fantastic 👍
  9. I have to say that I am surprised by the lack of comments on this build considering the effort that LFNokia has put into showing this build - I think it's quite simply amazing and also so very different. A great job with a different aspect - what a lovely ship.
  10. Another update from me - its all or nothing with me at the moment I can only apologise 😀 The final 2 breast hooks for the hawse timbers. The upper one is made of 3 pieces which then go on to be attached to the forward deck beam supports. The second is one piece - so I dimensioned the wood and roughly cut them out as per usual. It's worth noting that the upper breast hook is made from a piece that starts at 11mm thick. The lower breast hook is very straight forward and is just like all of the others that I have made. The only difference is that you have to cut a channel for the bowsprit which is set at 17 degrees. Installation is also just as before - take your time and get a good fit onto the hawse timbers. I see this bit as a challenge to get it as tight as possible. Now the very top breast hook is a very different thing to make. It has a gentle curve to match the clamp and the forward deck as the deck timbers sit directly onto it. It is also parallel in thickness throughout its curve; is recessed onto the clamp and has to align with the bowsprit too. I hope your keeping up 😆 So after a bit of thought this was my solution to making this piece which cost me quite a bit in wood as I didn't have anything else in the house other than Castello. Firstly I shaped the perimeter of it as per the drawings - this is the easy bit. Next to shape the inside curve I attached it to an angle plate to ensure a 90 degree cut. I then made a jig which matched the curve that I had just cut and once again attached it to an angle plate for a 90 degree cut. Next was to cut the recess for the clamp and again cut another recess for the bowsprit Then finally installation (btw this did take me 2 attempts to get right) The bowsprit view which just needs a little fettling to bring it all to the final diameter. You will notice that there is a small gap between the clamp and the breast hook. One of the spin off benefits of making this part as accurate as possible is that it has put the correct curvature on the model for the forward deck. Finally one of my most favourite pictures of my build so far - just a little tidying up needed. Now I was going to start planking the outside of the hull next but I have realised that the bowsprit partners are a little vulnerable. So instead I've decided to finish the forward deck first. So I need to make the small office and the ships stove and quite a few other parts too. I want to get the forward deck beams in before attempting any planking. Can't thank you all enough for the likes, advice and encouragement - cheers Mark
  11. Hi mgatrost - welcome to the build mate. Have a look on Ancre's website at all of their monographs. The attention to detail that the draftsman/historians/madmen put into their works are amazing. I feel that I need to do their work some kind of justice even if this my first scratch build. Thanks for your comment but have a good look around the forum as some of the builds here are truly amazing
  12. Thanks Dave I did learn quite a lot from this exercise. Pewter is great to work with but cannot be soldered (I tried). I also would not use cyano again either - the lumps you can see are hardened glue underneath the metal which would not smooth out. Otherwise the finish would have been better - next time I will use 15 minute epoxy very lightly spread just to give enough time to get a better fit. As for the scuppers I couldn't believe that the jib actually worked! I though that the pewter would loose its roundness when sanded but it stayed as it was. I'll take that as a win
  13. Thanks Chris that nice of you to say - Next time I'm in Gloucester I'm going to have to look you up 👍
  14. Hi All Some more done on my build - I decided to move to the front of the ship and make the bowsprit partners and the manger. The first job was to make the metal liners for the scuppers as once the partners were in place this would reduce the space in this area. Having read the article on using lead in model ships I opted for pewter or as some places call it brittania. The sheet I used is 0.15mm in thickness and I needed to find a solution to the angle of the scuppers. First I made a tube 4mm in diameter that would fit snuggly inside the scupper hole. I then made a simple jig to match the angle of the scuppers. This allowed me to place the tube inside and carefully sand the tube on a face sander. I then needed to roll the mouth of the tube over slightly to create a lip to stop the part from falling straight through the hole in the hull. Then it was simply a trial fit and repeat for the other side. Next I made the two bowsprit partners. Now making them was a whole lot easier than fitting them. They fit into slots that I had previously cut into the beams and they have to line up precisely. The reason being is that not only do they need to be inline with the bowsprit, they also tie into the beams of the deck above. It's not too difficult I just had to check the overall height of these pieces before gluing. Then it was onto the manger itself - I have decided after all not to plank the main deck. I did though need plank the area for the manger. I then made the back walls for the manger and pretty much got on with lining the whole thing with the pewter. I think that the results are ok - but just ok. I do like the way the scuppers just sit nicely in the corners as they should. I used cyano to glue it in and I remembered why I don't use this glue. I personally just cannot get on with the stuff. So my next job is to make the final 2 breast hooks for the bow. Cheers Mark
  15. Very nice work Tobias I found that getting the beams to sit in the perfect position quite time consuming but worth it to save loads of sanding to bring the deck fair. I love the dovetail joints - top job 👍
  16. Hi Kevin what a great job you have made of your carvings. Its something that I must learn too and I wish we could get some workshops here in the UK as I would attend. You have a Foredom so have you tried these? I put 6 into a mandrill and they work great for polishing wood. https://www.metalclay.co.uk/foredom-radial-bristle-discs-pumice-1200-grit-pink-6pk/?gclid=EAIaIQobChMImMWCwNebggMVS9HtCh2B8w47EAQYASABEgJ4a_D_BwE At 1200 grit they would smooth off your carvings without changing the shape Mark
  17. I think that I would make a stencil and paint the letters on. I think it would be more subtle mate 👍
  18. I think that the first 5 builders of the POF model are getting a very good deal here. Having scratched a frame in Castello I would estimate that the wood alone cost at least £300 ($400). This is the real deal and what a lovely ship this is going to be to build Not only that you know that its going to go together perfectly and also get the back up of the manufacturer right here. In fact I think the first 5 builders will be more than lucky and I can't wait to see their builds on here!
  19. Hi Paul I did post this but I must have done something wrong. Here’s the link you need but remember it does have a 22mm hole so a new arbor would be needed but Jim can supply them. https://www.protool-ltd.co.uk/p/17569 Cheers Mark
  20. Hi Thistle17 - fence alignment is very important and also really easy to do with a DTI. Since my last post 8 months ago I too have had some issues with thick wood overheating and burning. As I know that my saw is set up exactly it could only be the blade. The 110T blade can bind up quite quickly so I swapped it for a 64T blade. This got the chips out much better and solved my problem. In fact this blade goes through wood like a knife through butter. It also leaves me a good finish on the cutting edge with virtually no chip out. I’ve also noticed that the motor runs a lot cooler too. This is now my go to blade for ripping planks.
  21. Hi All Time is not a friend of mine at the moment but I have been watching others build projects (enviously 😆). I have got some done hence the update and thanks to everyone that took the time to give advice and the very lovely comments. The first thing was to fit two more plank strakes on the bulwarks and then pierce the holes for the scuppers and hawse holes. Nothing really tricky about this you just have to be careful cutting the holes so that you don't tear the wood too much. Next was to make and fit the deck clamps for the smaller aft and forward decks. Learning from my previous attempt at placing clamps I really took my time marking these out with a digital height gauge. I think this took me about 4 hours to get right until I was absolutely happy with their placing. I also used a technique that @Tobias uses with tiny spirit levels athwartship. These things are so cheap and yet they allowed me to checked my levels even further. I used quite a lot of clamps to make sure that my efforts stayed where they were. Cheers Tobias Next was to plank the gap between the already fitted planking and the clamp. All I would say about this is if you measure and plan it accurately it's a fairly straightforward job. I can imagine it being a nightmare if you don't. The clamps are slightly thicker than the planks and just need tapering into the planks below. I've put a photo below to show what I mean. Note to self - use a lower resolution camera as these photo's show everything Ok so as always - what did I do wrong? Well I cut the planking too short - Its not a problem but I forgot to allow for the scroll to the gunwale. This is how I cut it. And this is what I missed Its not a problem as I will fix this later on when I plank the outside but for fellow builders this could save you from doing the same. I'll get some more done as and when I can - I think I need to be retired so that I can enjoy my hobby more!! Cheers all - Mark
  22. Congratulations marsalv very well deserved for such a beautiful ship. I'm looking forward to your next build.
