MrBlueJacket
Everything posted by MrBlueJacket
  1. I must say that the food and speakers were both top notch.
  2. My goal is to have her finished by April 25th, which is the next Joint Clubs meeting of the Northeast, held each year in New London CT. It will be close......
  3. Hi, Yes, she has backstay spreaders, but they are supposed to go on after the backstays are in place. That way they are aligned with the run of the backstay.
  4. After the ratlines, the stays came next. Now that they're done, it's on to the backstays, then the 15 yardarms.
  5. The solution to that is to drill the hole first, then cut out the shape you want around it. I learned that the hard way.
  6. I have decided to extend this offer indefinitely. Several more people are added, you would get a note from me if I've seen it. If not, then PM me to add you. Nic
  7. And with the masts stepped, it is time to do the ratlines. It's just another one of those jobs that creates hours of great fun........
  8. Got to do the main stay and main top stay. These are much easier to install before the foremast goes in, as you can see from the picture. Small strips of paper towel were glued on and painted to represent the leather chaffing guards.
  9. And the mainmast shrouds are done. I will be doing the ratlines before the backstays so I have more space to work around.
  10. For the first shroud P&S I use the bent wire method (looks like a staple) - that way both sides have the same spacing. For the rest of the shrouds, I eyeball it to within about 1/32" and sieze it. Then I can tighten or loosen the lanyards, and also wind or unwind the shroud to get the final height to "eyeball" level.
  11. So we go to the next pair of deadeyes. Now the task is to make sure all the upper deadeyes are at the same level, which should be parallel to the waterline, not the deck.
  12. And so we begin the lower shrouds.The first shroud on each side, like the bowsprit, is critical to the alignment of the masts.Unless they are correct, the problems will mount later on. BTW, the masts are not glued in, they are held just by the rigging, like full-size practice. The lanyards on both sides are loose, then tightened up and adjusted to make the mast square before tying off.
  13. battery powered Dremel tool
  14. To avoid problems, we have to think ahead about what needs to go where before the other stuff gets in the way. For example, attaching the Mizzen stay would be nearly impossible after the main shrouds are installed.
  15. Now starts the stepping of the masts. Here's the Mainmast being set up at the proper rake angle, as determined by the template provided in the kit.
  16. Lead fittings are subject to corrosion (lead bloom) and decay, eventually turning to white powder. If they are perfectly sealed with paint, that doesn't become a problem for several decades. However, I suggest you replace them with Britannia metal fittings (lead-free pewter) - you can find probably everything you need from the fittings section of our website.
  17. Mike, Since you are doing a build thread on the Notman, when it is done you will be getting 10% off your next kit you get from us. FOr the Red Jacket, that means a $63 savings. Nic
  18. And this is the "money shot" - making sure everything is square and straight. Especially the martingale, it is balanced on both sides, and I had to play with the lanyards to get the tension just right.
  19. To make it easier to work on, I lay the ship on its side, with a foam rubber sheet under it for protection.
