vaddoc
Everything posted by vaddoc
  1. Many thanks to all for your comments and likes! My parents are visiting so I got a bit more time for the boat. I managed to do a little reading and finally I started work on the rigging! I have just a vague idea how the rigging should be but I decided to go crazy and make it as complex as I can. I will try to incorporate anything that could reasonably be found on this boat and hope to end up with a web of ropes going to all directions. The problem is I have absolutely no knowledge on this subject. I will rely on Leather's "Gaff Rig" book, internet search and also on other logs from the forum. Also, I have no information at all from the Whisstock plans on the rigging. To get the dimensions of the mast, boom, gaff and bowsprit I used the small drawings provided and measured the dimensions in relation to the beam, improvising a bit with Leather's help to get the probable dimensions. I applied grey automotive primer to the tabernacle and then started painting with Valejo silver paint. The result was terrible. This is a very difficult paint, no matter how much I steer it does not seem to want to mix. It runs and leaves streaks. I ll persevere for a few more coats but I suspect it will need some wet sanding. I then started work on the bowsprit, boom and gaff. I used birch as I did not have appropriate beech dowels and really do not want to buy more timber. In the photo the bowsprit is tapered and sanded to 400 grit but the dowels for the boom and gaff are untouched. I also cut some beech strips for laminating the gaff jaws, the little proxon table saw is great and I also produced some nice 2 mm offcuts strips. The photo shows also the brass strips for the chainplates, pretty stout as they are 1 mm thick. I made a drawing for the gaff jaws, I think I would like quite an acute angle. I also made a jig to steam bend the laminates, this will later be used for the lamination it self. The first batch of laminates went into boiling water for a few minutes. The Admiral was behind my back when I was taking this picture, loosing patience as she wanted the same pot to cook dinner for the little ones... The laminates bent very nicely into shape. Tomorrow I will get the rest boiled and bent. I also finished shaping the boom and gaff. I managed to get my cheap horrible plane in a somewhat functional state and got a taper towards both ends. it is difficult to see it in the photos but it is there. I did not use a jig but they came out reasonably straight and very smooth. I really need a couple of high end mini planes and a honing jig. Can't see this coming in the near future though...
  2. It's a strange thing: The more tools I buy, the more my tools-to-buy list grows. Cannot explain it! I would agree that the quality of the accessories is equally important to the quality of the tool itself.
  3. I have a Dremel 3000 with the flexible shaft. I mainly use it for drilling holes, rarely cutting wood and metal and milling/sanding. It is a very solid piece of kit but I suspect the Proxon would be equally good. Can'y go wrong with either. I went with a corded one and never felt the cord was a problem.
  4. I have never built a kit, only scratch build! I am sure someone else will be able to answer this one. The boat on the pictures I must admit is maybe a touch extreme, some planks were 80 cm long and were cut out of 1000 x 100 mm sheets of 2 mm maple. The planks nearest to the keel and sheer were very heavily spilled. But a spilled plank will always sit much better than one forced to bend sideways into position.
  5. Just a note on spilling. They say a picture is a thousand words. In my current boat I went a bit crazy with spilling. Zack, note the shape the plank (the cardboard template) needs to have, to actually lie straight on the frames. This is spilling. You cannot bend a plank laterally.
  6. I had another go, the wood needs sanding etc. The old steps were an insult to this great forum. This looks better.
  7. A little more work done so time for a quick update Druxey, even very low tack tape seems to lift the varnish so it seem the real issue is the bond of the varnish to the paint. Roger, indeed this was the plan all along and I think it worked fine. John, many thanks for the support and for finding the time to drop by, hope you are recovering and feeling better! The tabernacle is ready, I cleaned the scale and the copper deposits and is ready to be primed, painted and installed. However, I feel that it is a bit out of scale, on the cabin roof it looks massive. I might need to re make it. I installed the rubrails, they are under a bit of tension following the sheer so I used screws (to be replaced by wood nails) every 1 cm. About 150 in total. As I had carved hollow the back of the rubrails, they sat nicely over the edge of the canvas. The cockpit is almost ready, I am not sure of the steps as they don't look very "nautical" but there is quite a climb to the cabin and this looked like a good solution. I am not very convinced though. I also installed the tracks for the companionway hatch. With all hatches temporarily in place, the boat is looking almost elegant! I filled the counter holes on the hand rails with 1.8 mm tree nails, sanded and re applied Tung oil. I think the boat will need some metal hand rails, I thought I could do without but again I think they would look good and actually would be necessary in a bot like this. Another challenge....
  8. Welcome Dave! You are certainly in the right place. The British winter is starting here. It usually lasts 3 years. Too bad I do mind winters...
  9. Do diamond files have any advantage or clog less with brass?
  10. This is indeed cool. A bit illegal this side of the pond but I can imagine a Victory with a hundred odd of these firing broadsides.
  11. Welcome Kevin. I cannot access your photos either. You will know what tools you need as you progress through the various phases and tasks of building your model. Regards Vaddoc
  12. Your work is inspiring Mark, you keep things simple and produce very elegant results. The boat is coming out mighty nice! The cockpit sole looks great. Following your build I ve been encouraged to try on some metalwork myself. (Not as easy as you make it look) Vaddoc
  13. Many thanks to all for your comments! I did not mention that all my tests using the Fearsome Step Drill ended up with the destruction of the test piece. But I thought I had enough training and took a leap of faith. Well, end's well, all well! I made some more progress and interesting things happened. I had taped off the edges of the cabin roof and the tape has been there for some time. I did not consider that masking tape gets stronger the more it is left. When I removed it, it lifted the polyurethane varnish! These areas had a rugged edge and also a much paler colour as the Valejo polyurethane varnish seems to have a tint. However, this was sorted very easily, to the credit of Valejo which really is a top company. I sanded the raised edges of the varnish layer with 600 grit and simply applied two more coats of varnish. The cabin top now looks like this incident never took place! I continued work on the cockpit, I glued the external panels and then shaped and fitted the top covers. These are screwed and I will replace the screws with tree nails. I also did some work with the rigging. I am thinking of using two large solid pieces of timber (not sure how they are called) to offset the chainplates. They actually came out fine and I will install them after the mast goes on. I also finished the hand rails. My main problem was how to secure them on the cabin top, and I wanted to also have a slight curve which would apply some pressure as they are two rather stiff pieces of timber. I do not have tree nails long or strong enough. I thought of using brass wire and CA glue but I am concerned it would come off with the extreme variations in temperature. Finishing would also be a problem. I thought of using 1 mm screws and countersinking the head but the screws I have are mild steel and easily deform. This would happen for sure and with the countersinking it would be impossible to remove the bad screws. The solution was to get stainless steel screws which are much stronger. They seem indeed to be stainless steel as they are non-magnetic whereas the normal ones are. So here it goes: Holes drilled and then countersinking Then screwed on the cabin top with the help of the Admiral. Looks good I think! I still need to plug the holes and apply two coats of enamel varnish but I am happy.
  14. Spot on Bob Boat building needs a lot of space, a surface that ts ok if it gets ruined (it will) and a lot of light.
  15. PVA glue will be the main glue you ll use. Aliphatic has quick set and dries yellow, normal PVA has more opening time and dries more clear. Epoxy can be useful for laminating and gap filling or for gluing dissimilar material, is messy and temperamental and has somewhat of a learning curve. I use it a lot though, usually thickened with talk powder as it is brittle on its own. CA glue for specific tasks. My personal opinion, all PVA glues are created more or less equal, epoxy and CA most definitely are not. For scratch building, glue sticks (pratt etc) are useful for gluing paper patterns to wood. There are various other glues but are rarely used.
  16. Funny they mention basswood. Basswood and lime are pretty much the same wood, the former a bit softer. I ve found that lime when treated with Tung oil gets this yellow tint that remotely resembles boxwood. Generally not a good wood for modelling.
  17. The "good to have" tools are more than the stars in the sky. But the absolutely necessary ones are few. I would agree on the ability to drill holes, I love my (vast) collection of drills! In regards to planes and chisels, you ll need diamond stones, straps etc to keep sharp and they are really in the "good to have" list. All in good time...
  18. Your wood is fuzzy and has this yellow tint, It looks a bit like lime wood.
  19. Well, since trees are wider at the base, the fibres should converge inwards towards the top. So planning from top to bottom should make the plane dig into the wood. If it was the other way around, there would be fibres ending up at the bark.
  20. A quick addition, I drilled all the holes, initially with the fearsome step drill and then finished to size with the Dremel. I dry fitted the portholes and they look good!
  21. It's been approx 400 tablets since the day of the tooth extraction and I am happy to report it has now settled! I found a bit of time to work on the boat and made some progress. First, I continued work on the cockpit. It was quite annoying to discover that a piece I had previously prepared with significant labour had gone missing. Also, a couple of other pieces did not fit anymore. All these had to be redone. I screwed the side plywood panels, then replaced the screws with tree nails, sanded the surface and then glued the cherry veneers on top. Thankfully I did not made a mess. Lots of springs and clamps were used. Then the back panels went on the same way. The fit of the bottom vertical panels is bad but I did not notice it when I put it together and of course now it cannot be repaired. I ll need to display the boat on the starboard side... The benches look scratched but they are not, in any case Il sand them again and re apply Tung oil and then oil based varnish. The portholes I bought arrived, they are very nice and I do not think I could have made anything close myself. I also bought a step drill as I will need to open 12.5 mm holes in the side panels of the cabin. Drilling such holes in the cabin that has taken me 12 months to make is a bit frightening! The first one came out fine but this drill needs to be used with extreme care as it is very aggressive. Pilot holes are needed. I dry fitted the first porthole and really liked the result. I think that the oiled wood and the shiny brass is a beautiful combination! When all 5 pertholes (per side) come on, it should look ok. I may need to add something on the inside of the glass to make it non-transparent, we will see though.
  22. Not really Patrick. For some reason CA never worked for me so bonding dissimilar material is a headache. I sometimes use epoxy as good surface mating is not essential but it is messy and does not work very well. I have a feeling I ve been using the wrong CA glue, too fluid and too cheap! I think next I ll try a combination of gell CA with an activator to set it in seconds. I need to remember not to scratch my eyelids when gluing...😀
  23. It is certainly coming along Patrick, no easy task capturing the very many curves and recesses! You are gluing plastic, paper, styrene and wood together and some times the contact area is tiny, is it CA glue you are using? Vaddoc
  24. Welcome Pherigo! For sure start a build log and share your journey. Vaddoc
  25. Thanks Patrick, good to hear from you again! Between work, family and a wisdom tooth extraction that went pear shaped, I managed to do very little work. Still, I made the cabin top hand rails. Turned out to be one of the most enjoyable tasks! I wanted to use pear but somehow, I only realised the wood I was using was cherry after the rails were finished. A splash of Tung oil and they are ready to be installed and then varnished.
