MrBlueJacket
Everything posted by MrBlueJacket
  1. Look at where and why the drills are used - often a different diameter will work just fine. You're only talking a few thousandths of an inch. If you think you will do another model, consider the entire #61-80 drill set. As for mistakes - the definition of experience is "what you get right after you needed it"
  2. As for applying the CA glue, look at the tip of the month in this link (near the bottom) http://campaign.r20.constantcontact.com/render?m=1105166336677&ca=64bf22da-704d-496c-8e70-95bc1220ea79
  3. Regarding the garboard strakes, look at the instructions page 5 where it starts with "hull planking" - the second sentence says the garboard strakes are cut oversize to allow for trimming. So you did not do anything wrong!
  4. I held it with my fingers at the center of the keelson, then applied a bit of CA inbetween the two middle formers. Then is was easy to use clothespins at the ends and finish the gluing.
  5. Next comes the first plank, a strip of 1/16 x 1/8. Then the next plank, a laser-cut piece of 1/32. So the 1/16 thick plank sits proud of the planks on either side. That's because it sits on the turn of the bilge. The instructions then say to fair it to the other planks, making a rounded surface. They also recommend putty to fill in any irregularities. For me, when it comes to putty, the more the better. Less chance of needing a second coat. So far I think I'm into this for 3 1/2 hours or so.
  6. First planks to go on are the garboard planks, Quite wide, but wetting the 1/32 basswood let them form to the jig perfectly.
  7. Moving on to construction, the first thing is to build the assembly jig. 4 formers, then glue the stem and stern to the keelson and put over the jig. I liberally waxed the formers to prevent the planks from sticking, we'll see how well that works.
  8. So here we go to build this interesting whaleboat. Despite its large scale, it is a small model. Here's the box top And the overview of the contents:
  9. So now I have put all 3 top yards on and attached their lifts. Now this project goes on hold while I build a New Bedford Whaleboat for a customer.
  10. Been too busy to do much. Here's the fore top yard almost done. Need to add 4 blocks, then it can be mounted.
  11. I leave some DNA on every model. Usually just a little blood from getting poked by the #11 blade.
  12. Nice work, Stan. We'll be sending corrected copies to everyone who bought a Perry.
