MrBlueJacket
Everything posted by MrBlueJacket
  1. So after thinking of options like wire, etc. I settled on using thread. I have a spool of .015 tan line, so I cut off several 6" lengths and inserted them through holes I made in the sail..
  2. And the staysail and jibsail are attached. I glued them to their respective stays with tachy glue. Next I have to figure out how to do the mast hoops.
  3. The sheet on the right is liberally sprayed with flat clear lacquer, which doesn't shrink it. Then the second piece is laid over it, and wiped with a finger to remove any air bubbles.
  4. Starting to do the sails. First step is to tape the sail pattern down, then tape silkspan over it. Next step is to trace the lines onto the silkspan, then cut another piece with the grain at 90 degrees to the first piece.
  5. Both gaffs installed. All that is left are the sails, davits, lifeboat, anchors and stern flag. Oh, and putting it on a water base display.
  6. Bluejacket is proud to announce an exciting new kit, the Ellie Mara, a 2-masted coastal schooner typical of the mid-1800's. With a wide beam and shallow draft, she could get very close to the shore. The kit has a cast resin hull, laser cut pieces, Britannia fittings, brass rod, and 4 sizes and colors of rigging thread. overall length is 15", and is scaled for HO (1:87) She has a very attractive list price of $124.00, part number K1115.
  7. Very nice, Jim! more photos, please. And your customer file now shows you will get a 10% discount off the next kit you buy from us. I can suggest Red Jacket, Charles Notman, Alfred, Mahogany runabout to name a few.
  8. To prevent underbleed, brush or spray either clear or the underlying paint on the edge of the tape.
