Everything posted by druxey
On a smaller vessel, the bowsprit was sometimes constrained by an iron hoop attached to the bulwark. The heel was secured to the bowsprit step with an iron fid.
The bow ports were not armed: no space for working a gun! The were used as bridle ports for anchor handling. The vertical half-port lids illustrated were 'for example' and not drawn for all the other ports. You could not have a conventional lid as there was nothing but the rail above the port opening. There was no place to fit a hinge to! The advantage of these lids was that in a heavy sea you would not ship as much water over the decks as would happen with open ports.
mnl is correct; watercolor is a transparent medium. You can also see the background through the ships' masts and the knee of the head.
There are several suggested routes you might take. Try this first, though: If you used white glue, rubbing alcohol will soften it so that you can disassemble the planks and try again. Wetting the planks , you can re-shape them, then let them dry. The second time you now know what to look for and check on. It's always a learning process, no matter how long you've been building models! 'Sea' what you can do! (groan)
- 9 replies
- Lowell Grand Banks Dory
- Model Shipways
Jaager: Your reference to the Unimat saw attachment made me smile. Back in 1970 that was the only way I could cut plank and other stock. A lot of hit and miss with any cut depths or widths! And the dust everywhere....
You would definitely need a wider stance on board anyway with the motion of the ship under you, as well as bracing yourself against the pressure of the rudder/tiller combination. I see you've been at Mots d'heures gousse râmes again, Steven. Sometimes I worry about you!
- 508 replies
Spare spars might have been lashed to the bulwark tops except that, in your case, the rail does not continue over the ports! Possibly they were lashed vertically to the foremost shrouds. Very nice work on the spars and the finish looks excellent.
- 562 replies
- vanguard models
- alert
Both nicely done and enhanced! I really like the neat 'flaked down' coils of line.
- 88 replies
- Muscongus Bay Lobster Smack
- Finished
Tiny Spar on 17th Century English Yacht
druxey replied to catopower's topic in Masting, rigging and sails
A head stick was certainly in use in the 18th century on fore and jib sails, as shown above, but I've never seen a contemporary 17th century English yacht drawing or painting that even hints at their use. If anyone can point to the arrangement this at that time, I'd be appreciative of the evidence. -
Steven: You need to stretch the SilkSpan, wet it with water alone first and let it dry to make it drum-tight. Then, when you re-wet it with dilute acrylic, it will initially sag, but re-dry tight and smooth again.
- 508 replies
A very nice result, MC, your frustrations notwithstanding!
- 40 replies
- Model Shipways
HMS Euryalus 1803 by rlb - 1:48 scale
druxey replied to rlb's topic in - Build logs for subjects built 1801 - 1850
It's been a while since I checked in on your build, Ron. Coming along very nicely.- 122 replies
- Euryalus
- Plank-on-frame
(and 4 more)
