Everything posted by MrBlueJacket
- 356 replies
- red jacket
- finished
Additional info - some of the mast"straps" are Britannia metal strips (mast caps) and between the hounds are cast fittings to hang the yard trusses.
- 356 replies
- red jacket
- finished
Let's answer these in order: mast straps are 1/16" black vinyl tape, once they were all on, I sprayed flat clear over them. Yes, that is the bumpout for the shrouds. Instructions and plans are for single bullseyes for the upper shrouds. Instructions say masts are dark brown, but since they were probably greased, and since I did the red bottom it would be her maiden voyage (she was coppered after she arrived in England) I thought a little lighter finish would be appropriate.
- 356 replies
- red jacket
- finished
So now the foremast is complete. The extra thread lengths are because the ratlines at the upper end of each mast segment go over to the first backstay.
- 356 replies
- red jacket
- finished
Hi, If you PM or email me, I will give you 10% off your next BlueJacket kit once you finish this build. That is a standing offer I have to promote build logs. Nic
- 29 replies
- spray
- BlueJacket Shipcrafters
So now I'm into the ratlines. It's about a wash as to whether it is easier on the model of off the model. Notice that to get the mast to stay at the correct position, I had to use a couple of clothespins to stabilize it. Also, putting a white background behind the mast helps my aging eyes. My opinion of ratlines is like forming the deadeyes (see page 2) "it's hours of great fun"
- 356 replies
- red jacket
- finished
- 356 replies
- red jacket
- finished
And yes, even the topmast shrouds are easier off the model. But I'm holding off any final comment until I see how it is to do the ratlines.
- 356 replies
- red jacket
- finished
- 356 replies
- red jacket
- finished
Time to start the rigging. Normally, I step all the lower masts and add the shrouds and stays, then work my way up. However, the instructions say to build the masts and rig the upper parts before putting mast to the deck, claiming it is easier. I will try it on the foremast and see if I like the method. Here is the foremast, finished and ready for some thread.
- 356 replies
- red jacket
- finished
Very nice! I have added a note in your customer file for 10% off your next kit purchase. Thanks for doing the build thread. Nic
- 33 replies
- Maine
(and 3 more)
So it's time to install the outriggers for the main braces. The instructions say to drill a hole, then use a sharp blade to square out the hole for the outrigger. In a moment of inspired laziness, I figured it would be easier to round out the square piece than to try and square out the hole. Worked like a charm.
- 356 replies
- red jacket
- finished
Very nice job. When you put "finished" in your title, I will make a note in your file that you get 10% off your next kit from us. Nic
- 60 replies
- mary taylor
- solid hull
Yes, we have kept a close eye on 3-D printing. From a kit production standpoint, it is prohibitively expensive for not much gain. However, for the modeler, it is practical. For example, if you want to get nice marine figures in 1/192 scale, shapeways has you covered. Look here: https://www.shapeways.com/product/55GX8HF2S/1-192-us-navy-dungaree-set-1?optionId=61093772&li=marketplace And here's one in place on the USS Kidd.
- 227 replies
- Stephen Hopkins
Looks good, Tim. I found a 1/200 tractor for you: https://www.shapeways.com/product/AEG6GRKJC/1-200-scale-m915-tractor Nic
- 227 replies
- Stephen Hopkins
Been doing a little of this and a little of that. Like adding the vertical ladder to the deckhouse, the ventilators, anchor chain, bitts, etc. Pretty soon I think I'll be starting the rigging.
- 356 replies
- red jacket
- finished
Again, thanks to all for the well wishes. Nic
- 356 replies
- red jacket
- finished
The rear deckhouse is permanently installed, and the bilge pump is fabricated. Boy, does it feel good to get back to modeling.
- 356 replies
- red jacket
- finished
- 356 replies
- red jacket
- finished
Made the several sampson posts for the forecastle from 1/8" square stock. Pins are for secure mounting.
- 356 replies
- red jacket
- finished
So I have been out of the hospital for a week now. Get tired very easily, every day is a little improvement. Got to looking at the RJ last Friday, and wondered why there are no scupper ports in the bulwarks. Careful examination of the plans shows 8 tiny channels from the deck out the hull. I thought "why bother?"but I couldn't ignore them. Here's a shot of one of them (just left of the locker) and its exit. Time to bring out the black touch-up paint.
- 356 replies
- red jacket
- finished
If you haven't cut the Spring stay yet, there is an alternative: Seize the middle of the shroud like before, then wrap the shroud line around the lower mast head, and then seize it together in place. A bit awkward, but (I think) easier than cutting a line. Nic
- 60 replies
- mary taylor
- solid hull
to RFP: My GUESS is that if the wheel well confined the splash, some of it would be directed against the turn of the paddle, using energy for nothing. Just my guess, but try to picture the water splashing against the top, then back-splashing to the wrong direction. by letting the water splash go higher, it would more likely drip straight downand not impede progress. Nic
