Everything posted by druxey
L'Amarante by marsalv - 1:36 - POF
druxey replied to marsalv's topic in - Build logs for subjects built 1501 - 1750
Beautifully framed! -
I agree that high relief rather than 'in the round' would be more likely here. Your story-telling is as entertaining as your construction notes! I use a single point light source from beyond the piece I'm carving to throw the shadows in the correct direction. Diffuse light or from other directions is not helpful. Beautifully done!
HMCSS Victoria 1855 by BANYAN - 1:72
druxey replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Eberhard; that is exactly why I never acquired a single roller rest! Pat: I hope the right cocktail of beta blockers can be found for you.- 1,013 replies
- gun dispatch vessel
- victoria
Good advances there, Mark! I made a considerable quantity of projection drawings for the stern galleries. (This was 30 years ago before the various computer graphic programs we now have were available!) I found the sane way was to expand in a single plane at a time. For instance, first correcting the tilt of the stern tier of lights, then flattening the round aft. Of course, you can do this in seconds and a few clicks now! Cheers, D
Coming along nicely. Keep your pencil mark-out lines as thin as possible; a thick line can lead to poor fitting joints. A harder lead (3H or higher) will keep a much sharper point. A clutch lead holder and sharpener such as below is ideal for this kind of work.
- 92 replies
Welcome back! An interesting approach, that. I've only seen single roller file guides. I can see the value of a double.- 1,013 replies
- victoria
Late to this discussion, but it triggers memories of many years ago when I was building Polyphemus, 64 guns of 1782. I also had a time puzzling out this geometry - particularly the jog aft at quarter deck level. This is not immediately apparent in the sheer plan. It looks like "By George, he's got it!"
John's advice is right on the mark. One of the great things about model building is that one is always learning and figuring out new or better ways to do things.
Scale size questions
druxey replied to Desertanimal's topic in Building, Framing, Planking and plating a ships hull and deck
Yes, please stay sane. I can work to ½" a scale inch at 1:48 scale. That's 1/96" or just over 1/100". Not .005", for sure but that's the difference between the two states of mind. -
That's a great question. The best plans are drawn with hair's width lines.This minimises the issue that you mention. Of course, in CAD you can magnify to a size that will drive you crazy! If you want to go the CAD route, might I suggest that the base drawing be redrawn from the 'fat line' plan first, then imported? There will always be some compromises, or you will lose your mind. -
A damp brush gets nicely into corners to remove dust.
- 69 replies
- Lowell Grand Banks Dory
- Model Shipways
A good ol' fashioned scale rule works for me most of the time! -
I apologise for the tardy response ( to post #409), Steven, but I've been under the weather for most of the past month and am only just now catching up with you. You figured out what I used, I see; acrylic matt medium. If you need to dampen the sail to shape it, the bolt rope won't come undone like it woudld if you had used PVA. Great progress since I last looked in, and it was nice to see a civilised discussion and gentlemanly disagreement, unlike some other threads I've seen elsewhere! As for anchor design; would there have been much if any change between the 12th and 14th centuries? My instinct is to use the slightly later design as your starting point.
- 508 replies
