MrBlueJacket
Everything posted by MrBlueJacket
  1. Congratulations! Your customer file now has a note that you will get 10% off your next kit from us. Nic
  2. Yes, drill all the way through. I've put the Wendameen aside for a bit, doing a project for Al. Nic
  3. Regarding CA glue, it has a shelf life of 6-12 months at room temperature. You will notice that it starts to take longer to set. While accelerator helps, I find it better to just get a new bottle. Unopened glue will last a long time in the freezer. Nic
  4. So Bob, where in Maine are you?
  5. Yes, by all means start a build log. When you have finished, I will give you 10% off the next kit you buy from us! Nic
  6. I will add that working with Al is a real joy. He has a great sense of dry humor. Here's a photo of his workshop door.
  7. Silkspan is what stick-and-tissue airplane modelers cover their models with. Perhaps a hobby store might carry it. Here is a photo of Sultana with silkspan sails.
  8. So after much thinner, rubbing, scraping and sanding, a coat of primer, more sanding, and a spray tan, the result is much more pleasing.
  9. I believe they are called mast trucks, and would have a sheave in them for the flag halyards. https://en.wikipedia.org/wiki/Truck_(rigging)
  10. To me it looks like some filler should do the trick. The fatter bulwark will be hidden by the caprail, perhaps it will need to be a bit wider. No-one is going to take a ruler to your model an critique it. " putty and paint....makes it look like what it ain't"
  11. A Dremel with a cut-off wheel will cut the brass nicely. I have seen them cut straight across, but also seen them cut at an angle to match the hull. Take your choice. Nic
  12. Rather than mask off, I decided to freehand paint the deck. It will need a second coat, and then I'll touch up the bulwarks.
  13. #1-Good judgement comes from experience. Experience comes from bad judgement. #2- Experience is what you get right after you needed it.
