MrBlueJacket
Everything posted by MrBlueJacket
  1. Personally, I love the Savannah, but it was not a good seller. Nic
  2. A pintle is a bent wire on the rudder that goes into an eyepin hole on the boat. It is shaped like a sideways "L" It forms the hinge for the rudder. I drew a diagram for you.
  3. So I painted the inside yellow (spray) and didn't like it, so I wiped it off with thinner. Then I used a brush. Needs another coat, yellow is difficult to cover. Then I used a compass to mark off where the visible frame heads will go. 5/32" spacing amidships, and 1/4" near the ends.
  4. Hi, Your kit is not from 1938, since it has the BlueJacket label, it is after 1972. It shows that the kit design goes back that far.
  5. Had a chance to dig into some old catalogs and found this from 1938:
  6. Hi Brian, Please do a build thread. When you finish, I will give you 10% off your next kit you get from us. Nic
  7. Yes, as we run out of MM stock, we are switching over to True North. There are several reasons for this. First, of course is that it is good enamel paint. Second, they make it here in Maine, less than an hour away. Third, they are quick to remedy any problems that arise. Fourth, they are willing to make a new color just for us, and have done so 4 or 5 times. Colors like Depot Buff and Jade Green for example. Fifth, they are modelers themselves, and understand us.
  8. Try using 220 wet/dry sandpaper (the black stuff) and use it wet. The water helps to sluff off the sanding dust and the paper lasts a lot longer ( a lot lot longer)
  9. I agree it needs some sanding. Personally I use automotive lacquer primer in a spray can. Usually 2 or 3 coats, sanding in between.If you go look at my thread on the New Bedford Whaleboat, that's the stage I'm at over there.
