Everything posted by druxey
Rubber cement will not distort paper or tracing vellum as will any glue with water content.
- 92 replies
3D Longboats in Blender
druxey replied to 3DShipWright's topic in CAD and 3D Modelling/Drafting Plans with Software
Interesting discussion! BTW, 3DSW, I think you meant 'pinnace', not 'pinnacle'. Worn paintwork looks great. -
Never regret time lofting and drawing; if you did it correctly, the actual construction and fairing will be (comparatively) easy!
bolting frames onto keel
druxey replied to hamilton's topic in Building, Framing, Planking and plating a ships hull and deck
Another source is, of course, TFFM (The Swan Class Sloops 1767-1780, The Fully Framed Model, SeaWatchBooks LLC.) -
Welcome aboard! Check the 'Important Ship Model Club News' area on this site: Model Shipwrights of Niagara. The meetings are online as well as in-person.
Railings?
druxey replied to hlong222's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Nice idea, SHJ, but no! The beams below the stachions and rail at the ends of forecastle and quarter deck were called the breast beams. -
Railings?
In the 18th century British lexicon, railings at the ends of decks were referred to as 'breastwork'. -
I think either way will work.
- 69 replies
- Lowell Grand Banks Dory
- Model Shipways
And check out the reef points!
I've also had this problem to solve. I cut a blank, longer than the finished ellipse, and PVA glued it to a backing block. This reduced the chance of breakage cross-grain. I then very carefully scratch molded the section. After soaking the piece off the backing, I was able to cut the joints with the straight sections of the moldings. If there are any 'tricks' to this, a really good piece of boxwood is needed and patience while running the molding along it.
HMS VICTORY 1765 by albert - 1/48
druxey replied to albert's topic in - Build logs for subjects built 1751 - 1800
I've seen both closed and open varieties in contemporary models. The closed balcony balustrade would be stronger. -
If the antique wood is a little brittle, you may be able to restore pliability as the veneer folk do: a very dilute solution of glycerin in water. Spray the cut strips and let them dry between sheets of plain newsprint under weight for a couple of days. (It may take longer in regions of higher humidity as it takes longer for the water content to evaporate out.)
Well done and a nice presentation, Chris. You can be proud of the result.
- 30 replies
- Grand Banks Dory
- first build
Quite the collection you have there! Well done.
- 422 replies
- Vanguard Models
- Sphinx
