druxey
Everything posted by druxey
  1. The font you picture (post #982)is a modern late 19th/20th century one. It is quite unlike that used in the 18th century. The letter have thick and thin strokes, as well as serifs (the triangular pointy bits). Bold san serif lettering will detract from your lovely model. If you can't imitate the style, perhaps omit the name altogether?
  2. Bienvenue ici, Michel!
  3. Around 45 degrees seems to be about right, rather than twists per foot.
  4. That is one outstanding model, Steve. A great example also of seeing a huge project through over so many years. Well done, indeed.
  5. Sliding doors make sense, I think. Just an uninformed opinion.
  6. Only the 36-pounder English guns were single/double blocks for the outhauls. Any below those were single/single tackle.
  7. Dust? A small brush or old toothbrush works well. Resist using a vacuum; sooner or later - generally sooner - it will swallow a vital part of the model.
  8. Now, that is attention to detail! Beautifully fitted.
  9. Nice methodical approach, JP. I notice some cross-grain on the stemson and fore deadwood. Try to minimise this by orienting the pieces when you lay them out on the stock. This will be important when cutting frame components.
  10. Very impressive work for a first build. Your care in constructing her is evident. You should be very proud of your accomplishment. Please consider a protective glass case!
  11. Cast toptimbers? Cut the pieces out of a piece whose thickness is the overall width of the timber as seen from the side. Trace the side's shape on this to see where parts of the timber need cutting away.
  12. re: Post #35: The fact that waterlines fall exactly 8' 0" apart is a nice confirmation of correct plan scale.
  13. I'd be terrified to use a rotary tool to cut the limber passage!
  14. Looking good so far. The scores for the sills are nicely positioned. You may wish to clean out the inner corners with a very sharp blade, or the sills may not seat properly later on.
  15. While Chapelle's draftsmanship is excellent, unfortunately he is not always reliable. Cum grano salis...
  16. Unglaublich, Eberhard! Congratulations on miniature masterpiece. An amazing accomplishment.
  17. It would take a chapter to describe the manufacture of cannon, but the bands you are asking about, named reinforces, were all cast into the cannon. Only very early wrought iron ordnance had separate bands applied (shrunk) over a barrel made up of longitudinal iron bars. There is a lot of information on the internet you could access on the subject.
  18. I've just discovered your log, Gregor. What a beautiful job you are doing at this scale! A gem of a model.
