Everything posted by vaddoc
Epoxy glue
vaddoc replied to mtaylor's topic in Painting, finishing and weathering products and techniques
A couple of things on epoxy Mark: It can be very messy, uncured epoxy though can be cleaned with vinegar (Epoxy is alkaline) Different epoxies can be very different, some flexible and some not, however they are generally all brittle. Epoxy thickened with something (I use gypsum) is far stronger. It also fills gaps very well. In cold weather, if the 2 parts become very thick, a few secs in a microwave restores them. -
Dear all Thank you for your likes. Indeed Bedford, there are some tasks in model building that are certainly therapeutic! So the first bunch of nails came out just about acceptable, still trying to standardise the process and solve issues. However, from then on things went much better and lovely tree nails produced This is about 2000 nails. I ll make another 1000, and since I am at it I ll process that slice of cherry for future use. Then I ll be ready to start replacing screws. I had make a thread on making nails, I ll update that as well. Regards Vaddoc
Well, it has been so long since my last post, I had to look to find my log! So a lot of things have come to pass: I lost some more weight, gained a belt in Tae Kwon Do, injured my hamstring and converted to an electric car to name a few. In the shipyard though, progress has been far more modest - I have been very busy lately. I finished all ribs but the foremost one. This was left in place until the screws at the stem are replaced with tree nails. There were a few ribs that needed a lot of twisting and bending but steaming the ribs worked miracles. Most of the ribs are beech but I think I must have mixed my strips a bit and some birch and alder may have sneaked in. Also, I think I should have had more cant ribs at the bow - it's ok though So, each screw holding the plank to the temporary frame had to be removed, the rib installed, the hole re-drilled from the outside in, through the rib now, and a new screw inserted from the inside to push the rib against the planks. 13 planks x 2 sides x 2 screws each x 32 ribs( +stem) + a few here and there = 1700 screws. So, 1700 screws to attach the planks to the temporary frames, then another 1700 to attach the ribs to the planks. But now, all these screws need to be removed and replaced with tree nails. So we need 1700 tree nails + wastage. I have a fair few left from other projects but there is no consistency in colour, material and size. So I need to make them. The photo bellow shows my tree nail making station: Now, I have made many thousands tree nails using the needle method but I really struggled. The needle burned the wood, the nails constantly broke off inside the needle, couldn't find the right size needle, in short mayhem. I spend a lot of time experimenting and finally got things to work. These are the tree nails I made today, ready to be released by aggressively sanding the underside. I think there are about 600 or so. Every missing nail was a blockage in the needle that had to be cleared. So, these were the changes I made that fixed the problem: I used a needle with thin wall. I slowed the speed of the drill press from high to medium (low speed led to breakages). I realised the wood was too dry so I soaked it in water overnight and allowed it to dry. Finally, I made sure the end of the needle was sharp. Now, the best nails are made from hard wood with straight grain. This is the wood I am using (slices already soaked): The right wood is cherry. Very nice wood, I ve already made thousands of nails from these wood but lately it has been playing up. The wood on the left is either Howthorn (most likely) or apricot (I had two logs but I could find only one in the garage, so it is either or). It is a hard wood though so it does not matter. (The little piece of wood at the bottom of the photo is indeed apricot. I tried a slice but it is too dry and did not work.) So, next few sessions in the shipyard will be devoted to tree nails. Best wished Vaddoc
It will still stretch. I found Mara threads very good alternative as suggested by Chuck. A lot of discussion in relevant threads.
The good quality cotton threads will produce excellent rope. The only problem is that if there is any tension, the rope will stretch.
Work Table Recommendations ?
vaddoc replied to DanB's topic in Modeling tools and Workshop Equipment
Have a look at this. I actually made two of these benches. Made a large one and then an even larger. Very heavy, very solid. -
I think this is why Highfield levers were invented
Very interesting boat GL and very nicely done so far! It was a pleasure to catch up. Looking forward to the rest of the journey, it will be interesting to see how the rigging will be laid out Vaddoc
- 153 replies
- Ancre
- Bruno Orsel
These are indeed good news Hakan! Hopefully you ll be on the mend in no time at all. Your boat also seems to be progressing very well. I am very impressed that you can create a three dimensional fair hull from just 2D plans, I am really looking forward to see how all will come together. I presume you will use birch for the planks? What wood did you chose for the frames? Vaddoc
Another quick update I started steaming and installing the ribs. As expected, beech responded wonderfully to wet heat becoming as pliable as boiled spaghetti. My steam box is working great and in no time I had bent half of the ribs. I made a simple spacer to make sure the rib is placed at equal distances from the frames Then I started screwing the ribs to the planks. Regards Vaddoc
Hi @Gregory I do not come across any specific information, but these are my thoughts: Probably transoms were made from a few pieces, edge to edge like the planking but thicker. It is much easier to find very wide short segments so maybe it would only take 3 pieces to make a Transom. Most of the transom is well above the water line so no caulking would be needed. I do not think any particular framing would be needed as usually there would be a sternpost or at least a knee, and also the planking, to keep the transom securely in place. In the boat I am building, each transom piece would be nailed to three planks on each side. In more modern larger vessels, on top of the sternpost there are extra pieces of timber as the photo bellow shows. This would be easy enough to use also for boats and would result to a very strong transom. However in "The boats of men-of-war" by May, for a 22 ft long boat it states: Transom: Broad or moulded at the upper part 3ft 9 in, thick or sided 3 inch, knees sided 2 3/4 in. No mention of framing.
Dear friends Planking is finished! But what a difficult boat to plank! With great difficulty I managed to scrape a few moments here and there to work on the boat. My 3D plans I am pretty sure are correct, but I think they did not transfer that well to wood as some of the lines looked a bit wrong. In any case, with a lot of eyeballing and using the 80 - 20 rule, it all came together. But it was not easy! It is not only that the planks need to bend and more importantly twist a lot, it is also that the largest distance keel to sheer is near the bow and not midships. On top of this, batens cannot really be used due to the very curved bow. The scarfs also made a fair plank curve difficult. That was a mountain to climb. My planking I think is more or less correct but if I was to build this boat again, I would change the run of the planks a bit at the bow. A few photos: Perhaps the planks could end a bit lower at the bow but I do not think this is too significant, there is plenty of room. Another issue is that gaps have appeared between the planks. The wood database mentions that beech has large movement in service and indeed, the planks have shrunk considerably after they reached their moisture balance. I will use filler but I cannot sand the hull just yet, the screws need to go which means all the ribs need to be installed, the temporary frames to be removed and all the screws exchanged for tree nails. So we now move on to the next stage: steam bending ribs! And also making a few thousand tree nails... I started cutting parts of the frames to open up the space This is as far as I was able to get, at least I managed to not go into hibernation. But I am really sorry I have not been able to keep up with your logs and updates. Till next time My very best wishes to all Vaddoc
Dear all Many thanks for your likes and comments. @BobG Yes Bob, for the scales I work at 1mm screws are fantastic. They hold things accurately and securely, can be removed and hole filled with tree nail. I ve used many thousands so far, go for stainless steel to avoid head rounding off. Modelling has slowed down as other priorities have stepped in. One is family, wife and two daughters 5 and 7. Work (of course) but also a need to increase physical fitness. During lockdown I put on a lot of weight that really started to affect me and something had to be done. So, spare time went to Tae kwon Do, cycling, gym etc. It did work, along side a sensible diet and I am 14 kg lighter - about 31 pounds and much fitter. Still a bit more to go though! Now, modelling has slowed down for two other reasons. One has been the very low temperatures, my garage at -1 C is pretty unpleasant. The other reason was that things have become more complex and difficult. Repair/restoration is much more difficult. I ended up taking more planks off, more than the photos bellow show, to correct gaps or defects but also because their shape was a bit off, collectively changing the run of the planking. The two plank halves had to be split as the aft part can be reused for some of the planks, Isopropyl alcohol dissolved PVA very effectively. I used the existing planks to re-arrange the run of all the other planks. This time I must stick to the markings, even if the planks end up with pigtail shapes. I hope the new markings will give a better plank run, we ll see Till next time Vaddoc
@druxey You are very right Druxey. A valuable lesson learned! I need to decide now whether I can continue or whether I should take all the planks out and start again. I think though there is enough space at the stem for 4 more planks.
Oh dear. One step forward, many steps backwards! But first thing's first. Many thanks to all for your comments and likes! Jan 6: I continued with the planking. I fitted the next plank which was wildly off. Still, I heated it up and fixed in place, to be sanded to shape later on. This is when I eyeballed the planks and thought: "Something is wrong". Jan 7: I tidied up the shipyard! And then continued with the planking. With some aggressive sanding, the plank fitted fine: Something was not right though. The plank had a funny S shape at the stem, did not look fair at all. Also, the general run of the planks is rising too acutely at the bow. Due to the very rounded shape of the bow, it should be a much more subtle rise, following the shape of the sheer to a degree. Something is not correct. See how after the last frame, the plank goes horizontal-this is wrong. At the most forward frames, the planks should rise a bit higher before meeting the stem. Jan 8: It is not possible to proceed with the planking. Something is really wrong. There is too much space to be covered at the first 3 frames, the planks do not have a fair run and become too thick near the stem, there is not enough space at the stem and it seems that the sheer should be going a bit higher at the stem - despite the CAD saying otherwise. Even following the current markings which are probably wrong, I have made this plank too narrow. This plank is clearly wrong. The next plank would need to be very thick at the bow to close the gap. I thought it would be ok having this plank a bit more narrow - wrong! Despite these concerns, I went ahead and made the next plank on both sides. The shape looks properly wrong! I tried to re-arrange the plank widths at the stem but I could feel the main issue was elsewhere. The new plank fitted in place. Looks absolutely horrible. It is very obvious that the previous plank is cut too narrow near the bow and is too thick at frames 6, 5 4 & 3. There is also this very ugly massive gap at the plank further down. Not sure how this opened up but it is not really acceptable. So decision taken: one plank from port side and two from strarboard need to come out. Here they are: This was painful but necessary. I should be able to salvage the aft parts of the planks and make again the scarfs. January 10: I redid the run of the planks again. I tried to make them equal width but my primary concern was to have a more pleasant run and to follow the sheer. I think it looks ok. The bow is so curved that it is very difficult to use battens and to eyeball the hull. Comparing the new with the old markings (not too clear on the photo), it is clear some of the frame were way off. So here is where we are now. I think the contralateral plank will need to be removed also. So next: transfer the markings to the other side, quite possibly remove the port plank, fill the screw holes and continue with the planking, hopefully I ll be able to salvage the aft halves of the planks. This is a very difficult boat to plank! Have a great new year everyone! Vaddoc
Then it was gorilla original. This is not PVA glue. Gorilla original activates with water and is an expanding glue, filling gaps. I tried it years ago but made a big mess. It probably would be good for wood working when parts do not fit well, like gluing chairs but maybe not too good for modelling. I am not sure if this glue can be dissolved with chemicals. Maybe best to experiment, apply some glue to a scrap piece of wood and use heat or either IPA or acetone, what ever you can get, and see how it reacts. Scraping with a sharp blade may actually do the trick and leave a smooth surface.
Just finished going through your inspiring log, fantastic work! I hope all is well Drazen.
- 487 replies
- ship of the line
- 80 guns
