druxey
Everything posted by druxey
  1. There are some differences between the photographed prototype and the production model. As noted, the end result is the same.
  2. Sussex ain't so bad, surely, Keith? I recall as a child visiting an uncle and seeing the glow of the steel furnaces in the night sky.
  3. It is more than likely that Wolf was steered by tiller alone. No reflection on your work at all, but on the kit design! Some of these smaller sixth rates were retrofitted with wheels in the position mentioned.
  4. I had no idea that planking a transom could be skirting danger! Looking very fine, Keith.
  5. Very neatly done, Clare! The tiller/wheel set-up is unlike any I've seen - usually if a wheel is present, it is on the quarterdeck where the funnel-like structure is sitting.
  6. Did you not recieve my two pm's, Kevin?
  7. Looking really nice so far. Two suggestions: One, skin tones are always darker than you think. Two, blend the upper edge of the beard into the skin are a bit for a softer natural edge.
  8. At miniature scales 'cheats' to fool the eye are necessary. Perhaps at least try some of the suggested methods that the experts use to see if you can get a result that pleases you.
  9. The brulée torch is perfect for modelmaking as well. Heat the metal in dim light to cherry red and then let it air-cool to room temperature. Take care not to burn yourself - or anything else, for that matter.
  10. First, you've done a very neat and workmanlike job of your first wooden model build. Well done! Clamping parts on a model where nothing is square is always a challenge in this hobby. Your solution worked well - not one I've seen before. As you work your way through more models, problem solving is half the challenge and fun!
  11. Nice! It's amazing with accurate mark-out and the correct hand tool what one can accomplish.
  12. Is that a pair, but one mounted the wrong way around?
  13. Don't be too hard on yourself, Mike. These parts look deceptively easy, but they are not - as you've discovered.
  14. What would be the rise and tread of those steps, Rich? Also, how does that upper rail look in plan view? Does it extend in a straight fore and aft line, or is it cranked?
  15. My apologies for confusing the issue of the depth of keel.
  16. Excellent result. You now only need a ship to attach it to.
  17. Rich: re post #164, I took this quote from post #119, first page of the manuscript at the top.
  18. Ah! "...with the shoe moulds 46 inches..." that/those are the false keel(s). So, 46 - 32 = 14". Not unreasonable to have a double false keel in 7" thicknesses.
  19. I read that at 16" wide (sided). Two pieces: upper 20" high (moulded) and the lower 12"high. Total 32".
  20. For short radiused curves, perhaps two layers of 1/64" aircraft ply with the outer grain direction vertical?
  21. Well done so far. I often find I dread certain making certain parts because I over-think the process. When it comes to actually making them, it usually goes better than I expected. Sounds like that was the case with your cast toptimbers. Enjoy your vacation and safe travels!
